Continuation of Suspend problems, broken dsdt table:
Thread got locked so I had to make a new one
Waking from deep sleep takes 1 minute and then the computer wakes up with the keyboard not working.
Becasue of that I ussualy reset the laptop with my touchpad and run every command that I can after rebooting, such as journalctl for example.
I was able to get the dmesg without rebooting by using a external keyboard.
Here is the output:
sudo dmesg -l warn+
[ 0.151481] #5 #6 #7 #8 #9 #10 #11
[ 0.246458] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.965218] pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 1.149831] hpet_acpi_add: no address or irqs in _CRS
[ 1.470205] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.478201] usb: port power management may be unreliable
[ 2.049686] memfd_create() without MFD_EXEC nor MFD_NOEXEC_SEAL, pid=1 'systemd'
[ 2.289521] acpi_call: loading out-of-tree module taints kernel.
[ 3.185059] ACPI Warning: \_SB.WCCD._DSM: Argument #4 type mismatch - Found [Integer], ACPI requires [Package] (20230331/nsarguments-61)
[ 3.214088] wmi_bus wmi_bus-PNP0C14:02: WQZZ data block query control method not found
[ 3.260666] resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcffff], which spans more than pnp 00:04 [mem 0xfedc0000-0xfedc7fff]
[ 3.260671] caller igen6_probe+0x1a0/0x8d0 [igen6_edac] mapping multiple BARs
[ 3.502060] hp_wmi: query 0x4 returned error 0x5
[ 3.605438] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 3.822768] iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
[ 3.822868] thermal thermal_zone17: failed to read out thermal zone (-61)
[ 3.831692] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[ 4.152675] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[ 4.453616] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[ 5.204026] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
[ 5.212502] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[ 5.462982] snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
[ 5.462988] snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
[ 5.463075] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
[ 5.463078] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
[ 5.463080] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
[ 5.463082] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
[ 5.463084] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
[ 5.463088] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
[ 5.463091] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
[ 5.463094] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
[ 5.463098] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
[ 5.463101] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
[ 5.463104] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
[ 5.463112] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[ 61.852317] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 61.852324] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 61.852358] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.ITLB due to previous error (AE_TIME) (20230331/psparse-529)
[ 61.852365] ACPI Error: Aborting method \HWAK due to previous error (AE_TIME) (20230331/psparse-529)
[ 61.852369] ACPI Error: Aborting method \_WAK due to previous error (AE_TIME) (20230331/psparse-529)
[ 61.852376] ACPI Error: AE_TIME, While executing method \_WAK (20230331/hwesleep-47)
[ 66.849116] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 66.849121] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 66.849152] ACPI Error: Aborting method \_SB.PC00.RP08.PSTA due to previous error (AE_TIME) (20230331/psparse-529)
[ 66.849158] ACPI Error: Aborting method \_SB.PC00.RP08.PXP._STA due to previous error (AE_TIME) (20230331/psparse-529)
[ 69.352055] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 69.352084] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 69.352227] ACPI Error: Aborting method \_SB.PC00.RP08.PON due to previous error (AE_TIME) (20230331/psparse-529)
[ 69.352259] ACPI Error: Aborting method \_SB.PC00.RP08.PXP._ON due to previous error (AE_TIME) (20230331/psparse-529)
[ 69.478179] xhci_hcd 0000:00:0d.0: xHC error in resume, USBSTS 0x401, Reinit
[ 69.482191] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[ 69.981429] iosm 0000:57:00.0: msg timeout
[ 71.997904] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 71.997925] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 71.997972] ACPI Error: Aborting method \_SB.WMIV.WGDS due to previous error (AE_TIME) (20230331/psparse-529)
[ 71.998003] ACPI Error: Aborting method \_SB.WMIV.HVWP due to previous error (AE_TIME) (20230331/psparse-529)
[ 71.998024] ACPI Error: Aborting method \_SB.WMIV.HVWA due to previous error (AE_TIME) (20230331/psparse-529)
[ 71.998046] ACPI Error: Aborting method \_SB.WMIV.WMPV due to previous error (AE_TIME) (20230331/psparse-529)
[ 74.550744] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 74.550770] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 74.550812] ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20230331/psparse-529)
[ 74.550839] ACPI Error: Aborting method \_TZ.CPUZ._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 74.550867] thermal thermal_zone0: failed to read out thermal zone (-19)
[ 77.073756] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 77.073789] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 77.073929] ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20230331/psparse-529)
[ 77.073973] ACPI Error: Aborting method \_TZ.GFXZ._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 77.074018] thermal thermal_zone1: failed to read out thermal zone (-19)
[ 79.596845] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 79.596879] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 79.596938] ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20230331/psparse-529)
[ 79.596979] ACPI Error: Aborting method \_TZ.EXTZ._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 79.597024] thermal thermal_zone2: failed to read out thermal zone (-19)
[ 82.116663] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 82.116700] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 82.116834] ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20230331/psparse-529)
[ 82.116874] ACPI Error: Aborting method \_TZ.LOCZ._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 82.116915] thermal thermal_zone3: failed to read out thermal zone (-19)
[ 84.636489] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 84.636516] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 84.636559] ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20230331/psparse-529)
[ 84.636585] ACPI Error: Aborting method \_TZ.BATZ._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 84.636613] thermal thermal_zone4: failed to read out thermal zone (-19)
[ 87.156420] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 87.156444] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 87.156487] ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20230331/psparse-529)
[ 87.156513] ACPI Error: Aborting method \_TZ.CHGZ._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 87.156541] thermal thermal_zone5: failed to read out thermal zone (-19)
[ 89.676338] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 89.676362] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 89.676458] ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20230331/psparse-529)
[ 89.676482] ACPI Error: Aborting method \_TZ.SK1Z._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 89.676509] thermal thermal_zone6: failed to read out thermal zone (-19)
