Hi all, I’m very new to Manjaro, but I’ve been using Sabayon linux for years. I just bought an Asus TUF gaming laptop and installed a Manjaro on it as it was the only distro supporting the touchpad.
The video cards on the laptop are AMD Renoir and a Nvidia Geforce 3060. On my previous laptop, I had Intel and Nvidia and I switched between them with optirun. I tried installing bulblebee on this laptop but bumblebee wouldn’t start.
I installed hybrid-amd-nvidia-prime with mhwd but I have no idea how to switch between the video cards. So my question is is there a howto on switching between amdgpu and nvidia or if not, what is the preferred method to do it on Manjaro?
What I want for my laptop is to run on its amdgpu by default and to be able to switch to nvidia when I game or when I need cuda.
I’m sorry if I sound random, but it’s my first days with Manjaro so I’m still finding my way around. Thanks.
cuda
is completely unrelated, you can use that regardless of how the graphics stack is configured, provided that the appropriate kernel module is loaded and the necessary user space libraries are installed.
Then you should be able to run the applications of your choice with the NVIDIA GPU. E.g.:
prime-run glxgears
You can run
glxinfo -B | grep renderer
prime-run glxinfo -B | grep renderer
and observe the difference to confirm that it works.
Hi, thanks for replying. I get an error:
prime-run glxgears
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 25
Current serial number in output stream: 26
This is what I get when I use glxinfo
Extended renderer info (GLX_MESA_query_renderer):
OpenGL renderer string: AMD RENOIR (DRM 3.40.0, 5.10.30-1-MANJARO, LLVM 11.1.0)
But the system seems to know about Nvidia:
lspci|grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q] (rev a1)
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Device 1638 (rev c5)
That’s unfortunate, can you post the output of inxi -Gazy
and xrandr --listproviders
Yeah, sure.
inxi -Gazy
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:1638 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-4:2 chip-ID: 322e:202c class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: modesetting display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.30-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.2 direct render: Yes
and
Providers: number : 1
Provider 0: id: 0x45 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 2 associated providers: 0 name:modesetting
P.S. Sorry for the formatting.
Please also post the most recent Xorg log file. It’s either in /var/log/
or ~/.local/share/xorg/
Here it is:
cat /var/log/Xorg.0.log
[ 358.802] (--) Log file renamed from "/var/log/Xorg.pid-7048.log" to "/var/log/Xorg.0.log"
[ 358.803]
X.Org X Server 1.20.11
[ 358.804] Build Operating System: Linux Manjaro Linux
[ 358.804] Current Operating System: Linux denijane 5.10.30-1-MANJARO #1 SMP Wed Apr 14 08:07:27 UTC 2021 x86_64
[ 358.804] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=5fae2091-744a-46c3-8daf-e7bb155d1c96 rw quiet apparmor=1 security=apparmor resume=UUID=faed2235-2e05-4af0-92a5-d7a5bcd92eae udev.log_priority=3
[ 358.804] Build Date: 13 April 2021 04:11:08PM
[ 358.804]
[ 358.804] Current version of pixman: 0.40.0
[ 358.804] Before reporting problems, check http://wiki.x.org
[ 358.804] Markers: (--) probed, (**) from config file, (==) default setting,
[ 358.804] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Apr 24 20:53:33 2021
[ 358.804] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 358.804] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 358.804] (==) ServerLayout "layout"
[ 358.804] (==) No screen section available. Using defaults.
[ 358.804] (**) |-->Screen "Default Screen Section" (0)
[ 358.804] (**) | |-->Monitor "<default monitor>"
[ 358.805] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 358.805] (**) | |-->Device "integrated"
[ 358.805] (==) No monitor specified for screen "Default Screen Section".
[ 358.805] (==) Automatically adding devices
[ 358.805] (==) Automatically enabling devices
[ 358.805] (==) Automatically adding GPU devices
[ 358.805] (==) Automatically binding GPU devices
[ 358.805] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 358.805] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 358.805] Entry deleted from font path.
[ 358.805] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 358.805] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 358.805] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 358.805] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 358.805] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 358.805] (II) The server relies on udev to provide the list of input devices.
