Just installed Manjaro, and I am having issues with my graphics card: Nvidia GeForce GTX 750. I want to replace the existing video-nvidia 575.64.05 with 470 driver. Could someone explain the steps on how to do this?
I can remove the current driver with:
sudo mhwd -r pci video-nvidia
but what order should I do this? I read where I remove driver and reboot, Manjaro will pick up with another driver, then I can install the 470 driver with:
sudo pacman -S nvidia-470xx-dkms nvidia-470xx-utils nvidia-settings
The problem is, that with the Manjaro iso, if I choose open source drivers, it comes up to a black screen.
I tried removing the current gpu driver, rebooting, and got a black screen. I used Timeshift to revert back, then tried adding the nouveau driver, removing the current driver, rebooting and still got a black screen.
What is the correct procedure?
Thanks!
