Char
23 January 2023 16:07
1
Trying to convert video to 60fps but got the error
here is the log file
21:18:35.787: ===== Starting mpv ======
21:18:35.787: Command line: /usr/bin/mpv /mnt/be9fd59c/clips/trainonroad.mp4 --o=/mnt/be9fd59c/clips/trainonroad.SVP.temporary.mkv --no-audio --no-sub --no-sub-auto --input-ipc-server=/tmp/mpvencodesocket --input-media-keys=no --no-msg-color --vf=vapoursynth:/home/sim/.local/share/SVP4/scripts/ffff.py:4:3 --of=matroska --ovc=libx264 --ovcopts=preset=slow,crf=18,threads=3
21:18:36.009: Option vf: vapoursynth doesn't exist.
21:18:36.009: Error parsing option vf (option parameter could not be parsed)
21:18:36.009: Setting commandline option --vf=vapoursynth:/home/sim/.local/share/SVP4/scripts/ffff.py:4:3 failed.
21:18:36.009: Exiting... (Fatal error)
21:18:36.016: (!!!) Intermediate file may be broken: /mnt/be9fd59c/clips/trainonroad.SVP.temporary.mkv
21:18:36.016: ===== mpv exited with code 1 =====
it says âvapoursynth doesnât existâ but it was pre installed
it says that the option parameter canât be parsed (it canât make âsenseâ of what you are trying to tell it),
not that âvapoursynthâ doesnât exist
when I run:
mpv --vf help
a video filter named âvapoursynthâ is not among the filters listed
vapoursynth is NOT part of the default âmpvâ package from the repositories.
instead, try to install âmpv-gitâ from aur AFTER you have installed vapoursynth. then, mpv is being built with vapoursynth support.
you can confirm this by searching the terminal output of compiling âmpv-gitâ.
No, but it is a dependency of svp-bin in the AUR.
@Char How did you install SVP?
Char
24 January 2023 04:13
5
Yochanan:
it was in AUR, I installed it from there
Char
24 January 2023 04:16
6
mpv --vf help î˛ 1 â
Error parsing commandline option vf: option requires parameter
Make sure you're using e.g. '--vf=value' instead of '--vf value'.
Char
24 January 2023 04:56
7
So I only need to install mpv-git from AUR since vapoursynth was pre-installed in manjaro , right?
Yes.
https://aur.archlinux.org/packages/svp-bin
mpv-git (mpv-full-git , mpv-amd-full-git , mpv-full-build-git ) (optional) â needed for mpv vapoursynth support
Itâs an optional dependency. That is why you where not âforcedâ to replace the mpv version you already have.
Char
24 January 2023 11:01
9
Thank you so much everyone
system
Closed
27 January 2023 01:01
10