[ 358.805] (II) Module ABI versions:
[ 358.805] X.Org ANSI C Emulation: 0.4
[ 358.805] X.Org Video Driver: 24.1
[ 358.805] X.Org XInput driver : 24.1
[ 358.805] X.Org Server Extension : 10.0
[ 358.807] (++) using VT number 1
[ 358.807] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 358.807] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 358.818] (**) OutputClass "AMDgpu" setting /dev/dri/card0 as PrimaryGPU
[ 358.821] (--) PCI: (1@0:0:0) 10de:2520:1043:16a2 rev 161, Mem @ 0xfb000000/16777216, 0xfc00000000/8589934592, 0xfe00000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[ 358.821] (--) PCI:*(5@0:0:0) 1002:1638:1043:16a2 rev 197, Mem @ 0xfe10000000/268435456, 0xfe20000000/2097152, 0xfc500000/524288, I/O @ 0x0000d000/256
[ 358.821] (II) Open ACPI successful (/var/run/acpid.socket)
[ 358.821] (II) LoadModule: "glx"
[ 358.821] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 358.823] (II) Module glx: vendor="X.Org Foundation"
[ 358.823] compiled for 1.20.11, module version = 1.0.0
[ 358.823] ABI class: X.Org Server Extension, version 10.0
[ 358.823] (II) LoadModule: "modesetting"
[ 358.823] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 358.823] (II) Module modesetting: vendor="X.Org Foundation"
[ 358.824] compiled for 1.20.11, module version = 1.20.11
[ 358.824] Module class: X.Org Video Driver
[ 358.824] ABI class: X.Org Video Driver, version 24.1
[ 358.824] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 358.830] (II) modeset(0): using drv /dev/dri/card0
[ 358.830] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 358.830] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 358.830] (II) Applying OutputClass "AMDgpu" options to /dev/dri/card0
[ 358.830] (==) modeset(0): RGB weight 888
[ 358.830] (==) modeset(0): Default visual is TrueColor
[ 358.830] (II) Loading sub module "glamoregl"
[ 358.830] (II) LoadModule: "glamoregl"
[ 358.830] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 358.835] (II) Module glamoregl: vendor="X.Org Foundation"
[ 358.835] compiled for 1.20.11, module version = 1.0.1
[ 358.835] ABI class: X.Org ANSI C Emulation, version 0.4
[ 358.901] (II) modeset(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.40.0, 5.10.30-1-MANJARO, LLVM 11.1.0)
[ 358.901] (II) modeset(0): glamor initialized
[ 358.901] (II) modeset(0): Output eDP-1 has no monitor section
[ 358.902] (II) modeset(0): Output HDMI-1 has no monitor section
[ 358.902] (II) modeset(0): EDID for output eDP-1
[ 358.902] (II) modeset(0): Manufacturer: NCP Model: 4d Serial#: 0
[ 358.902] (II) modeset(0): Year: 2019 Week: 51
[ 358.902] (II) modeset(0): EDID Version: 1.4
[ 358.902] (II) modeset(0): Digital Display Input
[ 358.902] (II) modeset(0): 8 bits per channel
[ 358.902] (II) modeset(0): Digital interface is DisplayPort
[ 358.902] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 358.902] (II) modeset(0): Gamma: 2.20
[ 358.902] (II) modeset(0): No DPMS capabilities specified
[ 358.902] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 358.902] (II) modeset(0): First detailed timing is preferred mode
[ 358.902] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 358.902] (II) modeset(0): Display is continuous-frequency
[ 358.902] (II) modeset(0): redX: 0.595 redY: 0.361 greenX: 0.346 greenY: 0.555
[ 358.902] (II) modeset(0): blueX: 0.157 blueY: 0.106 whiteX: 0.312 whiteY: 0.328
[ 358.902] (II) modeset(0): Manufacturer's mask: 0
[ 358.902] (II) modeset(0): Supported detailed timing:
[ 358.902] (II) modeset(0): clock: 354.7 MHz Image Size: 344 x 194 mm
[ 358.902] (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2180 h_border: 0
[ 358.902] (II) modeset(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1130 v_border: 0
[ 358.902] (II) modeset(0): clock: 147.8 MHz Image Size: 344 x 194 mm
[ 358.902] (II) modeset(0): Ranges: V min: 48 V max: 144 Hz, H min: 163 H max: 163 kHz, PixClock max 355 MHz
[ 358.902] (II) modeset(0): LM156LF-2F03
[ 358.902] (II) modeset(0): EDID (in hex):
[ 358.902] (II) modeset(0): 00ffffffffffff0038704d0000000000
[ 358.902] (II) modeset(0): 331d0104a5221378036850985c588e28
[ 358.902] (II) modeset(0): 1b505400000001010101010101010101
[ 358.902] (II) modeset(0): 010101010101918a8004713832403020
[ 358.902] (II) modeset(0): 350058c21000001abd39800471383240
[ 358.902] (II) modeset(0): 3020350058c21000001a000000fd0030
[ 358.902] (II) modeset(0): 90a3a323010a202020202020000000fe
[ 358.902] (II) modeset(0): 004c4d3135364c462d324630330a0035
[ 358.902] (II) modeset(0): Printing probed modes for output eDP-1
[ 358.902] (II) modeset(0): Modeline "1920x1080"x144.0 354.73 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (162.7 kHz eP)
[ 358.902] (II) modeset(0): Modeline "1920x1080"x60.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 358.902] (II) modeset(0): Modeline "1920x1080"x60.0 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 358.902] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 358.902] (II) modeset(0): Modeline "1920x1080"x60.0 147.81 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (67.8 kHz e)
[ 358.902] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 358.902] (II) modeset(0): Modeline "1680x1050"x144.0 354.73 1680 1968 2000 2180 1050 1083 1088 1130 +hsync -vsync (162.7 kHz e)
[ 358.902] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "1600x900"x60.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 358.902] (II) modeset(0): Modeline "1600x900"x59.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x1024"x144.0 354.73 1280 1968 2000 2180 1024 1083 1088 1130 +hsync -vsync (162.7 kHz e)
[ 358.902] (II) modeset(0): Modeline "1280x1024"x85.0 157.50 1280 1344 1504 1728 1024 1025 1028 1072 +hsync +vsync (91.1 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "1440x900"x144.0 354.73 1440 1968 2000 2180 900 1083 1088 1130 +hsync -vsync (162.7 kHz e)
