I have a laptop with a fan that crashes and grinds regularly (because it’s not a Delta Electronics fan). It has the latest Manjaro GNOME Testing installed. When the fan crashes and grinds, I send the computer into sleep mode. If there are any file transfers in progress, it just sits at the lock screen perpetually. With Windows, the system is down immediately regardless of any file transfers, which easily resume later. Because Manjaro GNOME didn’t suspend, it was grinding for too long, and is now persistently jammed and out-of-order. As such, it’s not possible to collect the information or logs requested.
That is unfortunate - as no one knows or even can know what is going on.
… not just you, sitting in front of the unit and thus the only one to be able to provide data …
I very much doubt that this is the reason.
… speculation is not going to help
but without data
only speculation is possible
The laptop fan was finally replaced, so this is the information from inxi --admin --verbosity=7 --filter --width
Kernel: 5.16.2-3-rt19-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-rt-x86_64
root=UUID=010b4eaf-80de-40a2-98b1-ccab734db894 rw quiet splash apparmor=1
security=apparmor resume=UUID=813beb18-8b6f-4301-a240-71f5a73c96e8
udev.log_priority=3
Desktop: GNOME v: 42.0 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Acer product: Aspire V5-571 v: V1.12
serial: <superuser required>
Mobo: Acer model: Aspire V5-571 v: V1.12 serial: <superuser required>
UEFI: Phoenix v: 1.12 date: 06/12/2012
ID-1: BAT0 charge: 15.0 Wh (100.0%) condition: 15.0/37.0 Wh (40.5%)
volts: 17.1 min: 14.8 model: SANYO AL12A32 type: Li-ion serial: <filter>
status: full
RAM: total: 7.57 GiB used: 6.79 GiB (89.7%)
RAM Report:
Info: model: Intel Core i5-3317U bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2401 high: 2421 min/max: 800/2600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2371 2: 2395 3: 2421
4: 2417 bogomips: 13569
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel ports: active: LVDS-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166
class-ID: 0300
Device-2: Suyin HD WebCam type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 064e:e330 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: LVDS-1 model: BOE Display 0x078b built: 2017 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
Message: Wayland GBM/EGL data currently not available.
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-3-rt19-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.2 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0f2 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 168c:0034 class-ID: 0280
Device-3: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
bus-ID: 4-2.4:5 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20u2u4 state: down mac: <filter>
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-1.4:27
chip-ID: 04ca:3006 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 14 state: up address: see --recommends
Local Storage: total: 1.09 TiB used: 909.04 GiB (81.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS545050A7E380
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: A6C0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk
model: SanDisk Ultra size: 58.89 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung model: HD642JJ
size: 596.17 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GU61N rev: 1.00
dev-links: cdrom
Features: speed: 8 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 456.67 GiB size: 448.43 GiB (98.20%) used: 359 GiB (80.1%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 010b4eaf-80de-40a2-98b1-ccab734db894
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 016E-FFBD
ID-3: /run/media/spindle/4623FCB831DBA024 raw-size: 58.89 GiB
size: 58.89 GiB (100.00%) used: 87.5 MiB (0.1%) fs: ntfs dev: /dev/sdb1
maj-min: 8:17 label: N/A uuid: 4623FCB831DBA024
ID-4: /run/media/spindle/4C11218436295A59 raw-size: 596.12 GiB
size: 596.12 GiB (100.00%) used: 548.57 GiB (92.0%) fs: ntfs dev: /dev/sdc1
maj-min: 8:33 label: N/A uuid: 4C11218436295A59
ID-1: swap-1 type: partition size: 8.8 GiB used: 1.38 GiB (15.7%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 813beb18-8b6f-4301-a240-71f5a73c96e8
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:27 info: Lite-On type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 04ca:3006
class-ID: e001
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 3-2:4 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 3-4:3 info: Suyin HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 064e:e330
class-ID: 0e02
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-8: 4-2:4 info: Genesys Logic USB3.0 Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 05e3:0617 class-ID: 0900
Device-1: 4-2.2:7 info: ASMedia ASM1153 SATA 3Gb/s bridge
type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
chip-ID: 174c:1153 class-ID: 0806 serial: <filter>
Device-2: 4-2.3:6 info: SanDisk Ultra type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 504mA
chip-ID: 0781:5581 class-ID: 0806 serial: <filter>
Device-3: 4-2.4:5 info: ASIX AX88179 Gigabit Ethernet type: Network
driver: ax88179_178a interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 8mA
System Temperatures: cpu: 51.0 C mobo: 41.0 C
Processes: 265 Uptime: 5d 5h 29m wakeups: 20 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1283
lib: 331 flatpak: 0 Shell: Zsh v: 5.8.1 running-in: gnome-terminal
inxi: 3.3.15
and it (still)
even though it is not the same one, but new?
