I know this update happened a long time ago but can anyone tell me how to safely switch from video-hybrid-intel-nvidia-430xx-bumblebee to video-hybrid-intel-nvidia-450xx-prime as a driver using mhwd? I was having difficulty finding it on manjaro wiki.
$ inxi -Fxxxza --no-host
Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=3f183aee-c840-4fca-9947-75ccccf6aa9f rw noquiet pci=nomsi
apparmor=1 security=apparmor
resume=UUID=1adef7be-f8fd-439c-8550-03f060447e51 udev.log_priority=3
Desktop: GNOME 3.36.5 tk: GTK 3.24.22 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: X541UV v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X541UV v: 1.0 serial: <filter>
UEFI: American Megatrends v: X541UV.309 date: 04/17/2019
ID-1: BAT0 charge: 20.9 Wh condition: 20.9/23.8 Wh (88%) volts: 10.8/10.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
cycles: 44
Topology: Dual Core model: Intel Core i5-6198DU bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: D6
L2 cache: 3072 KiB
bogomips: 19204
Speed: 500 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 659 2: 594
3: 699 4: 507
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel HD Graphics 510 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:1906
Device-2: NVIDIA GM108M [GeForce 920MX] driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0 chip ID: 10de:134f
Device-3: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-6:2 chip ID: 04f2:b424 serial: <filter>
Display: x11 server: X.org 1.20.8 compositor: gnome-shell driver: intel
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel HD Graphics 510 (SKL GT1) v: 4.6 Mesa 20.1.6
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d70
Sound Server: ALSA v: k5.7.17-2-MANJARO
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK
driver: r8169 v: kernel port: d000 bus ID: 02:00.2 chip ID: 10ec:8136
IF: enp2s0f2 state: down mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: d000
bus ID: 03:00.0 chip ID: 8086:08b1
Local Storage: total: 1.36 TiB used: 148.21 GiB (10.6%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 3B6Q scheme: GPT
ID-2: /dev/sdb vendor: Seagate model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0001 scheme: MBR
ID-1: / raw size: 100.00 GiB size: 97.93 GiB (97.93%)
used: 49.67 GiB (50.7%) fs: ext4 dev: /dev/sda5
ID-2: /home raw size: 120.00 GiB size: 117.62 GiB (98.01%)
used: 78.43 GiB (66.7%) fs: ext4 dev: /dev/sda6
ID-3: /var raw size: 37.64 GiB size: 36.80 GiB (97.77%)
used: 20.11 GiB (54.6%) fs: ext4 dev: /dev/sda7
ID-1: swap-1 type: partition size: 8.00 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda8
System Temperatures: cpu: 41.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2200
Processes: 210 Uptime: 1h 24m Memory: 19.42 GiB used: 2.84 GiB (14.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 8/9 clang: 10.0.1
Packages: pacman: 1591 lib: 372 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05
