Whenever I try to open a GUI app from the terminal I get this:
symbol lookup error: /usr/lib/libtracker-sparql-3.0.so.0: undefined symbol: g_task_set_static_name
Also when trying to launch pamac, I get a similar error:
symbol lookup error: /usr/lib/libsoup-3.0.so.0: undefined symbol: g_task_set_static_name
If I try to grep inside the file causing issues I get this as the output:
I have tried reinstalling glib2 which I believe(gpt-4 told me) is what they both depend on, but it is still not working. I also tried to reinstall/uninstall the fonts to see if that is causing an issue(particularly Cairo font). Any help regarding this will be appreciated. Also, this is my first time using a Linux support forum so forgive me if I am verbose enough(Yes I am new to the whole thing).
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information.
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxiin a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already
for your problem in the forum ? (Wisdom lies in reading
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=b5ccde6c-473d-4f4d-8235-7d2b90565a02 rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 intel_ucode=early
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Micro-Star product: Titan GT77 12UHS v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-17Q1 v: REV:1.0 serial: <filter> UEFI: American
Megatrends LLC. v: E17Q1IMS.109 date: 06/27/2022
ID-1: BAT1 charge: 79.4 Wh (84.6%) condition: 93.8/95.0 Wh (98.7%)
volts: 16.6 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
System RAM: available: 62.5 GiB used: 14.08 GiB (22.5%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
size: 32 GiB speed: spec: 4800 MT/s actual: 4000 MT/s volts: curr: 1.1
min: 1.1 max: 1.1 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M425R4GA3BB0-CQKOD serial: <filter>
Device-2: Controller0-ChannelA-DIMM1 type: no module installed
Device-3: Controller1-ChannelA-DIMM0 type: no module installed
Device-4: Controller1-ChannelA-DIMM1 type: DDR5 detail: synchronous
Info: model: 12th Gen Intel Core i9-12900HX socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake gen: core 12 level: v3 note: check
built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151)
stepping: 2 microcode: 0x2C
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 1312 high: 2500 min/max: 800/4900:5000:3600
base/boost: 2277/8500 scaling: driver: intel_pstate governor: powersave
volts: 0.9 V ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 831 5: 833
6: 2500 7: 800 8: 800 9: 800 10: 800 11: 800 12: 932 13: 800 14: 2500
15: 800 16: 2500 17: 800 18: 819 19: 972 20: 801 21: 2500 22: 2500 23: 2500
24: 2500 bogomips: 119832
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
sdbg sep serialize sha_ni smap smep split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-HX GT1 [UHD Graphics 770] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:4688
class-ID: 0300
Device-2: NVIDIA GA103M [GeForce RTX 3080 Ti Mobile] vendor: Micro-Star MSI
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2420 class-ID: 0300
Device-3: Bison HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:12 chip-ID: 5986:116f
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5760x2630
Monitor-1: DP-1-5 pos: primary,top-right res: 3840x2160 dpi: 163
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-2: eDP-1 pos: bottom-l res: 1920x1080 hz: 120 dpi: 128
size: 381x214mm (15x8.43") diag: 437mm (17.2") modes: N/A
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel UHD Graphics (ADL-S
GT1) direct-render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:7ad0 class-ID: 0401
Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2288 class-ID: 0403
Device-3: Razer USA BlackShark V2 Pro
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 1532:0528 class-ID: 0300
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.70 status: off tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel Alder Lake-S PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
Device-2: Realtek Killer E3000 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 5000 bus-ID: 05:00.0
chip-ID: 10ec:3000 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-14:14 chip-ID: 8087:0033 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 2.8 TiB used: 75.17 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL22T0HBLB-00BTW
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: GXB7401Q temp: 44.9 C
scheme: GPT
SMART: yes health: PASSED on: 226d 11h cycles: 306
read-units: 24,682,610 [12.6 TB] written-units: 50,553,620 [25.8 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Extreme SSD
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD serial: <filter>
fw-rev: 0111 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler 3.0
size: 28.82 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
scheme: MBR
ID-1: / raw-size: 488.28 GiB size: 479.55 GiB (98.21%)
used: 75.14 GiB (15.7%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6 label: N/A uuid: b5ccde6c-473d-4f4d-8235-7d2b90565a02
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
used: 30.3 MiB (10.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: SYSTEM uuid: D269-C6A4
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 1.36 TiB fs: ntfs label: Windows
uuid: 9A0A364A0A362423
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 900 MiB fs: ntfs