[ 358.902] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x960"x85.0 148.50 1280 1344 1504 1728 960 961 964 1011 +hsync +vsync (85.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "1440x810"x60.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 358.902] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x800"x144.0 354.73 1280 1968 2000 2180 800 1083 1088 1130 +hsync -vsync (162.7 kHz e)
[ 358.902] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x720"x144.0 354.73 1280 1968 2000 2180 720 1083 1088 1130 +hsync -vsync (162.7 kHz e)
[ 358.902] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 358.902] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "1024x768"x144.0 354.73 1024 1968 2000 2180 768 1083 1088 1130 +hsync -vsync (162.7 kHz e)
[ 358.902] (II) modeset(0): Modeline "1024x768"x85.0 194.02 1024 1108 1220 1416 768 768 770 806 doublescan -hsync +vsync (137.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "1024x768"x75.0 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 358.902] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 358.902] (II) modeset(0): Modeline "1024x768i"x87.0 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "960x720"x85.0 170.68 960 1036 1144 1328 720 720 722 756 doublescan -hsync +vsync (128.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "960x720"x75.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 358.902] (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 358.902] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 358.902] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 358.902] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 358.902] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "800x600"x144.0 354.73 800 1968 2000 2180 600 1083 1088 1130 +hsync -vsync (162.7 kHz e)
[ 358.902] (II) modeset(0): Modeline "800x600"x85.0 114.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (106.2 kHz d)
[ 358.902] (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 358.902] (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 358.902] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
[ 358.902] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 358.902] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 358.902] (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x512"x85.0 78.75 640 672 752 864 512 512 514 536 doublescan +hsync +vsync (91.1 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x480"x144.0 354.73 640 1968 2000 2180 480 1083 1088 1130 +hsync -vsync (162.7 kHz e)
[ 358.902] (II) modeset(0): Modeline "640x480"x85.1 74.25 640 672 752 864 480 480 482 505 doublescan +hsync +vsync (85.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 358.902] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 358.902] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 358.902] (II) modeset(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "512x384"x85.0 47.25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync (68.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 358.902] (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 358.902] (II) modeset(0): Modeline "512x384i"x87.1 22.45 512 516 604 632 384 384 388 408 interlace doublescan +hsync +vsync (35.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "400x300"x85.3 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync (53.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 358.902] (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 358.902] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 358.902] (II) modeset(0): Modeline "320x240"x85.2 18.00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync (43.3 kHz d)
[ 358.902] (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 358.902] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 358.902] (II) modeset(0): Modeline "360x200"x85.0 17.75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync (37.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "320x200"x85.3 15.75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync (37.9 kHz d)
[ 358.902] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 358.902] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 358.902] (II) modeset(0): Modeline "320x175"x85.3 15.75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync (37.9 kHz d)
[ 358.902] (II) modeset(0): EDID for output HDMI-1
[ 358.902] (II) modeset(0): Output eDP-1 connected
[ 358.902] (II) modeset(0): Output HDMI-1 disconnected
[ 358.902] (II) modeset(0): Using exact sizes for initial modes
[ 358.902] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[ 358.902] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 358.902] (==) modeset(0): DPI set to (96, 96)
[ 358.902] (II) Loading sub module "fb"
[ 358.902] (II) LoadModule: "fb"
[ 358.902] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 358.902] (II) Module fb: vendor="X.Org Foundation"
[ 358.902] compiled for 1.20.11, module version = 1.0.0
[ 358.902] ABI class: X.Org ANSI C Emulation, version 0.4
[ 358.913] (==) modeset(0): Backing store enabled
[ 358.913] (==) modeset(0): Silken mouse disabled
[ 358.913] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 358.913] (==) modeset(0): DPMS enabled
[ 358.913] (WW) modeset(0): Option "PrimaryGPU" is not used
[ 358.913] (WW) modeset(0): Option "DRI" is not used
[ 358.913] (II) modeset(0): [DRI2] Setup complete
[ 358.913] (II) modeset(0): [DRI2] DRI driver: radeonsi
[ 358.913] (II) modeset(0): [DRI2] VDPAU driver: radeonsi
[ 358.913] (II) Initializing extension Generic Event Extension
[ 358.913] (II) Initializing extension SHAPE
[ 358.913] (II) Initializing extension MIT-SHM
[ 358.913] (II) Initializing extension XInputExtension
[ 358.913] (II) Initializing extension XTEST
[ 358.913] (II) Initializing extension BIG-REQUESTS
[ 358.913] (II) Initializing extension SYNC
[ 358.913] (II) Initializing extension XKEYBOARD