[ 92.196319] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 92.196344] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 92.196385] ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20230331/psparse-529)
[ 92.196409] ACPI Error: Aborting method \_TZ.SK2Z._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 92.196436] thermal thermal_zone7: failed to read out thermal zone (-19)
[ 94.719609] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 94.719635] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 94.719731] ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20230331/psparse-529)
[ 94.719755] ACPI Error: Aborting method \_TZ.PCHZ._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 94.719783] thermal thermal_zone9: failed to read out thermal zone (-19)
[ 97.242906] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 97.242931] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 97.242976] ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20230331/psparse-529)
[ 97.243001] ACPI Error: Aborting method \_TZ.EXTZ._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 97.243017] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN1._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 97.243044] thermal thermal_zone11: failed to read out thermal zone (-5)
[ 99.762926] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 99.762961] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 99.763028] ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20230331/psparse-529)
[ 99.763069] ACPI Error: Aborting method \_TZ.LOCZ._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 99.763095] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN2._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 99.763142] thermal thermal_zone12: failed to read out thermal zone (-5)
[ 102.299263] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 102.299270] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 102.299305] ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20230331/psparse-529)
[ 102.299314] ACPI Error: Aborting method \_TZ.SK1Z._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 102.299319] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.SEN6._TMP due to previous error (AE_TIME) (20230331/psparse-529)
[ 102.299328] thermal thermal_zone13: failed to read out thermal zone (-5)
[ 104.806316] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 104.806350] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 104.806423] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 104.806462] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 104.806488] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 104.940209] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 107.361391] i8042: Can't read CTR while initializing i8042
[ 107.361396] i8042: probe of i8042 failed with error -5
[ 107.446703] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[ 109.419037] iosm 0000:57:00.0: msg timeout
[ 109.892895] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 109.892922] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 109.893021] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 109.893048] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 109.893064] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 109.925739] iosm 0000:57:00.0: msg timeout
[ 110.432971] iosm 0000:57:00.0: msg timeout
[ 110.938799] iosm 0000:57:00.0: msg timeout
[ 112.396214] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 112.396242] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 112.396342] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 112.396368] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 112.396383] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 114.899257] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 114.899292] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 114.899365] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 114.899403] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 114.899429] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 117.399613] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 117.399648] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 117.399722] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 117.399760] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 117.399786] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 119.902897] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 119.902935] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 119.903008] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 119.903046] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 119.903069] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 122.402832] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 122.402861] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 122.402960] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 122.402987] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 122.403003] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 124.902902] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 124.902938] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 124.903010] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 124.903048] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 124.903071] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 127.406208] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 127.406242] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 127.406320] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 127.406359] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 127.406385] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 129.818991] iosm 0000:57:00.0: msg timeout
[ 129.912880] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 129.912915] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 129.912991] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 129.913030] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 129.913055] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 130.326239] iosm 0000:57:00.0: msg timeout
[ 131.339680] iosm 0000:57:00.0: msg timeout
[ 131.845658] iosm 0000:57:00.0: msg timeout
[ 132.416233] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 132.416273] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 132.416350] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 132.416388] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 132.416414] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 134.922920] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 134.922954] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 134.923097] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 134.923135] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 134.923159] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 135.346447] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Wake failed, re-enter hibernate: -42
[ 135.478860] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Wake failed, re-enter hibernate: -42
[ 135.613191] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Wake failed, re-enter hibernate: -42
[ 135.745728] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Wake failed, re-enter hibernate: -42
[ 135.879702] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Wake failed, re-enter hibernate: -42
[ 135.880307] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Timed out waking device
[ 135.880308] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Unable to exit Hibernate.
