Hello Manjaro Community,
I’m experiencing an issue with swap behavior after changing my swap file size from 4 GB to 8 GB. Despite rigorous tuning, the kernel refuses to use swap under memory pressure, causing system crashes.
System Details
- Manjaro: 6.12.39-1 LTS (BSPWM)
- Hardware:
- CPU: Intel Core i3-4170 (4 threads)
- RAM: 12 GB DDR3
- Storage: 1 TB HDD (ext4 root, swap file on the same filesystem)
- Kernel Parameters:
transparent_hugepage=never udev.log_priority=3 nvidia-drm.modeset=1
Issue Summary
- Previously: The 4 GB swap file was working perfectly (used when RAM was full)
- Now: After creating the 8 GB swap file (using
fallocate
/dd
), the swap file shows no activity even with: vm.swappiness=100
- THP disabled
- Default boot pressure setting Aggressive cache
- Consequence: System crashes when RAM is about to run out (10-11 GB used)
Diagnostic evidence
Swap is active, but unused:
$ free -h
total used free shared buff/cache available
Mem: 11Gi 10Gi 768Mi 223Mi 959Mi 1.3Gi
Swap: 8.0Gi 524Ki 8.0Gi -
Kernel messages show swap initialization but no activity during pressure.
What I’ve Tried
- Created swapfile via both
fallocate
anddd
(withconv=fdatasync
). - Tested a dedicated swap partition and direct
/dev/loopX
mapping. - Swappiness set from default 60 → 100.
- Disabled Transparent HugePages.
- Tuned kernel parameters:
vm.vfs_cache_pressure=150–200
vm.min_free_kbytes=20480–51200
- Switched kernels (currently 6.12.39-1 LTS).
- Installed and configured earlyoom.
- Relaxed overcommit (
vm.overcommit_memory=1
,vm.overcommit_ratio=100
Full Technical Report
===== System Information =====
Kernel: 6.12.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=0112145f-5715-4b71-a6cf-525bdad5b9ba rw quiet splash
Desktop: bspwm v: 0.9.10 with: polybar tools: avail: i3lock vt: 2 dm: SDDM
Type: Desktop Mobo: ASRock model: H81M-VG4 R2.0 serial: <superuser required>
uuid: <superuser required> BIOS: American Megatrends v: P1.30
date: 04/24/2015
Info: model: Intel Core i3-4170 bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3697 min/max: 800/3700 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 3697 2: 3697 3: 3697 4: 3697 bogomips: 29606
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: eVga.com. driver: nvidia
v: 575.64 alternate: nouveau,nvidia_drm non-free: 550-570.xx+ status: current
(as of 2025-04; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 2 speed: 5 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DVI-I-1 bus-ID: 01:00.0 chip-ID: 10de:1380 class-ID: 0300
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8 driver: X:
loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 84 s-size: 413x232mm (16.26x9.13")
s-diag: 474mm (18.65")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Samsung T19B300
built: 2010 res: mode: 1366x768 hz: 60 scale: 100% (1) dpi: 85 gamma: 1.4
size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes:
max: 1366x768 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2
memory: 1000 MiB
API: Vulkan v: 1.4.313 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 750 Ti driver: nvidia v: 575.64 device-ID: 10de:1380
surfaces: N/A
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: eVga.com. driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
API: ALSA v: k6.12.34-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 931.51 GiB used: 534.17 GiB (57.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA100
tech: HDD rpm: 7200 serial: <filter> fw-rev: A750 scheme: MBR
ID-1: / raw-size: 99.19 GiB size: 97.07 GiB (97.87%) used: 79.77 GiB (82.2%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: file size: 8 GiB used: 524 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 34 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 40%
Memory: total: 12 GiB available: 11.62 GiB used: 4.74 GiB (40.8%)
Processes: 216 Power: uptime: 28m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 4.56 GiB
services: power-profiles-daemon,upowerd Init: systemd v: 257
Packages: 1826 pm: pacman pkgs: 1799 libs: 548 tools: pamac,yay
