Sway theme color?
Hey i have just switched to sway, i was wondering why code titlebar is white when i set the theme in Kvantum to ArcDark?
kvantum only affects the application theme, i.e. that which is shown inside the application window. It does not affect the window border — which includes the title bar — itself. For that you need to choose a different window decoration — that’s what the window border and title bar are called.
do i have to change a config file or just do it using an app?
I’d say it’s probably a configuration file in your home directory, but I’m no expert on Sway. :man_shrugging:
alright i will look it up thank you for your tip
man sway.5
so many commands, i couldn’t find the one for setting titlebar color :frowning:
