Swedish keyboard not using swedish special character
So after updating to the new pacmac config Update - error: failed retrieving file 'community.db' from - #27 by linux-aarhus since the old one gave me this fine error
could not satisfy dependencies:
- removing lib32-libffi breaks dependency 'lib32-libffi' required by lib32-glib2
- removing lib32-pcre2 breaks dependency 'lib32-pcre2' required by lib32-glib2
- removing lib32-libffi breaks dependency 'libffi.so=8-32' required by lib32-glib2
all required by steam i did the database sync with the GUI application and now, my keyboard uses æø instead of öä.
I can see some errors in the boot
mar 07 16:08:22 amd-burk kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
mar 07 16:08:22 amd-burk kernel: usb 1-2: device descriptor read/64, error -71
mar 07 16:08:22 amd-burk kernel: usb 1-2: Device not responding to setup address.
mar 07 16:08:22 amd-burk kernel: usb 1-2: device not accepting address 4, error -71
mar 07 16:08:22 amd-burk kernel: usb 1-2: WARN: invalid context state for evaluate context command.
mar 07 16:08:22 amd-burk kernel: sd 6:0:0:0: [sdc] No Caching mode page found
mar 07 16:08:22 amd-burk kernel: sd 6:0:0:0: [sdc] Assuming drive cache: write through
mar 07 16:08:22 amd-burk kernel: usb 1-2: device not accepting address 5, error -71
mar 07 16:08:22 amd-burk kernel: usb usb1-port2: unable to enumerate USB device
mar 07 16:08:22 amd-burk kernel: asus_wmi: failed to register LPS0 sleep handler in asus-wmi
mar 07 16:08:22 amd-burk kernel: No matching power limits found for this system
mar 07 16:08:22 amd-burk kernel: Could not initialise PPT tunable control 0
mar 07 16:08:22 amd-burk kernel: usb 5-2.2.1: Warning! Unlikely big volume range (=5120), cval->res is probably wrong.
mar 07 16:08:22 amd-burk kernel: usb 5-2.2.1: [5] FU [Microphone Capture Volume] ch = 1, val = -2560/2560/1
mar 07 16:08:23 amd-burk kernel: usb 5-2.2.3.4: clear tt 1 (00b0) error -71
mar 07 16:08:23 amd-burk bluetoothd[771]: src/plugin.c:init_plugin() System does not support bap plugin
mar 07 16:08:23 amd-burk bluetoothd[771]: src/plugin.c:init_plugin() System does not support bass plugin
mar 07 16:08:23 amd-burk bluetoothd[771]: src/plugin.c:init_plugin() System does not support mcp plugin
mar 07 16:08:23 amd-burk bluetoothd[771]: src/plugin.c:init_plugin() System does not support vcp plugin
mar 07 16:08:23 amd-burk bluetoothd[771]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
mar 07 16:08:23 amd-burk bluetoothd[771]: src/plugin.c:init_plugin() System does not support micp plugin
mar 07 16:08:23 amd-burk bluetoothd[771]: src/plugin.c:init_plugin() System does not support ccp plugin
mar 07 16:08:23 amd-burk bluetoothd[771]: src/plugin.c:init_plugin() System does not support csip plugin
mar 07 16:08:23 amd-burk bluetoothd[771]: src/plugin.c:init_plugin() System does not support asha plugin
mar 07 16:08:50 amd-burk kernel: usb 5-2.2.3.4.4: 3:0: failed to get current value for ch 0 (-22)
mar 07 16:08:50 amd-burk kernel: usb 5-2.2.3.4.4: 3:0: cannot get min/max values for control 2 (id 3)
mar 07 16:08:50 amd-burk kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
mar 07 16:08:50 amd-burk (udev-worker)[561]: controlC3: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:08.1/0000:0e:00.4/usb5/5-2/5-2.2/5-2.2.3/5-2.2.3.4/5-2.2.3.4.4/5-2.2.3.4.4:1.0/sound/card3/controlC3/../uevent}="change", ignoring: No such file or directory
mar 07 16:08:50 amd-burk (udev-worker)[582]: controlC2: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:08.1/0000:0e:00.4/usb5/5-2/5-2.2/5-2.2.1/5-2.2.1:1.4/sound/card2/controlC2/../uevent}="change", ignoring: No such file or directory
mar 07 16:08:51 amd-burk dbus-broker-launch[767]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
mar 07 16:08:51 amd-burk kernel: usb 5-2.2.1: Warning! Unlikely big volume range (=5120), cval->res is probably wrong.
mar 07 16:08:51 amd-burk kernel: usb 5-2.2.1: [5] FU [Microphone Capture Volume] ch = 1, val = -2560/2560/1
mar 07 16:08:51 amd-burk dbus-broker-launch[978]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mar 07 16:08:51 amd-burk dbus-broker-launch[978]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
mar 07 16:08:51 amd-burk dbus-broker-launch[978]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mar 07 16:08:52 amd-burk kernel: block nvme0n1: No UUID available providing old NGUID
mar 07 16:08:52 amd-burk wireplumber[1091]: pw.resource: can't create node: No such file or directory
mar 07 16:08:52 amd-burk wireplumber[1091]: wp-node: failed to create node from factory 'spa-node-factory'
mar 07 16:08:52 amd-burk kded6[1190]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
mar 07 16:08:52 amd-burk kded6[1190]: QDBusObjectPath: invalid path "/modules/oom-notifier"
mar 07 16:08:52 amd-burk kded6[1190]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
mar 07 16:08:52 amd-burk kded6[1190]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
mar 07 16:08:52 amd-burk kded6[1190]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
mar 07 16:08:53 amd-burk kactivitymanagerd[1272]: kf.windowsystem: virtual void KX11Extras::connectNotify(const QMetaMethod&) may only be used on X11
mar 07 16:08:53 amd-burk plasmashell[1247]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
                                            file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
mar 07 16:08:53 amd-burk plasmashell[1247]: Toolbox not loading, toolbox package is either invalid or disabled.