pm: flatpak pkgs: 27 Compilers: clang: 20.1.6 gcc: 15.1.1 Shell: Zsh v: 5.9
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
===== Memory and Swap Status =====
total usado libre compartido búf/caché disponible
Mem: 11Gi 4,9Gi 5,7Gi 239Mi 1,4Gi 6,7Gi
Inter: 8,0Gi 524Ki 8,0Gi
NAME TYPE SIZE USED PRIO
/swapfile file 8G 524K -2
SwapCached: 0 kB
SwapTotal: 8388604 kB
SwapFree: 8388080 kB
Zswap: 0 kB
Zswapped: 0 kB
===== Swap Configuration =====
-rw------- 1 root root 8,0G jul 21 14:42 /swapfile
/swapfile none swap sw 0 0
===== Kernel Parameters =====
vm.swappiness = 60
vm.vfs_cache_pressure = 100
vm.min_free_kbytes = 51200
vm.overcommit_memory = 0
===== THP Configuration =====
always madvise [never]
always defer defer+madvise madvise [never]
===== Relevant Kernel Messages =====
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=0112145f-5715-4b71-a6cf-525bdad5b9ba rw quiet splash transparent_hugepage=never udev.log_priority=3 nvidia-drm.modeset=1
[ 0.000000] DMI: Memory slots populated: 2/2
[ 0.007504] ACPI: Reserving FACP table memory at [mem 0xdd8fc7c0-0xdd8fc8cb]
[ 0.007506] ACPI: Reserving DSDT table memory at [mem 0xdd8f2190-0xdd8fc7be]
[ 0.007506] ACPI: Reserving FACS table memory at [mem 0xdd913080-0xdd9130bf]
[ 0.007507] ACPI: Reserving APIC table memory at [mem 0xdd8fc8d0-0xdd8fc941]
[ 0.007507] ACPI: Reserving FPDT table memory at [mem 0xdd8fc948-0xdd8fc98b]
[ 0.007508] ACPI: Reserving SSDT table memory at [mem 0xdd8fc990-0xdd8fcec8]
[ 0.007509] ACPI: Reserving SSDT table memory at [mem 0xdd8fced0-0xdd8fd9a7]
[ 0.007509] ACPI: Reserving SSDT table memory at [mem 0xdd8fd9a8-0xdd8fdb6e]
[ 0.007510] ACPI: Reserving MCFG table memory at [mem 0xdd8fdb70-0xdd8fdbab]
[ 0.007510] ACPI: Reserving HPET table memory at [mem 0xdd8fdbb0-0xdd8fdbe7]
[ 0.007511] ACPI: Reserving SSDT table memory at [mem 0xdd8fdbe8-0xdd8fdf54]
[ 0.007511] ACPI: Reserving SSDT table memory at [mem 0xdd8fdf58-0xdd9013ea]
[ 0.007512] ACPI: Reserving AAFT table memory at [mem 0xdd9013f0-0xdd9016aa]
[ 0.007744] Early memory node ranges
[ 0.028181] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.028182] PM: hibernation: Registered nosave memory: [mem 0x0009d000-0x000fffff]
[ 0.028184] PM: hibernation: Registered nosave memory: [mem 0xcb24e000-0xcb254fff]
[ 0.028185] PM: hibernation: Registered nosave memory: [mem 0xcb9a5000-0xcbbdcfff]
[ 0.028186] PM: hibernation: Registered nosave memory: [mem 0xdd614000-0xdd819fff]
[ 0.028187] PM: hibernation: Registered nosave memory: [mem 0xdd86e000-0xddffefff]
[ 0.028188] PM: hibernation: Registered nosave memory: [mem 0xde000000-0xffffffff]
[ 0.033340] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=0112145f-5715-4b71-a6cf-525bdad5b9ba rw quiet splash transparent_hugepage=never udev.log_priority=3 nvidia-drm.modeset=1
[ 0.105725] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.122382] Freeing SMP alternatives memory: 40K
[ 0.130278] Memory: 11933200K/12521240K available (18432K kernel code, 2672K rwdata, 14344K rodata, 4284K init, 4280K bss, 578804K reserved, 0K cma-reserved)
[ 0.130557] x86/mm: Memory block size: 128MB
[ 0.266615] Non-volatile memory driver v1.3
[ 0.471682] Freeing initrd memory: 235800K
[ 0.702959] Freeing unused decrypted memory: 2028K
[ 0.704520] Freeing unused kernel image (initmem) memory: 4284K
[ 0.706318] Freeing unused kernel image (rodata/data gap) memory: 2040K
[ 8.802198] systemd[1]: Activating swap /swapfile...
[ 9.313280] Adding 8388604k swap on /swapfile. Priority:-2 extents:1693 across:103645184k
[ 9.313443] systemd[1]: Activated swap /swapfile.
[ 9.313676] systemd[1]: Reached target Swaps.
===== Key Releases =====
Linux martin-manjaro 6.12.34-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu, 19 Jun 2025 15:49:06 +0000 x86_64 GNU/Linux
linux612 6.12.34-1
linux-firmware 20250508.788aadc8-2
systemd 257.6-1
I appreciate any advice, suggestions or help, as I am completely lost on how to solve this problem. I can also provide more information if needed.
