pixel
12 April 2023 18:47
1
I use nvidia with nouveau driver. I’m going to remove nvidia card and switch to intel CPU with onboard graphic CPU as the only graphic. Do I need to uninstall nouveau driver first and install some nouveau driver dedicated for Intel or do anything about at all? Or system will load from its kernel all I need?
Do I need to worry about some xorg configs?
Are there any propriatary drivers for Intel onboard graphics? If yes, are they better than nouveau?
post output from:
mhwd -l -li
inxi -xG
pixel
12 April 2023 18:51
3
For the first: command not found. For second: it doesn’t do anything, no output.
lspci -k | grep -EA3 'VGA|3D|Display'
01:00.0 VGA compatible controller: NVIDIA Corporation GT218 [GeForce 210] (rev a2)
Subsystem: ASUSTeK Computer Inc. Device 8354
Kernel driver in use: nouveau
Kernel modules: nouveau
those commands should have outputs… did you typed them correctly?
in the lspci output it shows only nvidia, not intel cpu … is it disabled in bios?
pixel
12 April 2023 18:56
5
I haven’t switched hardware yet. I wanted to avoid troubles and ask first. I will come back here when I switch my disk to new mothermoard and CPU.
you should boot normally, since nouveau is included in video-linux and thats what youll be using with intel gpu
cscs
12 April 2023 20:42
7
Please provide the output of mhwd as already asked.
Likely you have video-linux profile installed … which is an umbrella for all the open video drivers. In which case you would be fine … but check mhwd.
This should be part of your basic ‘how to use manjaro’ knowledge.
For the very start I would read the following article in Arch Wiki
https://wiki.archlinux.org/title/intel_graphics - must read
On my laptop (Dell Lat. 5480) I have Intel HD graphics 620 - works very well in x11 and even better in Wayland (sddm - kde plasma 5.27)
If you config. everything properly as the above article says,
your konsole command
vainfo
should produce the following HW accel. results (enc means HW encoding):
vic@vic-2:~/$ vainfo
Trying display: wayland
vainfo: VA-API version: 1.18 (libva 2.17.1)
vainfo: Driver version: Intel i965 driver for Intel(R) Kaby Lake - 2.4.1
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointEncSliceLP
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointEncSliceLP
VAProfileH264MultiviewHigh : VAEntrypointVLD
VAProfileH264MultiviewHigh : VAEntrypointEncSlice
VAProfileH264StereoHigh : VAEntrypointVLD
VAProfileH264StereoHigh : VAEntrypointEncSlice
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileVP8Version0_3 : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileHEVCMain10 : VAEntrypointEncSlice
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointEncSlice
VAProfileVP9Profile2 : VAEntrypointVLD
system
Closed
16 April 2023 13:53
9