mar 07 16:08:53 amd-burk plasmashell[1247]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
mar 07 16:08:53 amd-burk baloo_file[996]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.24'
mar 07 16:08:53 amd-burk baloo_file[996]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.27'
mar 07 16:08:53 amd-burk backlighthelper[1434]: org.kde.powerdevil: no kernel backlight interface found
mar 07 16:08:53 amd-burk org_kde_powerdevil[1276]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 07 16:08:53 amd-burk org_kde_powerdevil[1276]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
mar 07 16:08:53 amd-burk org_kde_powerdevil[1276]: org.kde.powerdevil: Handle button events action could not check for screen configuration
mar 07 16:08:55 amd-burk kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
mar 07 16:08:54 amd-burk DiscoverNotifier[1479]: couldn't load "/usr/lib/qt6/plugins/discover-notifier/DiscoverPackageKitNotifier.so" because "Cannot load library /usr/lib/qt6/plugins/discover-notifier/DiscoverPackageKitNotifier.so: libpackagekitqt6.so.1: cannot open shared object file: No such file or directory"
mar 07 16:08:54 amd-burk kdeconnectd[1459]: 2025-03-07T16:08:54 default: Error sending UDP packet: QAbstractSocket::NetworkError
mar 07 16:08:54 amd-burk kdeconnectd[1459]: 2025-03-07T16:08:54 kdeconnect.core: Failed to open any MDNS client sockets
mar 07 16:08:54 amd-burk kdeconnectd[1459]: 2025-03-07T16:08:54 kdeconnect.core: Failed to open any MDNS server sockets
mar 07 16:08:54 amd-burk kconf_update[1854]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
mar 07 16:08:54 amd-burk kconf_update[1854]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
mar 07 16:08:54 amd-burk kconf_update[1854]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
mar 07 16:08:54 amd-burk kconf_update[1854]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
mar 07 16:08:54 amd-burk kconf_update[1854]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
mar 07 16:08:54 amd-burk kconf_update[1854]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
mar 07 16:08:54 amd-burk plasmashell[1847]: QThreadStorage: Thread 0x6162dfb69830 exited after QThreadStorage 8 destroyed
mar 07 16:08:54 amd-burk plasmashell[1851]: QThreadStorage: Thread 0x589e11711830 exited after QThreadStorage 8 destroyed
mar 07 16:08:54 amd-burk plasmashell[1851]: QThreadStorage: Thread 0x589e11711830 exited after QThreadStorage 3 destroyed
mar 07 16:08:54 amd-burk plasmashell[1847]: QThreadStorage: Thread 0x6162dfb69830 exited after QThreadStorage 3 destroyed
mar 07 16:08:54 amd-burk plasmashell[1851]: QThreadStorage: Thread 0x589e11711830 exited after QThreadStorage 2 destroyed
mar 07 16:08:54 amd-burk plasmashell[1847]: QThreadStorage: Thread 0x6162dfb69830 exited after QThreadStorage 2 destroyed
mar 07 16:08:54 amd-burk pulseaudio[1158]: Failed to open connection to session manager: None of the authentication protocols specified are supported
mar 07 16:08:54 amd-burk pulseaudio[1158]: Failed to load module "module-x11-xsmp" (argument: "display=:1 xauthority=/run/user/1000/xauth_teyRLq session_manager=local/amd-burk:@/tmp/.ICE-unix/1188,unix/amd-burk:/tmp/.ICE-unix/1188"): initialization failed.
mar 07 16:08:54 amd-burk systemd[933]: app-pulseaudio@autostart.service: Failed with result 'exit-code'.
mar 07 16:08:55 amd-burk kded6[1190]: kf.bluezqt: PendingCall Error: "The name is not activatable"
mar 07 16:08:55 amd-burk kded6[1190]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_03_00.1.hdmi-stereo-extra4.monitor"
mar 07 16:08:55 amd-burk corectrl[1457]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&Yes" msgid_plural: "" msgctxt: "@action:button"
mar 07 16:08:55 amd-burk corectrl[1457]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "&No" msgid_plural: "" msgctxt: "@action:button"
mar 07 16:08:55 amd-burk plasmashell[1247]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/application-menu
mar 07 16:08:55 amd-burk kwalletmanager5[1974]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
mar 07 16:08:55 amd-burk plasmashell[1247]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
mar 07 16:08:56 amd-burk dbus-broker-launch[767]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
mar 07 16:08:56 amd-burk pulseaudio[1158]: org.freedesktop.DBus.Properties.Get /org/bluez/hci0/dev_00_1B_66_8B_62_E7/sep3/fd0 Volume property not (yet) available
mar 07 16:08:56 amd-burk kded6[1190]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_03_00.1.hdmi-stereo-extra4.monitor"
mar 07 16:08:56 amd-burk kded6[1190]: org.kde.pulseaudio: No object for name "alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo-input"
mar 07 16:08:56 amd-burk kdeconnectd[1459]: 2025-03-07T16:08:56 kdeconnect.core: Failed to send mDNS query: Cannot assign requested address
mar 07 16:08:59 amd-burk kwin_wayland[997]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x62f2a3f04c50)
mar 07 16:08:59 amd-burk xdg-desktop-por[1006]: Realtime error: Could not get pidns: Could not fstatat ns/pid: Not a directory
mar 07 16:09:00 amd-burk systemd-coredump[3296]: Process 3294 (gldriverquery) of user 1000 dumped core.
