Hello,
I used Debian several years. As i switched from Win10 to Linux for Gaming and the debian testing, sid or stable has all their own hurdles when it comes for an simple to use distro with newest packages, i give Manjaro a try.
Unfortunately, the installer its not really clear for me… how can i tell the installer to use luks encryption for my 2 ssds and using them as one lvm partition, with logical volume for swap and system? In debian it was easy, but in manjaro i no idea how to setup correctly.
Is there an installation guide or something that let me do a correct setup?
Thank you very much for you help,
