Hi, first post. Hope I’ve included the correct information, I’m tryin!
I just switched my nvidia 1070 to a Radeon 6650 XT after struggling with nvidia for years. The final straw was my nvidia-settings disappeared from my system this morning and I couldn’t configure my screens to properly do my work. I was writing a post earlier trying to troubleshoot my nvidia problems but ended up throwing in the towel and picking up this 6650 on a good deal.
Everything seems great with the new card except my 2nd monitor (out of 3) is stuck at a 640*480 resolution. The monitor had no problem being recognized as a 1440p / 140hz screen when using the nvidia card with the same cable. It also has no problem detecting if I boot into windows with my current hardware configuration / cables.
The screen in question is hooked up over Display Port. I don’t remember the exact version of the cable, but I know I had to buy a good one to get full resolution / refresh rate out of the monitor.
I am by no means a linux expert or power user but I am trying to learn and know enough to be dangerous.
I have restarted the PC, monitor, changed physical ports, all the stupid stuff.
Here is what I’ve read so far trying to troubleshoot:
- Configure Graphics Cards - Manjaro (got my drivers sorted)
- xrandr - ArchWiki (I haven’t tried anything here, just been reading about it)
- VGA monitor resolution stuck at 640x480 - #4 by aafsmarak (not applicable from what I can tell)
I think the problem is with the EDID not making it into Manjaro. This might not be the correct terminology, but the monitor does detect and work properly in Windows.
Here is my inxi -Fazy:
Kernel: 6.1.22-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=c6eb747c-9145-49f6-899d-55e9560ef280 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: MAXIMUS VIII HERO ALPHA v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 3504
date: 06/30/2017
ID-1: hidpp_battery_0 charge: 90% condition: N/A volts: 4.1 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
status: discharging
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3350 high: 4000 min/max: 800/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1200 2: 4000 3: 4000
4: 4000 5: 1600 6: 4000 7: 4000 8: 4000 bogomips: 64026
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S] vendor: ASRock
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-2,HDMI-A-1 empty: DP-3 bus-ID: 03:00.0 chip-ID: 1002:73ef
class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4279x1920 s-dpi: 96 s-size: 1132x508mm (44.57x20.00")
s-diag: 1241mm (48.85")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: bottom-c
model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2021 res: 2560x1440
hz: 144 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-2: DP-2 mapped: DisplayPort-1 pos: bottom-r res: 640x480 hz: 60
size: N/A modes: 640x480
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: primary,top-left model: BKY1561
serial: <filter> built: 2019 res: 1080x1920 hz: 60 dpi: 141 gamma: 1.2
size: 194x345mm (7.64x13.58") diag: 397mm (15.6") ratio: 3:2, 16:10 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: AMD Radeon RX 6650 XT (navi23
LLVM 15.0.7 DRM 3.49 6.1.22-1-MANJARO) direct-render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 3-1:2 v: kernel chip-ID: 19f7:000a
bus-ID: 00:1f.3 class-ID: 0300 chip-ID: 8086:a170 serial: <filter>
class-ID: 0403
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-3: RODE Microphones AI-1 type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: Logitech Logitech G PRO X Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1.3:5 chip-ID: 046d:0aaa
class-ID: 0300 serial: <filter>
API: ALSA v: k6.1.22-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-3: PipeWire v: 0.3.67 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: ASUSTeK driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 0c:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 50.0 C
IF: wlp12s0 state: down mac: <filter>
Device-1: ASUSTek Qualcomm Bluetooth 4.1 type: USB driver: btusb v: 0.8
