Hi,
I am unable too boot Manjaro after change the boot mode (from UEFI to Legacy) in BIOS. I tried to get it back but no result
error: symbol `grub_is_lockdown` not found.
Entering rescue mode...
grub rescue>
Thanks for the help.
Hi,
grub rescue>
How?
Just change the “boot mode” back to what it was.
I did this in bios.
You may need to run grub-install again.
(or use the install-grub script)
First you probably need to gain functionality … such as by using live media (like a USB).
In fact theres an arch forum thread from yesterday with the same symptoms…
https://bbs.archlinux.org/viewtopic.php?pid=2158920
(though note your path may be different, such as /boot/efi)
PS.
Appears to be a product of ‘efi losing its linux record for some reason’.
I can only go with what you tell here.
If you changed something - and then changed it back to what it was - there should be no reason for you to ask about a change, because there effectively was none.
When I boot to live Manjaro ISO and press detect efi bootloader I have 2 options
(hd1,gpt1)/efi/Manjaro/grubx64.exi
(hd1,gpt1)/efi/boot/bootx64.efi
It’s seem I booted a windows10 usb flash drive by mistake. Can I delete the second one. Thank you.
In the live media I booted here.
PS.
Just Reinstall and Update Grub seems to solve the issue.
Thanks again.