[ 136.021554] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Wake failed, re-enter hibernate: -42
[ 136.172917] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Wake failed, re-enter hibernate: -42
[ 136.324260] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Wake failed, re-enter hibernate: -42
[ 136.478372] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Wake failed, re-enter hibernate: -42
[ 136.635186] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Wake failed, re-enter hibernate: -42
[ 136.636596] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Timed out waking device
[ 136.636603] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Unable to exit Hibernate.
[ 136.703210] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Failed to set mailbox cmd 1 (status 0)
[ 136.710516] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Failed to set mailbox cmd 1 (status 0)
[ 137.436254] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 137.436288] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 137.436364] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 137.436402] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 137.436428] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 139.936263] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 139.936307] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 139.936384] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 139.936426] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 139.936454] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 141.888368] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.0: Failed to set mailbox cmd 1 (status 0)
[ 141.896529] cs35l41-hda spi1-CSC3551:00-cs35l41-hda.1: Failed to set mailbox cmd 1 (status 0)
[ 142.442878] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 142.442905] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 142.442955] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 142.442982] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 142.442997] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 144.942933] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 144.942968] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 144.943044] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 144.943083] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 144.943108] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 147.446148] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 147.446174] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 147.446223] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 147.446250] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 147.446264] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 149.949479] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 149.949506] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 149.949603] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 149.949629] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 149.949643] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 152.459507] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 152.459543] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 152.459621] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 152.459660] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 152.459685] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 154.969543] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 154.969582] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 154.969656] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 154.969693] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 154.969718] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 157.469547] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 157.469581] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 157.469652] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 157.469692] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 157.469717] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 159.979541] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 159.979578] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 159.979654] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 159.979692] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 159.979718] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 162.482870] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 162.482906] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 162.482980] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 162.483017] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 162.483041] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 189.979530] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 189.979569] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 189.979644] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 189.979683] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 189.979710] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 192.489127] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 192.489134] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 192.489151] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 192.489159] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 192.489164] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 194.992888] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 194.992931] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 194.993002] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 194.993041] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 194.993066] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 197.496160] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 197.496186] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 197.496285] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 197.496310] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 197.496327] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 199.999520] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 199.999556] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 199.999632] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 199.999671] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 199.999697] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 202.505722] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 202.505728] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 202.505743] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 202.505751] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 202.505755] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 204.805950] warning: `ThreadPoolForeg' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 205.011988] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 205.011994] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 205.012009] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 205.012015] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 205.012019] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 207.521964] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 207.521980] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 207.522018] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 207.522037] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 207.522050] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 210.034989] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 210.034996] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 210.035015] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 210.035022] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 210.035026] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 212.544816] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 212.544826] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 212.544848] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 212.544858] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 212.544868] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 215.054540] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 215.054547] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 215.054563] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 215.054569] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 215.054574] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 217.564336] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 217.564342] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 217.564359] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 217.564366] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 217.564370] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 220.074401] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 220.074421] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 220.074466] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 220.074489] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 220.074503] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
[ 222.580796] ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20230331/evregion-300)
[ 222.580803] ACPI Error: Timeout from EC hardware or EC device driver (20230331/evregion-310)
[ 222.580820] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 222.580828] ACPI Error: Aborting method \_SB.BTST due to previous error (AE_TIME) (20230331/psparse-529)
[ 222.580832] ACPI Error: Aborting method \_SB.BAT0._BST due to previous error (AE_TIME) (20230331/psparse-529)
Nothing changes.
Also I was able to test deep sleep with bootable windows 10 pendrive and it also didn’t work there, however in win10 the screen didn’t work also and I had to hard reset the pc to do anything.
This leads me to belive that the deep sleep isn’t supported by the manufacturer so I feel that using s2 might be the better opion becasue it worked fine on windows.
However the problem is that s2 also doesn’t work as after wakeup the keyboard backlight is working (unlike deep) and the fans are spinning but the screen is black.
