Where can we keep track of changes? Maybe a changelog topic here?
I installed it as my daily driver and found a first issue. Would be glad to help
Sent a simple PR to add āArea screenshotā support that I use all the time at work.
Is this the correct workflow to contribute?
And
I donāt see the sway community edition in that link. Is it in a special branch?
In the iso-profiles repo there is a sway branch where we work at the moment.
Since we are still in development, we are currently working on how to handle official release builds and how the procedures for that are handled. We are working together with the Manjaro team, but since we are doing this in our spare time it will take some time.
Thank you for your inputs and recommendations towards this project.
Hi there, ā
I have downloaded Manjaro Sway 21.0 (community edition) and I would like to install it in a USB stick, so as to have a persistent bootable Sway installation without modifying my laptop hard disk.
I have used RPI imager to create a live USB stick with Sway, I have booted from it in my laptop (ASUS ZenBook) and immediately the wizard to install it appears. I select my other USB stick (/dev/sbd) in the drop down menu for āSelect storage deviceā and I see that the wizard says āThe EFI system partition at /dev/nvme0nn1p1 will be used for starting Manjaroā.
Just to clarify, partition /dev/nvme0n1 is the main hard disk of my laptop, where Windows 10 is installed, which I would like to keep unaltered.
In the last screen of the wizard, under partitions it shows both the main hard disk (/dev/nvme0nn1) and the USB stick (/dev/sdb), and it says:
I understand steps 1, 2 and 4, but I am not sure about 3.
I would like to understand what step 3 above means exactly and to confirm that it will not modify the Windows Boot Manager of the main partition.
Thanks for your help in advance and sorry if my question is a bit basicā¦
Cheers, Manuel
you want to disconnect your main drive temporarily so it isnāt touched/found.
Thanks. Shall I interpret your reply as that it does modify my main drive? Seems like it.
I suppose that to follow your suggestion I would need to open the laptop and unwire the disk⦠Itās a companyās work laptop, Iād prefer not to do that.
no rear access?
Hi Kerry, not sure what you mean by rear access. The computer is not a workstation, itās a laptop (netbook). I donāt even have a proper screwdriver, out of question to open it.
I just would like to know whether the third option in my list would actually change anything in the boot manager of the computer. If it does, I will not proceed with the installation. That would be okay, I just need to know.
I will only proceed with the installation if someone can confirm that that step is just about mounting the main drive, not actually writing to itā¦
that option sets the bootloader on the main drive to boot the usb.
you need the bootloader on the usb.
an example, the usb created that way will only boot on that laptop, because theres no bootloader on the usb it self.
By that, I understand it does modify the main drive. Would that affect how Windows is loaded when no USB is used to boot, or even prevent normal startup into Windows?
In any case, I havenāt had this problem when I did exactly the same thing with another distro. When I select a drive, thatās the one where everything is installed⦠Maybe something to improve in Sway?
ok. have not been using firefox for years, can you recommend an addon?
Please use vimium! Itās definitely more stable and responsive, feature rich and more actively developed than the one @Chrysostomus recommended.
http://vimium.github.io/
you guys most really be keyboarding it up.
i prefer a mix of both keyboard & mouse, i like to lean back in my chair & just use the mouse most of the time, so i add clickable elements to my waybar, launchers & click to close.
Registered here to say thanks @simonb @boredland (and Chrysostomus, canāt mention more than 2 users) for this awesome distro.
zsh, powerlevel10k, git-shortcuts, neovim, nice customization out-of-the-box. It feels already polished.
Iām still trying to understand how to customize top bar (looks like itās not a native sway bar?) and how to remove flash/transparency on switching windows. Iāve been using Manjaro i3 for 3 years and I think Iāll never return back
waybar is the panel, it has itās own ~/.config/waybar/config
very easy to understand.
Go to /etc/sway/config.d/99-autostart-applications.conf and comment out the line containing āflashfocusā.
This will be overwritten every time manjaro-sway-settings gets updated, though.
yeah, I think the solution for that is easy:
Iāll remove the fallback animation when flashfocus isnāt installed. After that you can just uninstall flashfocus and theyāre gone.
I donāt think this is a sway question, since sway uses the general manjaro installer (calamares).
ill grab a copy, but my internet is acting up, iām waiting on a new box from spectrum, my downloads keep dying, cause the net cuts out. torrents say like 999 days
, so i have to try direct download or wget.
