I have a strange issue with bluetooth headphones, I hearing some quirks, short noises that come and go. I’m using pipewire, I was thinking to switch back to pulseaudio to see if it helps, but I cannot replace it with pulseaudio
I installed pulse audio packages but was not prompted that it conflicts with pipewire and to remove the later and I can’t remove pipewire either
❯ pacman -Qs pipewire
local/gst-plugin-pipewire 1:1.0.7-2
Multimedia graph framework - pipewire plugin
local/libpipewire 1:1.0.7-2
Low-latency audio/video router and processor - client library
local/libwireplumber 0.5.2-2
Session / policy manager implementation for PipeWire - client library
local/pipewire 1:1.0.7-2
local/pipewire-session-manager 1:1.0.7-2
Session manager for PipeWire (default provider)
local/qemu-audio-pipewire 9.0.0-1
QEMU PipeWire audio driver
local/wireplumber 0.5.2-2
❯ sudo pacman -Rsn local/gst-plugin-pipewire local/libpipewire local/libwireplumber local/pipewire local/pipewire-session-manager local/qemu-audio-pipewire local/wireplumber
[sudo] password for gnome:
checking dependencies...
:: removing libpipewire breaks dependency 'libpipewire' required by audacious-plugins
:: removing libpipewire breaks dependency 'libpipewire' required by fluidsynth
:: removing libpipewire breaks dependency 'libpipewire-0.3.so=0-64' required by fluidsynth
:: removing libpipewire breaks dependency 'libpipewire' required by gnome-remote-desktop
:: removing pipewire breaks dependency 'pipewire' required by gnome-remote-desktop
:: removing libpipewire breaks dependency 'libpipewire' required by gnome-shell
:: removing libpipewire breaks dependency 'libpipewire' required by mutter
:: removing pipewire breaks dependency 'pipewire' required by mutter
:: removing pipewire breaks dependency 'pipewire' required by obs-studio
:: removing qemu-audio-pipewire breaks dependency 'qemu-audio-pipewire=9.0.0-1' required by qemu-desktop
:: removing gst-plugin-pipewire breaks dependency 'gst-plugin-pipewire' required by snapshot
:: removing libpipewire breaks dependency 'libpipewire' required by xdg-desktop-portal
:: removing pipewire breaks dependency 'pipewire' required by xdg-desktop-portal
How can I do this?