                                                 Stack trace of thread 3294:
                                                 #0  0x00000000ee82f579 n/a (n/a + 0x0)
                                                 ELF object binary architecture: Intel 80386
mar 07 16:09:02 amd-burk kwin_wayland[997]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 07 16:09:03 amd-burk kwin_wayland[997]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 07 16:09:06 amd-burk plasmashell[1247]: org.kde.plasma.taskmanager: applications:com.discordapp.Discord.desktop: Progress value -100 is out of bounds!
mar 07 16:09:06 amd-burk kwin_wayland[997]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x62f2a3ce1750)
mar 07 16:11:22 amd-burk xdg-desktop-portal-kde[1277]: xdp-kde-settings: Namespace  "org.gnome.desktop.a11y.interface"  is not supported
mar 07 16:11:22 amd-burk pamac-manager[4886]: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
mar 07 16:11:23 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:11:24 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:11:25 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:11:26 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:11:29 amd-burk kwin_wayland[997]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x62f2a3ebe520)
mar 07 16:11:29 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:11:30 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:13 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:14 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:15 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:15 amd-burk kwin_wayland[997]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x62f2a2a0fd60)
mar 07 16:12:16 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:17 amd-burk polkit-kde-authentication-agent-1[1275]: qrc:/qt/qml/org/kde/desktop/MenuItem.qml:84:13: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 10. Use 'sequences: [ <key> ]' to bind to all of them.
mar 07 16:12:20 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:27 amd-burk pamac-tray-plas[1483]: Source ID 10 was not found when attempting to remove it
mar 07 16:12:27 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:28 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:30 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:31 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:32 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:34 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:35 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:36 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:39 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:40 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:41 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:43 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:44 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:45 amd-burk pamac-tray-plas[1483]: Source ID 13 was not found when attempting to remove it
mar 07 16:12:51 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:12:52 amd-burk pamac-tray-plas[1483]: Source ID 14 was not found when attempting to remove it
mar 07 16:13:09 amd-burk pamac-manager[4886]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:21:00 amd-burk plasmashell[1247]: kf.windowsystem.wayland: Failed to recreate shadow for PlasmaQuick::AppletPopup_QML_212(0x617de4acb600, name="popupWindow")
mar 07 16:21:00 amd-burk plasmashell[1247]: qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
mar 07 16:21:10 amd-burk manjaro-settings-manager[6571]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
mar 07 16:21:31 amd-burk kwin_wayland[997]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x62f2a2a0fd60)
mar 07 16:21:33 amd-burk systemd-localed[6730]: Cannot compile XKB keymap for x11 keyboard layout (model='pc105' / layout='us' / variant='nodeadkeys' / options=''): Invalid argument
mar 07 16:22:11 amd-burk systemd-localed[6730]: Cannot compile XKB keymap for x11 keyboard layout (model='pc105' / layout='lv' / variant='nodeadkeys' / options=''): Invalid argument
mar 07 16:22:28 amd-burk systemsettings[6951]: qml: Pushed pages do not conform to the rules. Please check the documentation.
mar 07 16:22:37 amd-burk plasmashell[1247]: kf.plasma.quick: location should be set before showing popup window
mar 07 16:22:48 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 16:23:57 amd-burk kwin_wayland[997]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x62f2a2a0fd60)
mar 07 16:25:11 amd-burk systemsettings[7483]: QThreadStorage: Thread 0x61926eb1eba0 exited after QThreadStorage 8 destroyed
mar 07 16:25:11 amd-burk systemsettings[7483]: QThreadStorage: Thread 0x61926eb1eba0 exited after QThreadStorage 3 destroyed
mar 07 16:25:11 amd-burk systemsettings[7483]: QThreadStorage: Thread 0x61926eb1eba0 exited after QThreadStorage 2 destroyed
mar 07 16:25:48 amd-burk kwin_wayland[997]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x62f2a3fdcb50)
mar 07 16:25:52 amd-burk systemsettings[6951]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:172:9: QML ListView: Binding loop detected for property "cacheBuffer":
                                               qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:177:13
mar 07 16:25:54 amd-burk systemsettings[6951]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:172:9: QML ListView: Binding loop detected for property "cacheBuffer":
mar 07 16:25:57 amd-burk systemsettings[6951]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:172:9: QML ListView: Binding loop detected for property "cacheBuffer":
mar 07 16:26:03 amd-burk systemsettings[6951]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:156:5: QML OverlaySheet: Binding loop detected for property "implicitHeight":
