Hi,
I am on Kernel 6.3 and KDE. I would like to be able to switch the auto screen rotation ON/OFF on demand.
Switching OFF is rather straight forward via:
sudo systemctl stop iio-sensor-proxy
However when reversing the previous command with:
sudo systemctl start iio-sensor-proxy
auto screen rotation is not working anymore. The accelerometer however is working correctly, as I get from monitor-sensors:
Waiting for iio-sensor-proxy to appear
+++ iio-sensor-proxy appeared
=== Has accelerometer (orientation: undefined)
=== No ambient light sensor
=== No proximity sensor
Accelerometer orientation changed: normal
Accelerometer orientation changed: left-up
Accelerometer orientation changed: right-up
And also journalctl -b | grep iio confirms the correct activation:
Mai 19 15:08:59 LaptopSieAlleZuKnechten polkitd[868]: Operator of unix-session:2 successfully authenticated as unix-user:johnny to gain TEMPORARY authorization for action o
rg.freedesktop.systemd1.manage-units for system-bus-name::1.768 [systemctl start iio-sensor-proxy] (owned by unix-user:johnny)
Mai 19 15:08:59 LaptopSieAlleZuKnechten audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=iio-sensor-proxy comm="systemd" exe="/usr/lib/systemd
/systemd" hostname=? addr=? terminal=? res=success'
Mai 19 15:08:59 LaptopSieAlleZuKnechten kernel: audit: type=1130 audit(1684501739.612:202): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=iio-sensor-proxy comm="sy
stemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
systemctl status iio-sensor-proxy :
● iio-sensor-proxy.service - IIO Sensor Proxy service
Loaded: loaded (/usr/lib/systemd/system/iio-sensor-proxy.service; static)
Active: active (running) since Fri 2023-05-19 15:08:59 CEST; 7min ago
Main PID: 35709 (iio-sensor-prox)
Tasks: 4 (limit: 17585)
Memory: 5.3M
CPU: 26ms
CGroup: /system.slice/iio-sensor-proxy.service
└─35709 /usr/lib/iio-sensor-proxy
Mai 19 15:08:59 LaptopSieAlleZuKnechten systemd[1]: Starting IIO Sensor Proxy service...
Mai 19 15:08:59 LaptopSieAlleZuKnechten systemd[1]: Started IIO Sensor Proxy service.
What am I missing?
Thanks and BR.