[ 358.913] (II) Initializing extension XC-MISC
[ 358.913] (II) Initializing extension SECURITY
[ 358.913] (II) Initializing extension XFIXES
[ 358.914] (II) Initializing extension RENDER
[ 358.914] (II) Initializing extension RANDR
[ 358.914] (II) Initializing extension COMPOSITE
[ 358.914] (II) Initializing extension DAMAGE
[ 358.914] (II) Initializing extension MIT-SCREEN-SAVER
[ 358.914] (II) Initializing extension DOUBLE-BUFFER
[ 358.914] (II) Initializing extension RECORD
[ 358.914] (II) Initializing extension DPMS
[ 358.914] (II) Initializing extension Present
[ 358.914] (II) Initializing extension DRI3
[ 358.914] (II) Initializing extension X-Resource
[ 358.914] (II) Initializing extension XVideo
[ 358.914] (II) Initializing extension XVideo-MotionCompensation
[ 358.914] (II) Initializing extension GLX
[ 358.917] (II) AIGLX: Loaded and initialized radeonsi
[ 358.917] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 358.917] (II) Initializing extension XFree86-VidModeExtension
[ 358.917] (II) Initializing extension XFree86-DGA
[ 358.917] (II) Initializing extension XFree86-DRI
[ 358.917] (II) Initializing extension DRI2
[ 358.917] (II) modeset(0): Damage tracking initialized
[ 358.917] (II) modeset(0): Setting screen physical size to 508 x 285
[ 358.924] (EE) modeset(0): Failed to make import prime FD as pixmap: 22
[ 358.941] (II) config/udev: Adding input device Asus Wireless Radio Control (/dev/input/event4)
[ 358.941] (**) Asus Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[ 358.941] (**) Asus Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[ 358.941] (**) Asus Wireless Radio Control: Applying InputClass "system-keyboard"
[ 358.941] (II) LoadModule: "libinput"
[ 358.941] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 358.942] (II) Module libinput: vendor="X.Org Foundation"
[ 358.942] compiled for 1.20.10, module version = 1.0.0
[ 358.942] Module class: X.Org XInput Driver
[ 358.942] ABI class: X.Org XInput driver, version 24.1
[ 358.942] (II) Using input driver 'libinput' for 'Asus Wireless Radio Control'
[ 358.942] (**) Asus Wireless Radio Control: always reports core events
[ 358.942] (**) Option "Device" "/dev/input/event4"
[ 358.942] (**) Option "_source" "server/udev"
[ 358.943] (II) event4 - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[ 358.943] (II) event4 - Asus Wireless Radio Control: device is a keyboard
[ 358.943] (II) event4 - Asus Wireless Radio Control: device removed
[ 359.068] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input4/event4"
[ 359.069] (II) XINPUT: Adding extended input device "Asus Wireless Radio Control" (type: KEYBOARD, id 6)
[ 359.069] (**) Option "xkb_layout" "us"
[ 359.069] (II) event4 - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[ 359.069] (II) event4 - Asus Wireless Radio Control: device is a keyboard
[ 359.070] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[ 359.070] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 359.070] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 359.070] (**) Video Bus: Applying InputClass "system-keyboard"
[ 359.070] (II) Using input driver 'libinput' for 'Video Bus'
[ 359.070] (**) Video Bus: always reports core events
[ 359.070] (**) Option "Device" "/dev/input/event5"
[ 359.070] (**) Option "_source" "server/udev"
[ 359.070] (II) event5 - Video Bus: is tagged by udev as: Keyboard
[ 359.070] (II) event5 - Video Bus: device is a keyboard
[ 359.070] (II) event5 - Video Bus: device removed
[ 359.109] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input5/event5"
[ 359.109] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 359.109] (**) Option "xkb_layout" "us"
[ 359.109] (II) event5 - Video Bus: is tagged by udev as: Keyboard
[ 359.110] (II) event5 - Video Bus: device is a keyboard
[ 359.110] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[ 359.110] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 359.110] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 359.110] (**) Video Bus: Applying InputClass "system-keyboard"
[ 359.110] (II) Using input driver 'libinput' for 'Video Bus'
[ 359.110] (**) Video Bus: always reports core events
[ 359.110] (**) Option "Device" "/dev/input/event6"
[ 359.110] (**) Option "_source" "server/udev"
[ 359.110] (II) event6 - Video Bus: is tagged by udev as: Keyboard
[ 359.110] (II) event6 - Video Bus: device is a keyboard
[ 359.110] (II) event6 - Video Bus: device removed
[ 359.149] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/LNXVIDEO:01/input/input6/event6"
[ 359.149] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 359.149] (**) Option "xkb_layout" "us"
[ 359.149] (II) event6 - Video Bus: is tagged by udev as: Keyboard
[ 359.150] (II) event6 - Video Bus: device is a keyboard
[ 359.150] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 359.150] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 359.150] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 359.150] (**) Power Button: Applying InputClass "system-keyboard"
[ 359.150] (II) Using input driver 'libinput' for 'Power Button'
[ 359.150] (**) Power Button: always reports core events
[ 359.150] (**) Option "Device" "/dev/input/event0"
[ 359.150] (**) Option "_source" "server/udev"
[ 359.150] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 359.150] (II) event0 - Power Button: device is a keyboard
[ 359.150] (II) event0 - Power Button: device removed
[ 359.209] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 359.209] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 359.209] (**) Option "xkb_layout" "us"
[ 359.209] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 359.209] (II) event0 - Power Button: device is a keyboard
[ 359.210] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[ 359.210] (II) No input driver specified, ignoring this device.