                                               file:///usr/lib/qt6/qml/org/kde/kirigami/templates/OverlaySheet.qml:132:5
mar 07 16:26:03 amd-burk systemsettings[6951]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:156:5: QML OverlaySheet: Binding loop detected for property "y":
                                               file:///usr/lib/qt6/qml/org/kde/kirigami/templates/OverlaySheet.qml:110:5
mar 07 16:26:03 amd-burk systemsettings[6951]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:172:9: QML ListView: Binding loop detected for property "cacheBuffer":
mar 07 16:26:21 amd-burk systemsettings[6951]: qt.svg.draw: The requested buffer size is too big, ignoring
mar 07 16:26:23 amd-burk systemsettings[6951]: qt.qml.typeregistration: Invalid QML element name "Hint"; value type names should begin with a lowercase letter
mar 07 16:26:24 amd-burk systemsettings[6951]: kf.kirigami.layouts: FormData.buddyFor must be a direct child of the attachee. Attachee: RunScriptEdit_QMLTYPE_251_QML_271(0x5eef2d8b5010, parent=0x5eef2d7fdf60, geometry=0,0 0x0), buddyFor: ActionTextField_QMLTYPE_87(0x5eef2d891cd0, parent=0x5eef2dc07c70, geometry=0,0 0x0)
mar 07 16:26:24 amd-burk systemsettings[6951]: kf.kirigami.layouts: FormData.buddyFor must be a direct child of the attachee. Attachee: RunScriptEdit_QMLTYPE_251_QML_267(0x5eef2e86e700, parent=0x5eef2d7fdf60, geometry=0,0 0x0), buddyFor: ActionTextField_QMLTYPE_87(0x5eef2e5c8080, parent=0x5eef2e5c7ec0, geometry=0,0 0x0)
mar 07 16:26:24 amd-burk systemsettings[6951]: kf.kirigami.layouts: FormData.buddyFor must be a direct child of the attachee. Attachee: RunScriptEdit_QMLTYPE_251_QML_264(0x5eef2b504080, parent=0x5eef2d7fdf60, geometry=0,0 0x0), buddyFor: ActionTextField_QMLTYPE_87(0x5eef2dd69a90, parent=0x5eef2dd69640, geometry=0,0 0x0)
mar 07 16:26:24 amd-burk org_kde_powerdevil[1276]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getconservationmode failed "Battery conservation mode is not supported"
mar 07 16:26:26 amd-burk systemsettings[6951]: kf.kcmutils: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
mar 07 16:26:26 amd-burk systemsettings[6951]: qrc:/kcm/kcm_users/UserDetailsPage.qml:271:5: QML ChangeWalletPassword: Binding loop detected for property "implicitHeight":
mar 07 16:26:27 amd-burk systemsettings[6951]: qrc:/kcm/kcm_autostart/main.qml:154: TypeError: Cannot read property 'activeState' of undefined
mar 07 16:26:28 amd-burk systemsettings[6951]: qml: Pushed pages do not conform to the rules. Please check the documentation.
mar 07 16:26:48 amd-burk xdg-desktop-portal-kde[1277]: xdp-kde-settings: Namespace  "org.gnome.desktop.a11y.interface"  is not supported
mar 07 16:26:48 amd-burk pamac-manager[7902]: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
mar 07 16:26:48 amd-burk pamac-manager[7902]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:26:49 amd-burk pamac-manager[7902]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:26:50 amd-burk pamac-manager[7902]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:26:51 amd-burk pamac-manager[7902]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:26:52 amd-burk pamac-manager[7902]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:26:53 amd-burk pamac-manager[7902]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:26:57 amd-burk pamac-manager[7902]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:27:04 amd-burk pamac-manager[7902]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:27:05 amd-burk pamac-manager[7902]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:27:06 amd-burk pamac-manager[7902]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:27:06 amd-burk kwin_wayland[997]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x62f2a2a0fd60)
mar 07 16:27:07 amd-burk pamac-manager[7902]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:27:08 amd-burk pamac-manager[7902]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:28:31 amd-burk kwin_wayland[997]: file:///usr/share/kwin/tabbox/compact/contents/ui/main.qml:36: TypeError: Cannot call method 'longestCaption' of null
mar 07 16:28:31 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 16:28:37 amd-burk xdg-desktop-portal-kde[1277]: xdp-kde-settings: Namespace  "org.gnome.desktop.a11y.interface"  is not supported
mar 07 16:28:37 amd-burk pamac-manager[8417]: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
mar 07 16:28:38 amd-burk pamac-manager[8417]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:28:40 amd-burk pamac-manager[8417]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:28:44 amd-burk kwin_wayland[997]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x62f2a2a0fd60)
mar 07 16:28:44 amd-burk pamac-manager[8417]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:28:46 amd-burk pamac-manager[8417]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:28:51 amd-burk pamac-manager[8417]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:28:52 amd-burk pamac-manager[8417]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:28:53 amd-burk pamac-manager[8417]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:29:11 amd-burk kernel: ntfs3(sdc1): ino=121, Correct links count -> 2.
mar 07 16:29:11 amd-burk kernel: ntfs3(sdc1): ino=29b7, Correct links count -> 2.
mar 07 16:29:11 amd-burk kernel: ntfs3(sdc1): ino=2a4, Correct links count -> 2.
mar 07 16:29:11 amd-burk kernel: ntfs3(sdc1): ino=eebc, Correct links count -> 2.
mar 07 16:29:11 amd-burk kernel: ntfs3(sdc1): ino=321, Correct links count -> 2.
mar 07 16:29:11 amd-burk kernel: ntfs3(sdc1): ino=2b52, Correct links count -> 2.