label: WinRE tools uuid: CAAED6DDAED6C15D
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 23.01 GiB fs: ntfs
label: BIOS_RVY uuid: 3EA8D924A8D8DB89
ID-5: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: exfat label: Games SSD
uuid: 546D-C379
ID-6: /dev/sdb1 maj-min: 8:17 size: 3.47 GiB fs: iso9660
ID-7: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: E71D-7E89
Hub-2: 1-1:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Device-1: 1-1.2:5 info: Razer USA Goliathus type: mouse,keyboard
driver: razeraccessory,usbhid interfaces: 3 rev: 2.0
chip-ID: 1532:0c01 class-ID: 0300
Device-2: 1-1.3:15 info: Razer USA BlackWidow V3 Pro type: keyboard,mouse
driver: razerkbd,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:025a class-ID: 0300
Hub-3: 1-1.4:7 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
Hub-4: 1-1.4.4:9 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-1.4.4.3:11 info: Razer USA Base Station V2 Chroma type: HID
chip-ID: 1532:48f0 class-ID: 0300
Device-2: 1-1.4.4.4:13 info: Razer USA Base Station V2 Chroma type: HID
driver: razeraccessory,usbhid interfaces: 2 rev: 2.0
chip-ID: 1532:0f20 class-ID: 0300
Device-3: 1-2:3 info: Razer USA BlackShark V2 Pro type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Device-4: 1-3:4 info: Razer USA Naga Pro type: mouse,keyboard
driver: razermouse,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:008f class-ID: 0301
serial: <filter>
Device-5: 1-4:6 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:6094 class-ID: ef00 serial: <filter>
Device-6: 1-8:8 info: SteelSeries ApS KLC type: HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 1038:113a class-ID: 0300
Device-7: 1-9:10 info: SteelSeries ApS ALC type: HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 1038:1146 class-ID: 0300
Device-8: 1-13:12 info: Bison HD Camera type: video driver: uvcvideo
interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:116f class-ID: fe01 serial: <filter>
Device-9: 1-14:14 info: Intel type: bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Hub-5: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
Hub-6: 2-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
Hub-7: 2-1.4:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
Device-1: 2-1.4.3:4 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50
type: mass storage driver: usb-storage interfaces: 1 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 296mA
chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
Hub-8: 2-1.4.4:5 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
Hub-9: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-10: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Device-1: 4-2:2 info: SanDisk Extreme SSD type: mass storage driver: uas
interfaces: 1 rev: 3.2 speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1
power: 896mA chip-ID: 0781:55a8 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 479 Uptime: 36m wakeups: 1 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 alt: 12 clang: 15.0.7 Packages:
pm: pacman pkgs: 1259 libs: 378 tools: pamac,yay pm: flatpak pkgs: 0
Shell: Bash (sudo) v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.27
Welcome to the forum! ![]()
Are you fully up to date? See Pacman-mirrors - Manjaro
Hey Yochanan, thanks for replying. I am using default mirrors, my Pacman-mirrors version is 4.23.1, I have done sudo Pacman -Syu whenever I was trying to install something. I have also run the commands with fast-track; therefore, I think I am up to date. Tell me what else I can do.
Just to be sure, what versions of the affected programs do you have installed?
pacman -Qi tracker3 libsoup3 libpamac pamac-gtk | grep Version
Version : 3.5.2-1
Version : 3.4.2-1
Version : 11.5.4-1
Version : 10.5.1-2
Here is the output I hope it helps
The packages are up to date. I just wanted to double check as the most common reason for the problems you described are caused by being in a partial upgrade state with mismatched libraries.
Since this is not the case, my only other guess is you’ve installed either AUR packages or manually installed things locally that are interfering. No one else has reported anything vaguely similar, so it’s something local on your system causing the issue either way.
Interesting update,
If I use say “thunar” as a superuser(sudo) then the GUI opens up, but it shows some warnings on the terminal; below is the output of running the command
sudo thunar
thunar: Failed to initialize Xfconf: Error spawning command line “dbus-launch --autolaunch=4bb4cc1d89094824bc6ed9837022f55c --binary-syntax --close-stderr”: Child process exited with code 1
(thunar:13321): thunar-WARNING **: 01:13:19.234: Name 'org.xfce.FileManager' lost on the message dbus.
(thunar:13321): thunar-WARNING **: 01:13:19.234: Name 'org.freedesktop.FileManager1' lost on the message dbus.
ThunarThumbnailer: failed to create proxy: Error spawning command line “dbus-launch --autolaunch=4bb4cc1d89094824bc6ed9837022f55c --binary-syntax --close-stderr”: Child process exited with code 1
Maybe this can act as a clue and help fix whatever is wrong locally?
Never run a GUI with sudo. When something is not working as expected, there’s a reason for it. Running it with sudo is NEVER a “workaround”.
Absolutely not. There are errors running Thunar the wrong way that are not related to your issue.
