I switched to X, I wanted to mess with gamma & thought this would be simple. Anyway it is just a black screen with the curser now. I can not do anything. How can I switch that boot back to Wayland from here, so I have that one working again.
You don’t even have a login screen?
The display manager: SDDM
Did you set up automatic login?
How did you switch to X ?
That can normally be selected from the login screen.
Sorry, auto login is on. I went into KDE settings & switches to X in Login screen > Behavior So that one I switched to X, that will always be messed up right? I should just updte this snapshot.
I do not know the answer to that.
Probably yes, if that is the only way to be able to revert that choice you made without a GUI.
Which it is probably not - but:
Aren’t such things what snapshots are for?
I just have no experience with using those and consequently will not blindly recommend and answer: yes, do that.
To disable Autologin you can edit the ssdm con file:
sudo nano /etc/sddm.conf
Comment the lines with autologin, users and session:
# [Autologin]
# User=edward78
# Session=plasma.desktop
Save and restart.
Nevermind, I got it.
Then write how, so that the topic has some use for other people with the same problem.
In the absence of confirmation or information to the contrary, I hereby mark the most obvious solution at post #4.
KDE Plasma Version: 6.3.6
KDE Frameworks Version: 6.17.0
Qt Version: 6.9.1
Kernel Version: 6.12.41-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 5800X 8-Core Processor
Memory: 31.3 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 3060 Ti
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: B550I AORUS PRO AX
Open source Nvidia driver. Sorryif you wamted more.