mar 07 16:29:11 amd-burk kernel: ntfs3(sdc1): ino=2c0, Correct links count -> 2.
mar 07 16:29:11 amd-burk kernel: ntfs3(sdc1): ino=7a5, Correct links count -> 2.
mar 07 16:29:11 amd-burk kernel: ntfs3(sdc1): ino=b1c6, Correct links count -> 2.
mar 07 16:29:11 amd-burk kernel: ntfs3(sdc1): ino=905a, Correct links count -> 2.
mar 07 16:29:37 amd-burk kernel: ntfs3: 49 callbacks suppressed
mar 07 16:29:37 amd-burk kernel: ntfs3(sdc1): ino=2a97, Correct links count -> 2.
mar 07 16:29:37 amd-burk kernel: ntfs3(sdc1): ino=1ebd, Correct links count -> 2.
mar 07 16:29:37 amd-burk kernel: ntfs3(sdc1): ino=1cf5, Correct links count -> 2.
mar 07 16:29:37 amd-burk kernel: ntfs3(sdc1): ino=2d0a, Correct links count -> 2.
mar 07 16:29:37 amd-burk kernel: ntfs3(sdc1): ino=2d03, Correct links count -> 2.
mar 07 16:29:37 amd-burk kernel: ntfs3(sdc1): ino=2cf8, Correct links count -> 2.
mar 07 16:29:37 amd-burk kernel: ntfs3(sdc1): ino=2c9f, Correct links count -> 2.
mar 07 16:29:37 amd-burk kernel: ntfs3(sdc1): ino=2b73, Correct links count -> 2.
mar 07 16:29:37 amd-burk kernel: ntfs3(sdc1): ino=2a02, Correct links count -> 2.
mar 07 16:29:37 amd-burk kernel: ntfs3(sdc1): ino=2943, Correct links count -> 2.
mar 07 16:29:42 amd-burk kernel: ntfs3: 69 callbacks suppressed
mar 07 16:29:42 amd-burk kernel: ntfs3(sdc1): ino=9bb1, Correct links count -> 2.
mar 07 16:29:42 amd-burk kernel: ntfs3(sdc1): ino=9ba0, Correct links count -> 2.
mar 07 16:29:42 amd-burk kernel: ntfs3(sdc1): ino=9912, Correct links count -> 2.
mar 07 16:29:42 amd-burk kernel: ntfs3(sdc1): ino=9b4d, Correct links count -> 2.
mar 07 16:29:42 amd-burk kernel: ntfs3(sdc1): ino=9b3d, Correct links count -> 2.
mar 07 16:29:42 amd-burk kernel: ntfs3(sdc1): ino=9b2d, Correct links count -> 2.
mar 07 16:29:42 amd-burk kernel: ntfs3(sdc1): ino=9b0f, Correct links count -> 2.
mar 07 16:29:42 amd-burk kernel: ntfs3(sdc1): ino=9afe, Correct links count -> 2.
mar 07 16:29:42 amd-burk kernel: ntfs3(sdc1): ino=9af0, Correct links count -> 2.
mar 07 16:29:42 amd-burk kernel: ntfs3(sdc1): ino=9ae0, Correct links count -> 2.
mar 07 16:30:42 amd-burk kwin_wayland[997]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 07 16:30:51 amd-burk kwin_wayland[997]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 07 16:30:57 amd-burk kwin_wayland[997]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 07 16:31:03 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 16:31:11 amd-burk xdg-desktop-portal-kde[1277]: QWindow::fromWinId(): platform plugin does not support foreign windows.
mar 07 16:31:30 amd-burk plasmashell[1247]: org.kde.plasma.taskmanager: applications:com.discordapp.Discord.desktop: Progress value -100 is out of bounds!
mar 07 16:31:57 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 16:32:43 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 16:32:47 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 16:35:09 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 16:35:45 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 16:37:44 amd-burk xdg-desktop-portal-kde[1277]: xdp-kde-settings: Namespace  "org.gnome.desktop.a11y.interface"  is not supported
mar 07 16:37:44 amd-burk pamac-manager[13333]: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
mar 07 16:37:44 amd-burk pamac-manager[13333]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:37:47 amd-burk pamac-manager[13333]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:37:57 amd-burk pamac-manager[13333]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:37:58 amd-burk pamac-manager[13333]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:37:59 amd-burk pamac-manager[13333]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:37:59 amd-burk kwin_wayland[997]: kwin_core: Cannot grant a token to KWin::ClientConnection(0x62f2a2a0fd60)
mar 07 16:38:01 amd-burk pamac-manager[13333]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:38:02 amd-burk pamac-manager[13333]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:38:11 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 16:38:14 amd-burk pamac-manager[13333]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:38:17 amd-burk pamac-manager[13333]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:41:14 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 16:41:15 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 16:41:29 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 16:41:32 amd-burk pamac-manager[13333]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:41:33 amd-burk pamac-manager[13333]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:41:37 amd-burk pamac-manager[13333]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:54:57 amd-burk konsole[7689]: qt.qpa.wayland: Creating a popup with a parent, QWidgetWindow(0x5e97f3128e10, name="MainWindow#1Window") which does not match the current topmost grabbing popup, QWidgetWindow(0x5e97f3a57d60, name="session-popup-menuWindow") With some shell surface protocols, this is not allowed. The wayland QPA plugin is currently handling it by setting the parent to the topmost grabbing popup. Note, however, that this may cause positioning errors and popups closing unxpectedly. Please fix the transient parent of the popup.
