$ uname -r
5.12.19-1-MANJARO
Kde Plasma
inxi
$ inxi --full --verbosity=7 --filter --no-host
System: Kernel: 5.12.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop System: Micro-Star product: GP60 2QE v: REV:1.0 serial: <filter>
Mobo: Micro-Star model: MS-16GH v: REV:1.0 serial: <filter> UEFI: American Megatrends v: E16GHIMS.10H
date: 12/25/2014
Battery: ID-1: BAT1 charge: 16.1 Wh (96.4%) condition: 16.7/48.8 Wh (34.1%) volts: 12.4 min: 11.1 model: MSI Corp. MS-16GH
type: Unknown serial: N/A status: Unknown
Memory: RAM: total: 15.55 GiB used: 3.77 GiB (24.2%)
CPU: Info: Dual Core model: Intel Core i5-4210H bits: 64 type: MT MCP arch: Haswell rev: 3 cache: L2: 3 MiB
bogomips: 23153
Speed: 3191 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3191 2: 921 3: 2994 4: 3286
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Micro-Star MSI driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940M] vendor: Micro-Star MSI driver: nvidia v: 470.63.01 bus-ID: 01:00.0
chip-ID: 10de:1347 class-ID: 0302
Device-3: Acer MSI Integrated Webcam type: USB driver: uvcvideo bus-ID: 1-1.4:5 chip-ID: 5986:014c class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 21.1.6 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Device-3: Plantronics Plantronics .Audio 622 USB type: USB driver: plantronics,snd-usb-audio,usbhid bus-ID: 2-1.5:3
chip-ID: 047f:c014 class-ID: 0300
Sound Server-1: ALSA v: k5.12.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Network: Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet vendor: Micro-Star MSI driver: alx v: kernel port: d000
bus-ID: 03:00.0 chip-ID: 1969:e091 class-ID: 0200
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel port: d000 bus-ID: 05:00.0 chip-ID: 8086:08b3
class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-1.3:4 chip-ID: 8087:07dc
class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 6.37 TiB used: 2.53 TiB (39.7%)
ID-1: /dev/sda vendor: Western Digital model: WDS100T2B0A-00SM50 size: 931.51 GiB speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 20WD scheme: GPT
ID-2: /dev/sdb type: USB vendor: Western Digital model: WD My Book 25EE size: 5.46 TiB type: N/A serial: <filter>
rev: 4004 scheme: GPT
Partition: ID-1: / size: 915.53 GiB used: 69.55 GiB (7.6%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 0eef34c8-7ed8-4eb2-bffe-5f7e04864898
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 label: NO_LABEL uuid: CDDC-5789
ID-3: /run/media/andrew127/6TB My Book size: 5.46 TiB used: 2.46 TiB (45.1%) fs: exfat dev: /dev/sdb1
label: 6TB My Book uuid: 54BA-47FC
Swap: ID-1: swap-1 type: file size: 512 MiB used: 22.2 MiB (4.3%) priority: -2 file: /swapfile
Unmounted: Message: No unmounted partitions found.
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip-ID: 8087:8008
Device-1: 1-1.2:3 info: Logitech Cordless Mouse Receiver type: Mouse,HID driver: hid-generic,usbhid interfaces: 2
rev: 2.0 speed: 1.5 Mb/s power: 98mA chip-ID: 046d:c521 class-ID: 0300
Device-2: 1-1.3:4 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 8087:07dc class-ID: e001
Device-3: 1-1.4:5 info: Acer MSI Integrated Webcam type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 5986:014c class-ID: 0e02
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s chip-ID: 8087:8000
Device-1: 2-1.5:3 info: Plantronics Plantronics .Audio 622 USB type: Audio,HID
driver: plantronics,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 120mA chip-ID: 047f:c014
class-ID: 0300
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-6: 3-1:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip-ID: 2109:2813 class-ID: 0900
Hub-7: 3-1.1:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip-ID: 2109:2813 class-ID: 0900
Device-1: 3-1.2:4 info: Logitech Keyboard K120 type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 90mA chip-ID: 046d:c31c class-ID: 0300
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-9: 4-1:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip-ID: 2109:0813 class-ID: 0900
Hub-10: 4-1.1:3 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip-ID: 2109:0813 class-ID: 0900
Device-1: 4-2:4 info: Western Digital My Book 25EE type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 1058:25ee class-ID: 0806 serial: <filter>
Sensors: System Temperatures: cpu: 63.0 C mobo: N/A
Info: Processes: 210 Uptime: 10h 58m wakeups: 1 Init: systemd v: 248 Compilers: gcc: 11.1.0 Packages: pacman: 1164
Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
This failure happen very often. When it failed to suspend to ram, i usually try everything to shut it down… like “shutdown now” “shutdown -c” “ctrl+alt+del”… but not available. after quite sometime, it auto goes into sleep mode… … sometime it shut down… but that’s quite a long wait…
what i observed is:
observed weird part of the journalctl log
Aug 28 09:03:22 systemd[1]: run-timeshift-backup.mount: Mount process exited, code=exited, status=32/n/a
Aug 28 09:03:22 systemd[1]: Failed unmounting /run/timeshift/backup.
