Hello,
I have manualy added the following entry to fstab:
UUID=uuid-of-existing-swap-partition none swap defaults 0 0
But it doesn’t seem to work. When executing sudo mount -av the response for this entry is ignored. What’s wrong?
Hello,
A swap partition is not to be mounted, it is to be enabled: Swap - ArchWiki
Just look at the return of command :
swapon
Yes, swapon says:
/dev/nvme0n1p2 partition 24G 0B -2
It works. Thanks.