mar 07 16:57:58 amd-burk xdg-desktop-portal-kde[1277]: xdp-kde-settings: Namespace  "org.gnome.desktop.a11y.interface"  is not supported
mar 07 16:57:58 amd-burk pamac-manager[18863]: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
mar 07 16:57:59 amd-burk pamac-manager[18863]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:58:01 amd-burk pamac-manager[18863]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:58:10 amd-burk pamac-manager[18863]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 16:58:11 amd-burk pamac-manager[18863]: ../gtk/gdk/wayland/gdkcursor-wayland.c:210 cursor image size (32) not an integer multiple of theme size (24)
mar 07 17:00:19 amd-burk kwin_wayland[997]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 07 17:00:22 amd-burk kwin_wayland[997]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 07 17:04:32 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 17:04:33 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 17:04:40 amd-burk kwin_wayland[997]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
mar 07 17:04:42 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 17:08:54 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 17:08:55 amd-burk kwin_wayland[997]: qt.qml.context: file:///usr/share/kwin/tabbox/compact/contents/ui/main.qml:174:13 Parameter "event" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
mar 07 17:08:55 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
mar 07 17:08:56 amd-burk kwin_wayland[997]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glDrawBuffers(unsupported buffer GL_BACK_LEFT)
But when checking the envs
COLORFGBG=15;0
COLORTERM=truecolor
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
DEBUGINFOD_URLS=https://debuginfod.archlinux.org
DESKTOP_SESSION=plasmawayland
DISPLAY=:1
DOCKER_HOST=unix:///run/user/1000/podman/podman.sock
GTK2_RC_FILES=/etc/gtk-2.0/gtkrc:/home/eriase/.gtkrc-2.0:/home/eriase/.config/gtkrc-2.0
GTK_RC_FILES=/etc/gtk/gtkrc:/home/eriase/.gtkrc:/home/eriase/.config/gtkrc
HOME=/home/eriase
ICEAUTHORITY=/run/user/1000/iceauth_aTFULz
INVOCATION_ID=50964a693ada46838d91de6ae6a9ad03
JOURNAL_STREAM=9:8590
KDE_APPLICATIONS_AS_SCOPE=1
KDE_FULL_SESSION=true
KDE_SESSION_UID=1000
KDE_SESSION_VERSION=6
KGLOBALACCELD_PLATFORM=org.kde.kwin
KONSOLE_DBUS_SERVICE=:1.107
KONSOLE_DBUS_SESSION=/Sessions/1
KONSOLE_DBUS_WINDOW=/Windows/1
KONSOLE_VERSION=241202
LANG=en_GB.UTF-8
LANGUAGE=en_GB
LC_ADDRESS=sv_SE.UTF-8
LC_COLLATE=sv_SE.UTF-8
LC_CTYPE=sv_SE.UTF-8
LC_IDENTIFICATION=sv_SE.UTF-8
LC_MEASUREMENT=sv_SE.UTF-8
LC_MESSAGES=sv_SE.UTF-8
LC_MONETARY=sv_SE.UTF-8
LC_NAME=sv_SE.UTF-8
LC_NUMERIC=sv_SE.UTF-8
LC_PAPER=sv_SE.UTF-8
LC_TELEPHONE=sv_SE.UTF-8
LC_TIME=sv_SE.UTF-8
LOGNAME=eriase
<redacted>
<redacted>
<redacted>
<redacted>
MOTD_SHOWN=pam
<redacted>
PROFILEHOME=
PWD=/home/eriase
QT_AUTO_SCREEN_SCALE_FACTOR=0
QT_LINUX_ACCESSIBILITY_ALWAYS_ON=1
QT_WAYLAND_RECONNECT=1
SESSION_MANAGER=local/amd-burk:@/tmp/.ICE-unix/1188,unix/amd-burk:/tmp/.ICE-unix/1188
SHELL=/bin/bash
SHELL_SESSION_ID=41e3f43781074c24bd2679a41594304e
SYSTEMD_EXEC_PID=992
TERM=xterm-256color
USER=eriase
WAYLAND_DISPLAY=wayland-0
WINDOWID=1
XAUTHORITY=/run/user/1000/xauth_teyRLq
XDG_CONFIG_DIRS=/home/eriase/.config/kdedefaults:/etc/xdg:/usr/share/manjaro-kde-settings/xdg
XDG_CURRENT_DESKTOP=KDE
XDG_DATA_DIRS=/home/eriase/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share
XDG_MENU_PREFIX=plasma-
XDG_RUNTIME_DIR=/run/user/1000
XDG_SEAT=seat0
XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
XDG_SESSION_CLASS=user
XDG_SESSION_DESKTOP=KDE
XDG_SESSION_ID=1
XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
XDG_SESSION_TYPE=wayland
XDG_VTNR=1
XKB_DEFAULT_LAYOUT=fo
XKB_DEFAULT_MODEL=pc105
XKB_DEFAULT_VARIANT=nodeadkeys
SHLVL=1
OLDPWD=/home/eriase
LESS_TERMCAP_mb=
LESS_TERMCAP_md=
LESS_TERMCAP_me=
LESS_TERMCAP_se=
LESS_TERMCAP_so=
LESS_TERMCAP_ue=
LESS_TERMCAP_us=
LESS=-R
LS_OPTIONS=--color=auto
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=00:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.7z=01;31:*.ace=01;31:*.alz=01;31:*.apk=01;31:*.arc=01;31:*.arj=01;31:*.bz=01;31:*.bz2=01;31:*.cab=01;31:*.cpio=01;31:*.crate=01;31:*.deb=01;31:*.drpm=01;31:*.dwm=01;31:*.dz=01;31:*.ear=01;31:*.egg=01;31:*.esd=01;31:*.gz=01;31:*.jar=01;31:*.lha=01;31:*.lrz=01;31:*.lz=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.lzo=01;31:*.pyz=01;31:*.rar=01;31:*.rpm=01;31:*.rz=01;31:*.sar=01;31:*.swm=01;31:*.t7z=01;31:*.tar=01;31:*.taz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tgz=01;31:*.tlz=01;31:*.txz=01;31:*.tz=01;31:*.tzo=01;31:*.tzst=01;31:*.udeb=01;31:*.war=01;31:*.whl=01;31:*.wim=01;31:*.xz=01;31:*.z=01;31:*.zip=01;31:*.zoo=01;31:*.zst=01;31:*.avif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:*~=00;90:*#=00;90:*.bak=00;90:*.crdownload=00;90:*.dpkg-dist=00;90:*.dpkg-new=00;90:*.dpkg-old=00;90:*.dpkg-tmp=00;90:*.old=00;90:*.orig=00;90:*.part=00;90:*.rej=00;90:*.rpmnew=00;90:*.rpmorig=00;90:*.rpmsave=00;90:*.swp=00;90:*.tmp=00;90:*.ucf-dist=00;90:*.ucf-new=00;90:*.ucf-old=00;90:
