Hello,
I recently switched to pipewire from pulseaudio. I did it by installing manjaro-pipewire meta package.
I chose wireplumber as session manager.
I think installation uninstalled lot of pulseaudio stuff and now pavucontrol and pactl doesn’t work
pavucontrol says no pulseaudio server which is expected because pulseaudio is just get uninstalled in process. Also pactl info gives error pa_context_connect() failed: Connection refused
I have also installed pipewire-pulse and pipewire-alsa packages. and rebooted multiple times and checked that pipewire services are running in user mode.
What is correct way now to switch between different audio target, control volume etctetc?
Also keyboard soundcontrol buttons stopped working.
I DO have sound from spotify app and from brave/chrome browsers I just cannot control too much it.
I started whole process because suddently sounds stopped working and I get them back after this switch.
I have bluetooth headset and external speakers plugged in to stereo output of my laptop.
$ systemctl --user status pipewire.*
● pipewire.socket - PipeWire Multimedia System Socket
Loaded: loaded (/usr/lib/systemd/user/pipewire.socket; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-01-27 14:08:04 EET; 40min left
Until: Thu 2022-01-27 14:08:04 EET; 40min left
Triggers: ● pipewire.service
Listen: /run/user/1000/pipewire-0 (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire.socket
tammi 27 14:08:04 kertzi-laptoppi systemd[1172]: Listening on PipeWire Multimedia System Socket.
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; vendor preset: enabled)
TriggeredBy: ● pipewire.socket
Main PID: 1180 (pipewire)
Tasks: 2 (limit: 38092)
Memory: 7.8M
CPU: 54ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─1180 /usr/bin/pipewire
tammi 27 14:08:04 kertzi-laptoppi systemd[1172]: Started PipeWire Multimedia Service.
$ systemctl --user status pipewire-pulse.*
● pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-01-27 14:08:04 EET; 39min left
TriggeredBy: ● pipewire-pulse.socket
Main PID: 1182 (pipewire-pulse)
Memory: 1.6M
CPU: 12ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
└─1182 /usr/bin/pipewire-pulse
tammi 27 14:08:04 kertzi-laptoppi systemd[1172]: Started PipeWire PulseAudio.
● pipewire-pulse.socket - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.socket; enabled; vendor preset: enabled)
Until: Thu 2022-01-27 14:08:04 EET; 39min left
Triggers: ● pipewire-pulse.service
Listen: /run/user/1000/pulse/native (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire-pulse.socket
tammi 27 14:08:04 kertzi-laptoppi systemd[1172]: Listening on PipeWire PulseAudio.
$ systemctl --user status wireplumber.*
● wireplumber.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; vendor preset: enabled)
Main PID: 1181 (wireplumber)
Tasks: 4 (limit: 38092)
Memory: 23.8M
CPU: 278ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
└─1181 /usr/bin/wireplumber
tammi 27 14:08:04 kertzi-laptoppi systemd[1172]: Started Multimedia Service Session Manager.
tammi 27 14:08:04 kertzi-laptoppi wireplumber[1181]: Failed to set scheduler settings: Operation not permitted
tammi 27 13:14:14 kertzi-laptoppi wireplumber[1181]: unknown AT+IPHONEACCEV key:2 value:0
tammi 27 13:14:14 kertzi-laptoppi wireplumber[1181]: Failed to register battery provider. Error: org.freedesktop.DBus.Error.UnknownMethod
tammi 27 13:14:14 kertzi-laptoppi wireplumber[1181]: BlueZ Battery Provider is not available, won't retry to register it. Make sure you are
Output of inxi -Fxxxx
Host: kertzi-laptoppi Kernel: 5.16.2-1-MANJARO x86_64 bits: 64
compiler: gcc v: 11.1.0 Desktop: N/A wm: xfwm 4.16.1 vt: 7
Type: Laptop System: LENOVO product: 20NR001MMX v: ThinkPad L390
Mobo: LENOVO model: 20NR001MMX v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: R10ET43W (1.28 )
date: 12/27/2019
ID-1: BAT0 charge: 41.6 Wh (100.0%) condition: 41.6/45.7 Wh (90.9%)
volts: 12.3 min: 11.1 model: Celxpert 01AV483 type: Li-poly serial: 3615
status: Full cycles: 120
Info: quad core model: Intel Core i7-8565U bits: 64 type: MT MCP
smt: enabled arch: Whiskey Lake rev: B cache: L1: 256 KiB L2: 1024 KiB
L3: 8 MiB
Speed (MHz): avg: 800 min/max: 400/4600 cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 bogomips: 32012
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Sonix QHD Webcam type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2.2:6 chip-ID: 3c45:6366 class-ID: 0102 serial: SN0001
Device-3: Lite-On Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 04ca:7070 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: intel resolution: 1: 1920x1080~60Hz 2: 3840x1080~60Hz s-dpi: 96
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9dc8
class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
IF: wlp0s20f3 state: up mac: 48:89:e7:88:71:9c
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15be class-ID: 0200
IF: enp0s31f6 state: down mac: 48:2a:e3:42:e9:59
IF-ID-1: docker0 state: down mac: 02:42:67:ff:5c:6d
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:7 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 476.94 GiB used: 295.33 GiB (61.9%)
ID-1: /dev/nvme0n1 vendor: Western Digital
model: PC SN720 SDAQNTW-512G-1001 size: 476.94 GiB speed: 31.6 Gb/s
lanes: 4 type: SSD serial: 184257801024 rev: 10190101 temp: 44.9 C
scheme: GPT
ID-1: / size: 345.75 GiB used: 295.3 GiB (85.4%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 256 MiB used: 29 MiB (11.3%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 38 GiB used: 0 KiB (0.0%) priority: -2
file: /var/swap/swapfile
System Temperatures: cpu: 17.0 C pch: 47.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 281 Uptime: 14m wakeups: 7 Memory: 31.02 GiB
used: 3.72 GiB (12.0%) Init: systemd v: 250 Compilers: gcc: 11.1.0
clang: 13.0.0 Packages: 1573 pacman: 1565 snap: 8 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.12
Thanks for your help and time in advice!