[ 359.210] (II) This device may have been added with another device file.
[ 359.210] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 359.210] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 359.210] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 359.210] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 359.210] (II) Using input driver 'libinput' for 'Sleep Button'
[ 359.210] (**) Sleep Button: always reports core events
[ 359.210] (**) Option "Device" "/dev/input/event1"
[ 359.210] (**) Option "_source" "server/udev"
[ 359.210] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 359.210] (II) event1 - Sleep Button: device is a keyboard
[ 359.210] (II) event1 - Sleep Button: device removed
[ 359.249] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[ 359.249] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 359.249] (**) Option "xkb_layout" "us"
[ 359.249] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 359.249] (II) event1 - Sleep Button: device is a keyboard
[ 359.250] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event10)
[ 359.250] (II) No input driver specified, ignoring this device.
[ 359.250] (II) This device may have been added with another device file.
[ 359.250] (II) config/udev: Adding input device USB2.0 HD UVC WebCam: USB2.0 HD (/dev/input/event12)
[ 359.250] (**) USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "evdev keyboard catchall"
[ 359.250] (**) USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "libinput keyboard catchall"
[ 359.250] (**) USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "system-keyboard"
[ 359.250] (II) Using input driver 'libinput' for 'USB2.0 HD UVC WebCam: USB2.0 HD'
[ 359.250] (**) USB2.0 HD UVC WebCam: USB2.0 HD: always reports core events
[ 359.250] (**) Option "Device" "/dev/input/event12"
[ 359.250] (**) Option "_source" "server/udev"
[ 359.250] (II) event12 - USB2.0 HD UVC WebCam: USB2.0 HD: is tagged by udev as: Keyboard
[ 359.250] (II) event12 - USB2.0 HD UVC WebCam: USB2.0 HD: device is a keyboard
[ 359.250] (II) event12 - USB2.0 HD UVC WebCam: USB2.0 HD: device removed
[ 359.328] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-4/1-4:1.0/input/input13/event12"
[ 359.329] (II) XINPUT: Adding extended input device "USB2.0 HD UVC WebCam: USB2.0 HD" (type: KEYBOARD, id 11)
[ 359.329] (**) Option "xkb_layout" "us"
[ 359.330] (II) event12 - USB2.0 HD UVC WebCam: USB2.0 HD: is tagged by udev as: Keyboard
[ 359.330] (II) event12 - USB2.0 HD UVC WebCam: USB2.0 HD: device is a keyboard
[ 359.330] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event11)
[ 359.330] (II) No input driver specified, ignoring this device.
[ 359.330] (II) This device may have been added with another device file.
