No ofcourse tried :0
I also installed wayland from pamac build.
Would kernel and firmware be the next step?
Since we use RPi’s kernel and they provide the firmware and I keep them up to date they should already have what is needed.
From reading this article the Pi OS is maintaining their own mesa at the moment. It looks like only the initial commit to mesa has been made for the pi5 support. I believe the next step for other distro’s is to wait for full support from mesa.
ok, Bookworm use mesa-22.3.6, run pretty well.
so, build it for Pi4 and solved lost vulkan device issue.
and, test pass by SaschaWillems vulkan demo.
edit,
sorry, wrong source.
update, it was mesa-23.2.1-0+rpi2 from raspi.list source, patched.
Well it looks like you solved your issue you were having in another thread a couple of days ago on your pi4.
runs like a dream on rpi5. I installed docker and ran an ubuntu rdp enabled container, even that was crazy good (llvm pipeline).
cant wait for Manjaro running full bore
black market over $130/Pi5-8, $150 cooler plus.
I finally ordered an 8gb Pi5. I wished that I was Local the place where I ordered it.
I have not heard anything on my pre-order yet. I bet you will not see yours until January or February if you just ordered it.
Ah, sometime next week. unless Australia Post does something weird… like sending it to Perth, Western Australia.
I tried that on the pamac build mesa-git method,
it builds but still not glxinfo -B -display :0 output.
glxinfo -B
name of display: :0
Unsupported modifier requested
display: :0 screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Broadcom (0x14e4)
Device: V3D 4.2 (0xffffffff)
Version: 23.2.1
Accelerated: yes
Video memory: 7809MB
Unified memory: yes
Preferred profile: core (0x1)
Max core profile version: 3.1
Max compat profile version: 3.1
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.1
OpenGL vendor string: Broadcom
OpenGL renderer string: V3D 4.2
OpenGL core profile version string: 3.1 Mesa 23.2.1
OpenGL core profile shading language version string: 1.40
OpenGL version string: 3.1 Mesa 23.2.1
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 23.2.1
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
rpi4 yes ?
yep, Pi2 → Pi4 → Pi6?
Well you are lucky. I finally got an email from The Pi Hut in England but it was a lot of talk that did not give me any info on when to expect mine. I ordered as soon as I saw the announcement and their site was to only one that had been set up for pre-orders. What I learned from the email:
Apologized for not giving info due to email server issues
First batch pre-orders larger than expected so waiting for more devices
Then gave dates for 2nd and third batches; which had not changed
I am not having luck , i think its moaning about runtime dependancy v3dv3 not found
I ran across this today where RPi had some mesa tarballs at he bottom here of different versions and some associated patches with the same version. Looks like to me the patches may be prepared for upstream. There are several patches for each version; I do not know if they are incremental or not or their purpose.
I had post above, build mesa_23.2.1-0+rpt2 and run pretty well.
but not sure if Pi5 patched?
@BRX7 When you get time will you test these mesa packages on your pi5?
On my pi4:
name of display: :0.0
Version: 23.2.1
Accelerated: yes
Unified memory: yes
OpenGL core profile version string: 3.1 Mesa 23.2.1+rpt2.1
OpenGL version string: 3.1 Mesa 23.2.1+rpt2.1
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 23.2.1+rpt2.1
Device-1: bcm2711-hdmi0 driver: vc4_hdmi v: N/A
Device-2: bcm2711-hdmi1 driver: vc4_hdmi v: N/A
Device-3: bcm2711-vc5 driver: vc4_drm v: N/A
Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2 driver: X:
loaded: modesetting dri: vc4
gpu: vc4-drm,vc4_crtc,vc4_dpi,vc4_dsi,vc4_firmware_kms,vc4_hdmi,vc4_hvs,vc4_txp,vc4_v3d,vc4_vec
resolution: 1440x900~75Hz
API: EGL v: 1.4,1.5 drivers: swrast,v3d,vc4
API: OpenGL v: 4.5 compat-v: 3.1 vendor: broadcom mesa v: 23.2.1+rpt2.1
renderer: V3D 4.2
API: Vulkan v: 1.3.269 drivers: v3dv,llvmpipe surfaces: xcb,xlib
I have these packages installed from the provided mesa-patched folder.
sudo pacman -U mesa-23.2.1-1-aarch64.pkg.tar.zst vulkan-broadcom-23.2.1-1-aarch64.pkg.tar.zst vulkan-mesa-layers-23.2.1-1-aarch64.pkg.tar.zst vulkan-swrast-23.2.1-1-aarch64.pkg.tar.zst
11-14-23: New link
Hi Darksky
I installed them inside the recent plasma rpi image
this is inxi -G output
Device-1: bcm2712-hdmi0 driver: vc4_hdmi v: N/A
Device-2: bcm2712-hdmi1 driver: vc4_hdmi v: N/A
Display: server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2 driver: X:
loaded: modesetting
gpu: vc4-drm,vc4_crtc,vc4_dpi,vc4_dsi,vc4_firmware_kms,vc4_hdmi,vc4_hvs,vc4_ txp,vc4_v3d,vc4_vec
tty: 80x24
API: EGL v: 1.5 drivers: kms_swrast,swrast
platforms: gbm,surfaceless,device
API: OpenGL v: 4.5 vendor: mesa v: 23.2.1-arch1.3
note: console (EGL sourced) renderer: llvmpipe (LLVM 16.0.6 128 bits)
API: Vulkan v: 1.3.269 drivers: llvmpipe surfaces: N/A
from a working bookworm install on a rpi5 I have the following
inxi -G
Display: wayland server: X.Org v: 1.22.1.9 with: Xwayland v: 22.1.9
compositor: wayfire v: 0.7.5 driver: dri: vc4
resolution: 1280x720~60Hz
API: OpenGL v: 3.1 Mesa 23.2.1-0+rpt2 renderer: V3D 7.1
glxinfo -B
name of display: :0
WARNING: v3d support for hw version 71 is neither a complete nor a conformant OpenGL implementation. Testing use only.
Device: V3D 7.1 (0xffffffff)
Version: 23.2.1
Accelerated: yes
Video memory: 8052MB
Unified memory: yes
OpenGL renderer string: V3D 7.1
OpenGL core profile version string: 3.1 Mesa 23.2.1-0+rpt2
OpenGL version string: 3.1 Mesa 23.2.1-0+rpt2
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 23.2.1-0+rpt2
