Swat 4 Wine No Sound
Here’s my specs and info
  Kernel: 6.1.53-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=40809886-d17c-433b-876f-89a03d053b64 rw quiet splash apparmor=1
  Desktop: GNOME v: 44.4 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <superuser required>
    UEFI: American Megatrends v: F21 date: 02/08/2018
  System RAM: total: 16 GiB available: 15.57 GiB used: 3.85 GiB (24.7%)
  Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
    note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
    stepping: 1 microcode: 0x8001129
    L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
    desc: 2x8 MiB
  Speed (MHz): avg: 1764 high: 2796 min/max: 1550/3200 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1308 2: 1550
    3: 1270 4: 1550 5: 2793 6: 2796 7: 1550 8: 1550 9: 2333 10: 1550 11: 1550
    12: 1375 bogomips: 76670
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm
    lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
    popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
    smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
    syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Type: spec_rstack_overflow mitigation: safe RET, no microcode
  Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
    driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-08) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 08:00.0 chip-ID: 10de:1c02 class-ID: 0300
  Device-2: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 046d:0894
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce GTX 1060
    3GB/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 08:00.1 chip-ID: 10de:10f1 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
    chip-ID: 1022:1457 class-ID: 0403
  Device-3: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.1.53-1-MANJARO status: kernel-api with: aoss
  Server-2: JACK v: 1.9.22 status: off tools: jack_control
  Server-3: PipeWire v: 0.3.80 status: off with: 1: pipewire-media-session
    status: off 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
  Server-4: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
    lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
    v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0
    chip-ID: 14e4:43a0 class-ID: 0280
  IF: wlp7s0 state: down mac: <filter>
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0b05:190e
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
  Local Storage: total: 3.41 TiB used: 1.05 TiB (30.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZAZ-00L9GB0
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500312CS
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 5900 serial: <filter> fw-rev: CA12 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 1TB
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 147.62 GiB (64.8%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: 40809886-d17c-433b-876f-89a03d053b64
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
    uuid: E832-7B45
  ID-3: /run/media/nicholas/fourth-disk raw-size: 931.51 GiB
    size: 915.82 GiB (98.31%) used: 716.74 GiB (78.3%) fs: ext4 dev: /dev/sdd
    maj-min: 8:48 label: fourth-disk uuid: 1be4d25b-4ff6-40b0-a5c7-dfe6cc409b83
  ID-4: /run/media/nicholas/second disk raw-size: 434.51 GiB
    size: 426.62 GiB (98.18%) used: 199.95 GiB (46.9%) fs: ext4 dev: /dev/sdc2
    maj-min: 8:34 label: second disk uuid: 1ec047b4-ec64-4d28-8893-f16ad7899256
  ID-5: /run/media/nicholas/third-disk raw-size: 1.82 TiB
    size: 1.79 TiB (98.37%) used: 10.93 GiB (0.6%) fs: ext4 dev: /dev/sda
    maj-min: 8:0 label: third-disk uuid: 31f2d06a-293c-46c3-9216-27dc993cfb4e
  ID-1: /dev/sdc1 maj-min: 8:33 size: 31.25 GiB fs: swap label: N/A
    uuid: 14863704-322a-453c-b7a5-87bba34bb094
  Device-1: 1-1:2 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
  Device-2: 1-2:3 info: Logitech CrystalCam type: video,audio
    chip-ID: 046d:0894 class-ID: 0102 serial: <filter>
  Device-1: 3-3:2 info: Ducky One 3̠ type: HID,keyboard,mouse
    driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1011 class-ID: 0300
    serial: <filter>
  Device-2: 3-4:3 info: Logitech G502 Proteus Spectrum Optical Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
  Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 34.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 330 Uptime: 4h 16m wakeups: 0 Init: systemd v: 254
  Packages: 2353 pm: pacman pkgs: 2339 libs: 577 tools: gnome-software,pamac
  pm: flatpak pkgs: 5 pm: snap pkgs: 9 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.29
As the title says, Swat 4 does not have any sound. It does during the opening cutscenes i.e. company logos, credits, etc, but there’s a crackle when clicking through them. How do I go about figuring out what the problem is? Any possible solutions?
How do you start it? Is it from STEAM? From another launcher?
Do you use Proton, or a modified version of it (like the Glorious Eggrol version of Proton)? Or do you use plain WINE from the repositories?
Just plain Wine, I run the .exe from my games folder.
Then it is expected a 3D games has issues, unmodified WINE is not really meant to run games.
Try to setup a launcher from Lutris, so you run your game with a proper WINE for games (that you can select in Lutris), it will probably work properly from there.
In Lutris you can import a locally installed game with the + icon, and configure it with the WINE runner, and select WINE version “Lutis-7.2.2” or similar to use a proper “gamified” WINE. You may need to create/configure a folder where to stor the WINE prefix for this game, usually you use ~/Games/yourGamePrefixHere/ but you can store it where you want (it is basically the Windows environment files for WINE for this game, a few GB usually).
That seemed to work, thank you!