[ 359.330] (II) config/udev: Adding input device ELAN1203:00 04F3:307A Mouse (/dev/input/event9)
[ 359.330] (**) ELAN1203:00 04F3:307A Mouse: Applying InputClass "evdev pointer catchall"
[ 359.330] (**) ELAN1203:00 04F3:307A Mouse: Applying InputClass "libinput pointer catchall"
[ 359.330] (II) Using input driver 'libinput' for 'ELAN1203:00 04F3:307A Mouse'
[ 359.330] (**) ELAN1203:00 04F3:307A Mouse: always reports core events
[ 359.330] (**) Option "Device" "/dev/input/event9"
[ 359.330] (**) Option "_source" "server/udev"
[ 359.331] (II) event9 - ELAN1203:00 04F3:307A Mouse: is tagged by udev as: Mouse Pointingstick
[ 359.331] (II) event9 - ELAN1203:00 04F3:307A Mouse: device is a pointer
[ 359.331] (II) event9 - ELAN1203:00 04F3:307A Mouse: device removed
[ 359.408] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-ELAN1203:00/0018:04F3:307A.0001/input/input14/event9"
[ 359.408] (II) XINPUT: Adding extended input device "ELAN1203:00 04F3:307A Mouse" (type: MOUSE, id 12)
[ 359.409] (**) Option "AccelerationScheme" "none"
[ 359.409] (**) ELAN1203:00 04F3:307A Mouse: (accel) selected scheme none/0
[ 359.409] (**) ELAN1203:00 04F3:307A Mouse: (accel) acceleration factor: 2.000
[ 359.409] (**) ELAN1203:00 04F3:307A Mouse: (accel) acceleration threshold: 4
[ 359.409] (II) event9 - ELAN1203:00 04F3:307A Mouse: is tagged by udev as: Mouse Pointingstick
[ 359.410] (II) event9 - ELAN1203:00 04F3:307A Mouse: device is a pointer
[ 359.410] (II) config/udev: Adding input device ELAN1203:00 04F3:307A Mouse (/dev/input/mouse0)
[ 359.410] (II) No input driver specified, ignoring this device.
[ 359.410] (II) This device may have been added with another device file.
[ 359.410] (II) config/udev: Adding input device ELAN1203:00 04F3:307A Touchpad (/dev/input/event13)
[ 359.410] (**) ELAN1203:00 04F3:307A Touchpad: Applying InputClass "evdev touchpad catchall"
[ 359.410] (**) ELAN1203:00 04F3:307A Touchpad: Applying InputClass "libinput touchpad catchall"
[ 359.410] (**) ELAN1203:00 04F3:307A Touchpad: Applying InputClass "touchpad"
[ 359.410] (II) Using input driver 'libinput' for 'ELAN1203:00 04F3:307A Touchpad'
[ 359.410] (**) ELAN1203:00 04F3:307A Touchpad: always reports core events
[ 359.410] (**) Option "Device" "/dev/input/event13"
[ 359.410] (**) Option "_source" "server/udev"
[ 359.411] (II) event13 - ELAN1203:00 04F3:307A Touchpad: is tagged by udev as: Touchpad
[ 359.411] (II) event13 - ELAN1203:00 04F3:307A Touchpad: device is a touchpad
[ 359.411] (II) event13 - ELAN1203:00 04F3:307A Touchpad: device removed
[ 359.518] (**) Option "Tapping" "on"
[ 359.519] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-ELAN1203:00/0018:04F3:307A.0001/input/input15/event13"
[ 359.519] (II) XINPUT: Adding extended input device "ELAN1203:00 04F3:307A Touchpad" (type: TOUCHPAD, id 13)
[ 359.519] (**) Option "AccelerationScheme" "none"
[ 359.519] (**) ELAN1203:00 04F3:307A Touchpad: (accel) selected scheme none/0
[ 359.519] (**) ELAN1203:00 04F3:307A Touchpad: (accel) acceleration factor: 2.000
[ 359.519] (**) ELAN1203:00 04F3:307A Touchpad: (accel) acceleration threshold: 4
[ 359.520] (II) event13 - ELAN1203:00 04F3:307A Touchpad: is tagged by udev as: Touchpad
[ 359.520] (II) event13 - ELAN1203:00 04F3:307A Touchpad: device is a touchpad
[ 359.521] (II) config/udev: Adding input device ELAN1203:00 04F3:307A Touchpad (/dev/input/mouse1)
[ 359.521] (**) ELAN1203:00 04F3:307A Touchpad: Applying InputClass "touchpad"
[ 359.521] (II) Using input driver 'libinput' for 'ELAN1203:00 04F3:307A Touchpad'
[ 359.521] (**) ELAN1203:00 04F3:307A Touchpad: always reports core events
[ 359.521] (**) Option "Device" "/dev/input/mouse1"
[ 359.521] (**) Option "_source" "server/udev"
[ 359.598] (II) mouse1 - not using input device '/dev/input/mouse1'.
[ 359.599] (EE) libinput: ELAN1203:00 04F3:307A Touchpad: Failed to create a device for /dev/input/mouse1
[ 359.599] (EE) PreInit returned 2 for "ELAN1203:00 04F3:307A Touchpad"
[ 359.599] (II) UnloadModule: "libinput"
[ 359.599] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event8)
[ 359.599] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 359.599] (**) Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 359.599] (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
[ 359.599] (II) Using input driver 'libinput' for 'Asus WMI hotkeys'
[ 359.599] (**) Asus WMI hotkeys: always reports core events
[ 359.599] (**) Option "Device" "/dev/input/event8"
[ 359.599] (**) Option "_source" "server/udev"
[ 359.599] (II) event8 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 359.600] (II) event8 - Asus WMI hotkeys: device is a keyboard
[ 359.600] (II) event8 - Asus WMI hotkeys: device removed
[ 359.639] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input12/event8"
[ 359.639] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 14)
[ 359.639] (**) Option "xkb_layout" "us"
[ 359.639] (II) event8 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 359.639] (II) event8 - Asus WMI hotkeys: device is a keyboard
[ 359.640] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 359.640] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 359.640] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 359.640] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 359.640] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 359.640] (**) AT Translated Set 2 keyboard: always reports core events
[ 359.640] (**) Option "Device" "/dev/input/event3"
[ 359.640] (**) Option "_source" "server/udev"
[ 359.640] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 359.640] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 359.641] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 359.709] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 359.709] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 15)
[ 359.709] (**) Option "xkb_layout" "us"
[ 359.710] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 359.710] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 359.710] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 359.710] (II) No input driver specified, ignoring this device.
