I’m currently running manjaro kde, but I wanna test another DE like cinnamon ,so how to switch to another manjaro pre-configured DE without reinstaling the whole system?
Search the wikis and forums - learn how its generally messy and not suggested, but if you want to … simply install the required components.
ex:
https://wiki.archlinux.org/index.php/Cinnamon
[the following guide may be a bit outdated]
Then write it to USB and try the live version. Thats likely a much better ‘test’.
I’ve heard if i create a new user it won’t be conflict with my kde config.
The home configuration files wont conflict … but your libraries and applications still will … and example being you might have to replace and reconfigure your display manager - I dont know if SDDM can boot cinnamon or not. Some applications may become duplicated in the menus or have both the GTK and QT versions, etc.
Thanks I was about to make a mess
