I used this script to install the ultra light version (only cli).
Have ONLY installed lm_sensors htop wget & cifs-utils
I just noticed the swap in the block devices.
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk0 179:0 0 7.4G 0 disk
├─mmcblk0p1 179:1 0 457.8M 0 part /boot
└─mmcblk0p2 179:2 0 6.9G 0 part /
zram0 253:0 0 11.4G 0 disk [SWAP]
I do have the 8gb version but, 11.4G? And my sd-card is 8G… xD
Swapon:
NAME TYPE SIZE USED PRIO
/dev/zram0 partition 11.4G 0B 100
df -h looks pretty normal though.
Filesystem Size Used Avail Use% Mounted on
dev 3.6G 0 3.6G 0% /dev
run 3.9G 488K 3.9G 1% /run
/dev/mmcblk0p2 6.8G 1.7G 4.8G 26% /
tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs 3.9G 0 3.9G 0% /tmp
/dev/mmcblk0p1 458M 55M 403M 12% /boot
tmpfs 782M 0 782M 0% /run/user/1000
//192.168.1.10/raspberry-pi 2.8T 1.4T 1.5T 49% /mnt/backup
And nothing strange in my fstab:
# Static information about the filesystems.
# See fstab(5) for details.
# <file system> <dir> <type> <options> <dump> <pass>
PARTUUID=867145fb-01 /boot vfat defaults,noexec,nodev,showexec 0 0
PARTUUID=867145fb-02 / ext4 defaults 0 1
inxi:
Kernel: 6.1.34-1-MANJARO-ARM-RPI arch: aarch64 bits: 64 compiler: gcc
v: 12.1.0 parameters: coherent_pool=1M 8250.nr_uarts=0
snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1
snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0
smsc95xx.macaddr=E4:5F:01:BD:BD:BD vc_mem.mem_base=0x3ec00000
vc_mem.mem_size=0x40000000 root=PARTUUID=867145fb-02 rw rootwait
console=ttyS0,115200 console=tty3 selinux=0 quiet splash
plymouth.ignore-serial-consoles smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0
kgdboc=ttyS0,115200 usbhid.mousepoll=8 audit=0
Console: pty pts/0 Distro: Manjaro ARM base: Arch Linux
Type: ARM System: Raspberry Pi 4 Model B Rev 1.5 details: BCM2835 rev: d03115
serial: <filter>
System RAM: available: 7.63 GiB used: 270.7 MiB (3.5%) gpu: 76 MiB
RAM Report: missing: Required tool dmidecode not installed. Check
--recommends
Info: model: N/A variant: cortex-a72 bits: 64 type: MCP arch: ARMv8 family: 8
model-id: 0 stepping: 3
Topology: cpus: 1x cores: 4 smt: N/A cache: L1: 320 KiB
desc: d-4x32 KiB; i-4x48 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 600 min/max: 600/1500 scaling: driver: cpufreq-dt
governor: schedutil cores: 1: 600 2: 600 3: 600 4: 600 bogomips: 432
Features: asimd cpuid crc32 evtstrm fp
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2 status: Vulnerable
Device-1: bcm2711-hdmi0 driver: vc4_hdmi v: N/A bus-ID: N/A
chip-ID: brcm:fef00700 class-ID: hdmi
Device-2: bcm2711-hdmi1 driver: vc4_hdmi v: N/A bus-ID: N/A
chip-ID: brcm:fef05700 class-ID: hdmi
Device-3: bcm2711-vc5 driver: vc4_drm v: N/A bus-ID: N/A chip-ID: brcm:gpu
class-ID: gpu
Display: server: No display server data found. Headless machine?
tty: 212x26
API: N/A Message: No display API data available in console. Headless
machine?
Device-1: bcm2711-hdmi0 driver: vc4_hdmi bus-ID: N/A chip-ID: brcm:fef00700
class-ID: hdmi
Device-2: bcm2711-hdmi1 driver: vc4_hdmi bus-ID: N/A chip-ID: brcm:fef05700
class-ID: hdmi
API: ALSA v: k6.1.34-1-MANJARO-ARM-RPI status: kernel-api tools: N/A
Device-1: bcm2835-mmc driver: mmc_bcm2835 v: N/A port: N/A bus-ID: N/A
chip-ID: brcm:fe300000 class-ID: mmcnr
IF: wlan0 state: down mac: <filter>
Device-2: bcm2711-genet-v5 driver: bcmgenet v: N/A port: N/A bus-ID: N/A
chip-ID: brcm:fd580000 class-ID: ethernet
IF: end0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v6: <filter> scope: link
Device-1: pl011 driver: uart_pl011 bus-ID: N/A chip-ID: arm:fe201000
class-ID: serial
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: not found
rfk-block: hardware: no software: no address: see --recommends
Device-2: pl011 driver: N/A bus-ID: N/A chip-ID: arm:serial0
class-ID: serial
Local Storage: total: 7.37 GiB used: 1.66 GiB (22.5%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: Silicon Power model: SPCC
size: 7.37 GiB block-size: physical: 512 B logical: 512 B tech: SSD
serial: <filter> scheme: MBR
ID-1: / raw-size: 6.89 GiB size: 6.7 GiB (97.30%) used: 1.61 GiB (23.9%)
fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2 label: ROOT_MNJRO
uuid: 07250076-91dc-4969-bbf7-34b29e0d00c2
ID-2: /boot raw-size: 457.8 MiB size: 457.5 MiB (99.94%)
used: 54.7 MiB (12.0%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
label: BOOT_MNJRO uuid: 91BC-5471
ID-3: /mnt/backup raw-size: N/A size: 2.73 TiB used: 1.32 TiB (48.4%)
fs: cifs dev: /dev/raspberry-pi
Kernel: swappiness: 60 (default) cache-pressure: 80 (default 100)
ID-1: swap-1 type: zram size: 11.44 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 1-1:2 info: VIA Labs Hub ports: 4 rev: 2.1
chip-ID: 2109:3431 class-ID: 0900
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 40.4 C mobo: N/A
Processes: 150 Uptime: 27m Init: systemd v: 253 default: graphical
tool: systemctl Compilers: N/A Packages: pm: pacman pkgs: 218 libs: 55
Shell: Bash v: 5.1.16 running-in: pty pts/0 (SSH) inxi: 3.3.27
Advice?
