What happen
After updating to Plasma6, GTK3.0 applications (like Thunar) don’t show SVG icons.
As in the picture, breeze-dark icon theme doesn’t work properly. Adwaita is used instead of breeze-dark.(This is a screenshot of Thunar)
After a while, I found SVG icons are not rendered in GTK applications. (and fallback to ugly icons)
To reproduce, I tested the PlasmaXDark icon theme which also uses SVG icons.
Reproduce
1. PlasmaXDark
PlasmaXDark is also broken. As you can see, folder icons are ugly.
The reason why the “Pictures” icons are rendered correctly is that the PlasmaXDark inherits the gnome icon theme which uses PNG icons.
“Pictures” icon at /usr/share/icons/gnome/48x48/places/folder-pictures.png
2. Change folder icon
In ~/.local/share/icons/PlasmaXDark/48x48/places/, when I change folder.svg to folder.tmp.svg and put folder.png from gnome icon theme as shown in the picture,
folder icons rendered correctly after reloading the PlasmaXDark icon theme.
I confirmed the SVG icon glitch reproduces in the Plasma session of newly created user so I guess the problem is not from my Plasma configuration problem.
Conclusion
I concluded the problem is the SVG icon and it is not so difficult to convert the breeze-dark icon theme into a PNG one but it is not so comfortable solution.
Does anyone know how SVG icons work correctly in GTK3.0 applications in Plasma6?
Thank you.
Environment
KDE Plasma Version: 6.0.4
KDE Frameworks Version: 6.1.0
Qt Version: 6.7.0
Kernel Version: 6.1.90-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × Intel® Core™ i7-4770 CPU @ 3.40GHz
Memory: 15.6 GiB of RAM
Graphics Processor: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
Manufacturer: MouseComputer/7Hpr64
Product Name: H81M-D3V-JP