[ 359.710] (II) This device may have been added with another device file.
[ 362.788] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 363.434] (II) modeset(0): EDID vendor "NCP", prod id 77
[ 363.434] (II) modeset(0): Using EDID range info for horizontal sync
[ 363.434] (II) modeset(0): Using EDID range info for vertical refresh
[ 363.434] (II) modeset(0): Printing DDC gathered Modelines:
[ 363.434] (II) modeset(0): Modeline "1920x1080"x0.0 354.73 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (162.7 kHz eP)
[ 363.434] (II) modeset(0): Modeline "1920x1080"x0.0 147.81 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (67.8 kHz e)
[ 363.605] (II) modeset(0): EDID vendor "NCP", prod id 77
[ 363.605] (II) modeset(0): Using hsync ranges from config file
[ 363.605] (II) modeset(0): Using vrefresh ranges from config file
[ 363.605] (II) modeset(0): Printing DDC gathered Modelines:
[ 363.605] (II) modeset(0): Modeline "1920x1080"x0.0 354.73 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (162.7 kHz eP)
[ 363.605] (II) modeset(0): Modeline "1920x1080"x0.0 147.81 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (67.8 kHz e)
[ 2053.682] (EE) event13 - ELAN1203:00 04F3:307A Touchpad: kernel bug: Touch jump detected and discarded.
See https://wayland.freedesktop.org/libinput/doc/1.17.1/touchpad-jumping-cursors.html for details
[ 2182.775] (EE) event13 - ELAN1203:00 04F3:307A Touchpad: kernel bug: Touch jump detected and discarded.
[ 2187.117] (II) modeset(0): EDID vendor "NCP", prod id 77
[ 2187.117] (II) modeset(0): Using hsync ranges from config file
[ 2187.117] (II) modeset(0): Using vrefresh ranges from config file
[ 2187.117] (II) modeset(0): Printing DDC gathered Modelines:
[ 2187.117] (II) modeset(0): Modeline "1920x1080"x0.0 354.73 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (162.7 kHz eP)
[ 2187.117] (II) modeset(0): Modeline "1920x1080"x0.0 147.81 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (67.8 kHz e)
[ 2308.403] (II) modeset(0): EDID vendor "NCP", prod id 77
[ 2308.403] (II) modeset(0): Using hsync ranges from config file
[ 2308.403] (II) modeset(0): Using vrefresh ranges from config file
[ 2308.403] (II) modeset(0): Printing DDC gathered Modelines:
[ 2308.403] (II) modeset(0): Modeline "1920x1080"x0.0 354.73 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (162.7 kHz eP)
[ 2308.403] (II) modeset(0): Modeline "1920x1080"x0.0 147.81 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (67.8 kHz e)
[ 2311.881] (EE) event13 - ELAN1203:00 04F3:307A Touchpad: kernel bug: Touch jump detected and discarded.