P9K_SSH=0
_P9K_SSH_TTY=/dev/pts/1
ASDF_DIR=/home/eriase/.asdf
VISUAL=nano
<redacted>
<redacted>
<redacted>
P9K_TTY=old
_P9K_TTY=/dev/pts/1
_=/usr/bin/env
and setxkbmap
Setting verbose level to 10
WARNING: Running setxkbmap against an Xwayland server
locale is C
Trying to load rules file ./rules/evdev...
Trying to load rules file /usr/share/X11/xkb/rules/evdev...
Success.
Applied rules from evdev:
rules:      evdev
model:      pc105
layout:     se
variant:    nodeadkeys
Trying to build keymap using the following components:
keycodes:   evdev+aliases(qwerty)
types:      complete
compat:     complete
symbols:    pc+se(nodeadkeys)+inet(evdev)
geometry:   pc(pc105)
xkb_keymap {
        xkb_keycodes  { include "evdev+aliases(qwerty)" };
        xkb_types     { include "complete"      };
        xkb_compat    { include "complete"      };
        xkb_symbols   { include "pc+se(nodeadkeys)+inet(evdev)" };
        xkb_geometry  { include "pc(pc105)"     };
the only env that i don’t know if it is correct is the XKB_DEFAULT_LAYOUT=fo
System info dump
  Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=650fe6ed-2034-479f-9ce2-081f608ce8fc rw quiet
    cryptdevice=UUID=e92b8294-fad6-4d8f-bc1b-9b7b507b8a07:luks-e92b8294-fad6-4d8f-bc1b-9b7b507b8a07
    root=/dev/mapper/luks-e92b8294-fad6-4d8f-bc1b-9b7b507b8a07 splash
    udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
  Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
  Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
    UEFI: American Megatrends v: 1616 date: 05/16/2023
  System RAM: total: 32 GiB available: 30.5 GiB used: 9.21 GiB (30.2%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 4800 MT/s actual: 6000 MT/s volts:
    note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: G Skill Intl part-no: F5-6000J3238F16G serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 4387 min/max: 400/5573 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 4387 2: 4387 3: 4387
    4: 4387 5: 4387 6: 4387 7: 4387 8: 4387 9: 4387 10: 4387 11: 4387 12: 4387
    13: 4387 14: 4387 15: 4387 16: 4387 bogomips: 144054
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
    avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
    avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT /
    6900 XT] driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1, Writeback-1
    bus-ID: 03:00.0 chip-ID: 1002:73bf class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-4,HDMI-A-2,Writeback-2 bus-ID: 0e:00.0 chip-ID: 1002:164e
    class-ID: 0300 temp: 35.0 C
  Device-3: Lenovo Performance Camera driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.2.1:13
    chip-ID: 17ef:4839 class-ID: 0102 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-3 model: Samsung LS49A950U serial: <filter> built: 2021 res:
    mode: 5120x1440 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2 chroma: red:
    x: 0.678 y: 0.310 green: x: 0.275 y: 0.655 blue: x: 0.141 y: 0.055 white:
    x: 0.314 y: 0.329 size: 1192x336mm (46.93x13.23") diag: 1238mm (48.8")
    modes: 5120x1440, 3840x1080, 3840x2160, 3440x1440, 2560x1440, 1920x1200,
    1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480, 640x480,
    720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid: unknown
    tag 112
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi surfaceless:
    drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi
    navi21 LLVM 19.1.7 DRM 3.61 6.12.17-1-MANJARO) device-ID: 1002:73bf
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.304 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6900 XT (RADV NAVI21) driver: N/A device-ID: 1002:73bf
    surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD Radeon
    Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
    de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:1640
    class-ID: 0403
  Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:6
    chip-ID: 0b05:1a52 class-ID: 0300
  Device-4: Lenovo Performance Camera driver: snd-usb-audio,uvcvideo
  Device-5: Texas Instruments PCM2902 Audio Codec
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-2.2.3.4.4:19 chip-ID: 08bb:2902 class-ID: 0300
  API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-alsa
  Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0a:00.0 chip-ID: 14c3:0608
    class-ID: 0280
  IF: wlp10s0 state: up mac: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:9 chip-ID: 0e8d:0608
  Device-1: luks-e92b8294-fad6-4d8f-bc1b-9b7b507b8a07 maj-min: 254:0
    type: LUKS dm: dm-0 size: 931.21 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 931.22 GiB
  Local Storage: total: 5.46 TiB used: 712.68 GiB (12.8%)
