I had previously configured proprietary drivers and using nvidia to render graphics and now my GPU card is damaged.
I want to change the configuration and use inbuilt configuration instead of the nvidia GPU.
Things I can’t do right now
provide system info, as I am using my nvme ssd on different system through live usb + external casing
purchase new gpu, the gpu is soldered as I am using laptop.
Things I can provide: Since I am able to access my ssd from different system (manjaro-chroot), I can provide you the config files to help me fix this issue.
However, @tbhaxor, can you access the drive on a Linux machine, somehow?
Edit:
a Good idea might also be to check the BIOS/UEFI and disable it there. In fact, I’d suggest that before you go on.
Edit #2:
If you can disable in BIOS/UEFI, then you an disable it, ensure the Intel one is enabled, boot and enter a live environment, chroot into your installation and undo the steps to use only nvidia.
@tbhaxor if you disabled the nvidia card in BIOS/UEFIand ensured the Intel one is enabled, then simply uninstalling any and all nvidia-related stuff and undoing any custom configurations should be sufficient.
Update: It is display issue not the GPU one. Display is pitch dark in middle and some smudgy lines on the borders. Also when I restarted the PC (hard reset), I can’t see the BIOS splash screen.
I will get it diagnosed on the computer shop tomorrow.