[ 5240.163] (II) modeset(0): EDID vendor "NCP", prod id 77
[ 5240.163] (II) modeset(0): Using hsync ranges from config file
[ 5240.163] (II) modeset(0): Using vrefresh ranges from config file
[ 5240.163] (II) modeset(0): Printing DDC gathered Modelines:
[ 5240.163] (II) modeset(0): Modeline "1920x1080"x0.0 354.73 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (162.7 kHz eP)
[ 5240.164] (II) modeset(0): Modeline "1920x1080"x0.0 147.81 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (67.8 kHz e)
[ 5253.855] (II) modeset(0): EDID vendor "NCP", prod id 77
[ 5253.855] (II) modeset(0): Using hsync ranges from config file
[ 5253.855] (II) modeset(0): Using vrefresh ranges from config file
[ 5253.855] (II) modeset(0): Printing DDC gathered Modelines:
[ 5253.855] (II) modeset(0): Modeline "1920x1080"x0.0 354.73 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (162.7 kHz eP)
[ 5253.855] (II) modeset(0): Modeline "1920x1080"x0.0 147.81 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (67.8 kHz e)
[ 5253.856] (II) modeset(0): EDID vendor "NCP", prod id 77
[ 5253.856] (II) modeset(0): Using hsync ranges from config file
[ 5253.856] (II) modeset(0): Using vrefresh ranges from config file
[ 5253.856] (II) modeset(0): Printing DDC gathered Modelines:
[ 5253.856] (II) modeset(0): Modeline "1920x1080"x0.0 354.73 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (162.7 kHz eP)
[ 5253.856] (II) modeset(0): Modeline "1920x1080"x0.0 147.81 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (67.8 kHz e)
Can you post the output of
sudo systool -vm nvidia_drm
ls /dev/dri/
head -n999 /etc/X11/xorg.conf.d/* /etc/X11/xorg.conf`
Error opening module nvidia_drm
> ls /dev/dri/
by-path card0 renderD128
==> /etc/X11/xorg.conf.d/00-keyboard.conf <==
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "us"
EndSection
==> /etc/X11/xorg.conf.d/10-optimus-manager.conf <==
Section "Device"
Identifier "integrated"
Driver "modesetting"
BusID "PCI:5:0:0"
Option "DRI" "3"
EndSection
==> /etc/X11/xorg.conf.d/30-touchpad.conf <==
Identifier "touchpad"
Driver "libinput"
MatchIsTouchpad "on"
EndSection
==> /etc/X11/xorg.conf.d/90-mhwd.conf <==
Section "Module"
Load "modesetting"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
Option "AllowEmptyInitialConfiguration"
EndSection
head: „'/etc/X11/xorg.conf'“ cannot be open for reading: No such file or directory
You have optimus-manager
? In that case run optimus-manager --switch hybrid
, and prime-run
should work after that.
Nope, it doesn’t work.
ptimus-manager --switch hybrid,
ERROR: a GPU setup was initiated but Xorg post-start hook did not run.
Log at /var/log/optimus-manager/switch/switch-20210424T204736.log
If your login manager is GDM, make sure to follow those instructions:
https://github.com/Askannz/optimus-manager#important--gnome-and-gdm-users
If your display manager is neither GDM, SDDM nor LightDM, or if you don't use one, read the wiki:
https://github.com/Askannz/optimus-manager/wiki/FAQ,-common-issues,-troubleshooting
Cannot execute command because of previous errors.
And this is what the log says:
>cat /var/log/optimus-manager/switch/switch-20210424T204736.log
[9] INFO: # Xorg pre-start hook
[9] INFO: Previous state was: {'type': 'pending_pre_xorg_start', 'requested_mode': 'integrated', 'current_mode': None}
[9] INFO: Requested mode is: integrated
[201] INFO: Available modules: ['nouveau', 'bbswitch', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
[201] INFO: Unloading modules ['nvidia_drm', 'nvidia_modeset', 'nvidia_uvm', 'nvidia'] (if loaded)
[209] INFO: switching=none, nothing to do
[225] INFO: Writing to /etc/X11/xorg.conf.d/10-optimus-manager.conf
[225] INFO: Writing state {'type': 'pending_post_xorg_start', 'switch_id': '20210424T204736', 'requested_mode': 'integrated'}
[226] INFO: Xorg pre-start hook completed successfully.
Could it be something related to the kernel? I’m with 5.10.30-1-MANJARO #1 .
What’s the version (pacman -Q optimus-manager
Please try the following: remove 10-optimus-manager.conf
and 90-mhwd.conf
from /etc/X11/xorg.conf.d/
, and then reboot.
Well, it didn’t work. I removed the conf files, but I still get
Log at /var/log/optimus-manager/switch/switch-20210425T001059.log
and even though I removed it, I still get 10-optimus-manager.conf
cat /etc/X11/xorg.conf.d/10-optimus-manager.conf
Section "Device"
BusID "PCI:5:0:0"
Option "DRI" "3"
EndSection
Have you followed this when you installed optimus-manager
Because optimus-manager
recreates it. What’s in /etc/optimus-manager/optimus-manager.conf
Hi, thanks for the help. So optimus-manager.conf is empty. But I noticed your recommendation and did edit /etc/sddm.conf to comment out DisplayCommand
and DisplayStopCommand
and now I can switch to “nvidia”. So really thanks for helping me with this.
However, I noticed that when I use optimus-manager --switch hybrid and do prime-run glxspheres64, konsole claims I’m running the nvidia, but the FPS do not correspond to the Nvidia. Also in the vice versa, when I have switched to nvidia and do prime-run, I see higher FPS for the amdgpu that what I expect ( for example 200 instead of 145). Is this normal beahaviour?
When I’m in hybrid and start the nvidia with prime-run, nvidia-smi says it’s using the nvidia for the glxspheres64, but the FPS are 10 times lower than when I run on nvidia.
Well, I have never really analyzed the performance. As long as it’s enough for you, I wouldn’t bother messing with things. In any case, please open an new thread if you experience subpar performance.