bus-ID: 1-9:3 chip-ID: 0b05:1825 class-ID: e001
Local Storage: total: 2.95 TiB used: 74.95 GiB (2.5%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
rev: 4B2QEXM7 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2CW240A3
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 400i scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WDBNCE0010PNC
type: SSD serial: <filter> rev: 40RL scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 74.95 GiB (4.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 32.0 C mobo: N/A gpu: amdgpu temp: 54.0 C
mem: 56.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 276 Uptime: 30m wakeups: 2 Memory: 62.74 GiB used: 3.6 GiB (5.7%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 clang: 15.0.7 Packages: 1788 pm: pacman pkgs: 1747 libs: 386
tools: pamac,yay pm: flatpak pkgs: 24 pm: snap pkgs: 17 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
Here is my xrandr --props
DisplayPort-0 connected 2560x1440+1080+97 (normal left inverted right x axis y axis) 597mm x 336mm
EDID:
00ffffffffffff001e6d7f5b794a0a00
011f0104b53c22789f8cb5af4f43ab26
0e5054254b007140818081c0a9c0b300
d1c08100d1cf09ec00a0a0a067503020
3a0055502100001a000000fd003090e6
e63c010a202020202020000000fc004c
4720554c545241474541520a000000ff
003130314e54484d4b553432350a015b
02031a7123090607e305c000e6060501
60592846100403011f13565e00a0a0a0
29503020350055502100001a5aa000a0
a0a0465030203a005550210000006fc2
00a0a0a0555030203a0055502100001a
00000000000000000000000000000000
000000000000000000000000000000da
_KDE_SCREEN_INDEX: 1
GAMMA_LUT_SIZE: 4096
range: (0, -1)
DEGAMMA_LUT_SIZE: 4096
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
supported: off, on, auto
subconnector: Native
supported: Unknown, VGA, DVI-D, HDMI, DP, Wireless, Native
HDCP Content Type: HDCP Type0
supported: HDCP Type0, HDCP Type1
Content Protection: Undesired
supported: Undesired, Desired, Enabled
vrr_capable: 1
range: (0, 1)
max bpc: 8
range: (8, 16)
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
scaling mode: None
supported: None, Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 86
supported: 86
non-desktop: 0
range: (0, 1)
2560x1440 143.97*+ 120.00 99.95 59.95
1920x1200 143.97
1920x1080 74.98 60.00 60.00 50.00 59.94
1600x1200 143.97
1680x1050 59.95
1600x900 60.00
1280x1024 75.02 60.02
1440x900 143.97
1280x800 59.81
1152x864 59.97
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
800x600 75.00 60.32
720x480 60.00 59.94
640x480 75.00 60.00 59.94
DisplayPort-1 connected 640x480+3639+97 (normal left inverted right x axis y axis) 0mm x 0mm
_KDE_SCREEN_INDEX: 3
range: (0, -1)
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
0 1
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 94
supported: 94
non-desktop: 0
range: (0, 1)
640x480 59.94*
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
range: (0, -1)
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
subconnector: Unknown
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 98
supported: 98
non-desktop: 0
range: (0, 1)
HDMI-A-0 connected primary 1080x1920+0+0 left (normal left inverted right x axis y axis) 345mm x 194mm
_KDE_SCREEN_INDEX: 2
EDID:
00ffffffffffff002613601501000000
0b1d010380211678ea2d36a75438ae26
0d4f54a10800d1c0b3009500818081c0
810001010101023a801871382d40582c
450059c21000001e000000fc00424b59
313536310a2020202020000000fd003a
3e1e5310000a202020202020000000ff
00303030303030303030303030310129
020319f148900504032309071f208301
000066030c00100080011d007251d01e
206e285500a05a0000001e011d00bc52
d01e20b8285540a05a0000001e000000
00000000000000000000000000000059
range: (0, -1)
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
0 1
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 102
supported: 102
non-desktop: 0
range: (0, 1)
1920x1080 60.00*+ 50.00 59.94
1680x1050 59.88
2880x480 60.00 59.94
1280x1024 60.02
1440x900 59.90
1280x800 59.91
1024x768 60.00
800x600 60.32
720x480 60.00 59.94
640x480 60.00 59.94
720x400 70.08
Any suggestion on what I should try next would be very helpful, thank you.
