the release & prelease don’t boot on my rpi4 4gb, just a blinking cursor in the upper right corner.
guess i’ll be sticking with xfce for now.
This thread is not about sway
for ARM - you have to grab that from here:
See also:
my bag, anyways i used the manjaro-arm-installer to grab it.
i’m up & running already.
just fine tuning.
hopefully it’s not to much difference from x86 i can still help out.
I installed this a few months back and last week I started getting this error on updates:
sudo pacman -Syyu
error: manjaro-sway: key "A44C644D792767CED7941AFEABB2075D5F310CF8" is unknown
:: Import PGP key A44C644D792767CED7941AFEABB2075D5F310CF8? [Y/n]
error: key "A44C644D792767CED7941AFEABB2075D5F310CF8" could not be looked up remotely
core 169.2 KiB 258 KiB/s 00:01 [####################################################################] 100%
extra 1923.9 KiB 2.62 MiB/s 00:01 [####################################################################] 100%
community 6.6 MiB 7.19 MiB/s 00:01 [####################################################################] 100%
multilib 178.2 KiB 17.4 MiB/s 00:00 [####################################################################] 100%
manjaro-sway 13.9 KiB 0.00 B/s 00:00 [####################################################################] 100%
manjaro-sway.sig 438.0 B 0.00 B/s 00:00 [####################################################################] 100%
error: failed to update manjaro-sway (invalid or corrupted database (PGP signature))
error: failed to synchronize all databases
Any ideas @boredland ?
Per https://github.com/Manjaro-Sway/manjaro-sway try
pacman-key --keyserver keys.openpgp.org --recv-key A44C644D792767CED7941AFEABB2075D5F310CF8
This is the result I get from the command above…
gpg: keyserver receive failed: Server indicated a failure
==> ERROR: Remote key not fetched correctly from keyserver.
And I am online, no proxies or vpn’s, etc.
Are you behind any proxies, or anything that may be sniffing your traffic or on a low-bandwidth connection? I ran the same above command with no issues and it worked for me to get my system up-to-date.
Also, @jeaness , check out this GitHub issue:
I’m not sure if this is a GitHub issue or user issue, but I just installed Manjaro Sway into a GNOME Boxes/libvirt virtual machine, and I cannot get the MOD(super)+SHIFT+? to pop up the help menu, nor get the MOD+[h/j/k/l] movement to work, but the MOD+[arrow-up/down/left/right] work. I even redefined it in the ~/.config/sway/config.d/00-user-config
file as well to use the vim style navigation. Anyone else experiencing these issues?
I’m also having an issue where after I install all the latest updates doing sudo pacman -Syyu
and reboot, I can no longer log back in as my user or the manjaro user.
Add “nameserver 8.8.8.8” to /etc/resolv.conf
just tried and works ootb. perhaps you haven the correct keyboard layout in vm/host?
did you $unbindsym the keys you wanted to use? perhaps they/some are already taken…
this should be fixed now. for me it works ootb in a virgin boxes install.
I’m closing this due to unclear focus. Please create issues in github if you’d like support to specific issues.