Aug 28 09:03:22 systemd[1]: tmp.mount: Mount process exited, code=exited, status=32/n/a
Aug 28 09:03:22 systemd[1]: Failed unmounting /tmp.
Aug 28 09:03:22 systemd[1]: Stopped target Swaps.
Aug 28 09:03:25 systemd[1]: Set hardware watchdog to 10min.
Aug 28 09:03:25 kernel: watchdog: watchdog0: watchdog did not stop!
Aug 27 23:32:14 CROND[2316]: (root) CMDOUT ( 0.01% complete (03:40:14 remaining) 0.01% complete (03:40:14 remaining) 0.01% complete (07:17:26 remaining) 0.01% complete (10:54:12 remaining) 0.01% complete (08:23:11 remaining) 0.01% complete (10:28:26 remaining) 0.01% complete (12:33:55 remaining) 0.01% complete (14:39:09 remaining) 0.01% complete (16:44:23 remaining) 0.01% complete (18:49:37 remaining) 0.01% complete (20:55:07 remaining) 0.01% complete (23:00:21 remaining) 0.01% complete (25:05:35 remaining) 0.01% complete (27:10:49 remaining) 0.01% complete (29:16:18 remaining) 0.01% complete (31:21:33 remaining) 0.01% complete (33:26:47 remaining) 0.01% complete (35:32:01 remaining) 0.01% complete (37:37:15 remaining) 0.01% complete (39:42:44 remaining) 0.01% complete (41:47:58 remaining) 0.01% complete (43:53:13 remaining) 0.01% complete (45:58:27 remaining) 0.01% complete (48:03:56 remaining) 0.01% complete (50:09:10 remaining) 0.01% complete (52:14:24 remaining) 0.01% complete (54:19:39 remaining) 0.01% complete (56:25:)
Aug 27 23:32:39 CROND[2316]: (root) CMDOUT (08 remaining) 0.01% complete (58:30:22 remaining) 0.01% complete (60:35:36 remaining) 0.01% complete (62:40:50 remaining) 0.01% complete (64:46:19 remaining) 0.01% complete (66:51:34 remaining) 0.01% complete (68:56:48 remaining) 0.01% complete (71:02:02 remaining) 0.01% complete (73:07:31 remaining) 0.01% complete (75:12:45 remaining) 0.01% complete (77:18:00 remaining) 0.01% complete (79:23:14 remaining) 0.01% complete (81:28:43 remaining) 0.01% complete (83:33:57 remaining) 0.01% complete (85:39:11 remaining) 0.01% complete (87:44:25 remaining) 0.01% complete (89:49:40 remaining) 0.01% complete (91:55:09 remaining) 0.01% complete (94:00:23 remaining) 0.01% complete (96:05:37 remaining) 0.01% complete (98:10:51 remaining) 0.01% complete (100:16:21 remaining) 0.01% complete (102:21:35 remaining) 0.01% complete (104:26:49 remaining) 4.40% complete (00:18:27 remaining) 4.41% complete (00:19:18 remaining) Re)
Aug 27 23:32:39 CROND[2316]: (root) CMDOUT (moved '2021-08-27_23-00-02')
Aug 27 23:32:39 CROND[2316]: (root) CMDOUT (------------------------------------------------------------------------------)
Aug 27 23:32:40 kernel: Filesystems sync: 774.187 seconds
Aug 27 23:33:07 kernel: Freezing user space processes ... (elapsed 19.430 seconds) done.
Aug 27 23:33:07 kernel: OOM killer disabled.
Aug 27 23:33:07 kernel: Freezing remaining freezable tasks ... (elapsed 0.007 seconds) done.
Aug 27 23:33:07 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Aug 27 23:33:07 kernel: sd 4:0:0:0: [sda] Synchronizing SCSI cache
Aug 27 23:33:07 kernel: sd 4:0:0:0: [sda] Stopping disk
Aug 27 23:33:07 kernel: ACPI: EC: interrupt blocked
Aug 27 23:33:07 kernel: ACPI: Preparing to enter system sleep state S3
Aug 27 23:33:07 kernel: ACPI: EC: event blocked
Aug 27 23:33:07 kernel: ACPI: EC: EC stopped
Aug 27 23:33:07 kernel: PM: Saving platform NVS memory
Aug 27 23:33:07 kernel: Disabling non-boot CPUs ...
Aug 27 23:33:07 kernel: smpboot: CPU 1 is now offline
Aug 27 23:33:07 kernel: smpboot: CPU 2 is now offline
Aug 27 23:33:07 kernel: smpboot: CPU 3 is now offline
weird to me
Aug 27 23:31:50 kernel: INFO: task systemd-sleep:2532 blocked for more than 614 seconds.
Aug 27 23:31:50 kernel: Tainted: P OE 5.12.19-1-MANJARO #1
Aug 27 23:31:50 kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Aug 27 23:31:50 kernel: task:systemd-sleep state:D stack: 0 pid: 2532 ppid: 1 flags:0x00004000
Aug 27 23:31:50 kernel: Call Trace:
Aug 27 23:31:50 kernel: __schedule+0x2ff/0x8b0