    model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 111130WD temp: 34.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1CH164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC27 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS541010A9E680
    tech: HDD rpm: 5400 serial: <filter> fw-rev: A560 scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD20EZRX-00DC0B0 size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0
    tech: N/A serial: <filter> fw-rev: 2021 scheme: MBR
  ID-1: / raw-size: 931.21 GiB size: 915.52 GiB (98.32%)
    used: 322.47 GiB (35.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-e92b8294-fad6-4d8f-bc1b-9b7b507b8a07 label: N/A
    uuid: 650fe6ed-2034-479f-9ce2-081f608ce8fc
    used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: C912-EB06
  ID-3: /run/media/eriase/2.5 raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
    used: 124.49 GiB (13.6%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: 2.5
    uuid: 1be2e98d-9ac2-4582-92ad-3407791d63a4
  ID-4: /run/media/eriase/4f3061a3-676a-4912-b2ca-c32e25fb3dd5
    raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 117.99 GiB (6.4%) fs: ext4
    dev: /dev/sda1 maj-min: 8:1 label: 3.5
    uuid: 4f3061a3-676a-4912-b2ca-c32e25fb3dd5
  ID-5: /run/media/eriase/Backups raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 147.73 GiB (7.9%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: Backups
    uuid: 8A4E7F3A4E7F1E5F
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:6 info: ASUSTek USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
  Device-2: 1-7:7 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
    serial: <filter>
  Hub-2: 1-8:8 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-11:9 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-7: 5-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Hub-8: 5-2.2:12 info: Texas Instruments ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8242
  Device-1: 5-2.2.1:13 info: Lenovo Performance Camera type: video,audio
    driver: snd-usb-audio,uvcvideo interfaces: 6 rev: 2.1
  Hub-9: 5-2.2.3:14 info: Prolific USB 2.0 Hub ports: 4 rev: 2.0
    chip-ID: 067b:2586 class-ID: 0900
  Device-1: 5-2.2.3.1:15 info: [Maxxter] Optical Gaming Mouse [Xtrem]
    type: mouse,keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 18f8:0f97 class-ID: 0300
  Device-2: 5-2.2.3.2:16 info: Holtek USB-HID Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 04d9:a231 class-ID: 0300
  Device-3: 5-2.2.3.3:17 info: Contour Design Rollermouse Red type: mouse,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b33:1004 class-ID: 0300
  Hub-10: 5-2.2.3.4:18 info: Prolific USB 2.0 Hub ports: 4 rev: 2.0
  Device-1: 5-2.2.3.4.4:19 info: Texas Instruments PCM2902 Audio Codec
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Device-2: 5-2.3:4 info: Western Digital Elements Desktop (WDBAAU)
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 1058:1021 class-ID: 0806 serial: <filter>
  Hub-11: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-12: 6-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-13: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-14: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 55.6 C mobo: 38.0 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 36.0 C device: amdgpu temp: 41.0 C mem: 42.0 C
    fan: 0 watts: 17.00
  Packages: 1550 pm: pacman pkgs: 1525 libs: 456 tools: pamac pm: appimage
    pkgs: 0 pm: flatpak pkgs: 25
    1: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    2: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    3: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    5: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 493
  1: cpu: 23.1% command: clamd pid: 772 mem: 1427.2 MiB (4.5%)
  2: cpu: 5.1% command: firefox pid: 2476 mem: 810.8 MiB (2.5%)
  3: cpu: 3.2% command: kwin_wayland pid: 997 mem: 367.4 MiB (1.1%)
  4: cpu: 2.6% command: firefox pid: 22325 mem: 65.3 MiB (0.2%)
  5: cpu: 2.5% command: firefox pid: 16898 mem: 296.6 MiB (0.9%)
  Memory top: 5 of 493
  1: mem: 1427.2 MiB (4.5%) command: clamd pid: 772 cpu: 23.1%
  2: mem: 810.8 MiB (2.5%) command: firefox pid: 2476 cpu: 5.1%
  3: mem: 500.4 MiB (1.6%) command: plasmashell pid: 1247 cpu: 0.1%
  4: mem: 453.6 MiB (1.4%) command: firefox pid: 6873 cpu: 0.4%
  5: mem: 443.0 MiB (1.4%) command: firefox pid: 2875 cpu: 0.7%
  Processes: 493 Power: uptime: 1h 4m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
After booting into the terminal session instead of a default session i noticed that the keys worked… don’t know what i did exactly except trying to set the keyboards a few time, but now it works ¯_(ツ)_/¯.
And the XKB_DEFAULT_LAYOUT=se is now correct.
God **** i hate when it just fixes itself and i can’t find the root solution or cause.
