Suspend not working following Stable Update 2026-07-23
I experience quite serious issues with this update.
The update process had no problem. I ran it on Octopi and then reboot it successfully and everything appeared to work fine. After finishing my work, like always, I closed the lid of the laptop (an older MacBook Pro), which should send it to sleep.
Hours later, I took out the laptop, it felt warm, apparently it has been running, not sleeping. I plugged in the power, opened the lid, it showed a black screen. I tapped the power button, the screen showed a battery warning and the laptop didn’t start. I let it charge for about 10 minutes, then tapped the power button, thank god it started.
Then I tried to manually send it to sleep (from the menu), with the lid open, it went to sleep but without me touching anything, it came back to the login screen after about 20 seconds. I logged in, it didn’t connect to wifi. from the network popup from the panel, it showed looking for wifi but got no options. I tried to toggle off/on wifi from the popup, the toggle was not quite responsive, the effect came perhaps after 5 seconds after the click. Then it still finds no wifi. I logged out and in, wifi still doesn’t work. I had to reboot to get the wifi working.
Any suggestions on how to work normally as before: close lid → sleep, open lid → run with wifi.
BTW, when the wifi is working, toggling it off/on works as expected.
Hello @XJia I have moved your post to a dedicated Topic.
I suspect this is an issue with the kernel you are using now; this might get moved to that section if it is; this can be tested by trying another one e.g. linux618. Which are you using …?
It will help us to help you if you provide some System Information as that will tell us:
inxi -zv8
Note that the output produced by this command is privacy-filtered.
Please also remember to use proper code formatting as this makes it much easier to read on the Forum:
[Mini How-To] format code or command output
Select and copy all the text in the Terminal window (minus the prompt, if you are using zsh).
Then paste the output in between two lines containing three backticks
or three tildes
Or:
Copy & paste, then highlight the pasted text and click the </> button at the top of the reply window (easier for smaller outputs).
Also note that it is better to start a separate Topic on your WiFi/Networking issue in the appropriate section.
Cheers! :wink:
I was and am running 6.18.39-1-MANJARO #1 SMP PREEMPT_DYNAMIC
inxi -zv8
  Kernel: 6.18.39-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    root=UUID=06f2f8c6-47ea-444a-97a1-44629f02874f rw quiet splash
    resume=UUID=0fc478b2-1d95-466e-bafd-6de6515a989b udev.log_priority=3
  Desktop: KDE Plasma v: 6.7.3 tk: Qt v: N/A info: frameworks v: 6.28.0
  Type: Laptop System: Apple product: MacBookPro12,1 v: 1.0
    serial: <superuser required> Chassis: type: 9 v: Mac-E43C1C25D4880AD6
  Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12,1
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: Apple v: 430.140.3.0.0 date: 04/18/2022
  ID-1: BAT0 charge: 15.7 Wh (50%) condition: 31.5/72.6 Wh (43.3%)
    temp: 40.5 C volts: 11.79 min: 11.34 model: SMP bq20z451 type: Li-ion
    serial: N/A charging: status: charging cycles: 34
  System RAM: total: 8 GiB available: 7.65 GiB used: 3.61 GiB (47.1%)
  Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1867 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: 0x80AD part-no: 0x483943434E4E4E424C54414C41522D4E5544
    serial: <filter>
  Device-2: DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    serial: <filter>
  Info: model: Intel Core i5-5257U bits: 64 type: MT MCP arch: Broadwell
    gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
    family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 500 min/max: 500/3100 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 21601
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid lahf_lm
    lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
    pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
    tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel Broadwell-U GT3 [Iris Graphics 6100] vendor: Apple
    driver: i915 v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports:
    active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:162b class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: Apple Color LCD built: 2013 res: mode: 2560x1600
    hz: 60 scale: 100% (1) dpi: 227 gamma: 1.2 chroma: red: x: 0.655 y: 0.333
    green: x: 0.298 y: 0.620 blue: x: 0.145 y: 0.047 white: x: 0.314 y: 0.329
    size: 286x179mm (11.26x7.05") diag: 337mm (13.3") ratio: 16:10
    modes: 2560x1600
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 vendor: intel mesa v: 26.1.5-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel Iris Graphics 6100 (BDW GT3)
    device-ID: 8086:162b memory: 7.47 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.350 layers: 2 device: 0 type: integrated-gpu name: Intel
    Iris Graphics 6100 (BDW GT3) driver: mesa intel v: 26.1.5-arch1.1
    device-ID: 8086:162b surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: gputop, intel_gpu_top, lsgpu
  Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
    class-ID: 0403
  Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
  API: ALSA v: k6.18.39-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
    driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
  Device-1: Apple Bluetooth Host Controller driver: btusb,hid-generic,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
    chip-ID: 05ac:8290 class-ID: fe01
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 233.76 GiB used: 130.53 GiB (55.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256G
    size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: PA0Q scheme: GPT
  ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 26.83 GiB (56.2%)
    fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 06f2f8c6-47ea-444a-97a1-44629f02874f
  ID-2: /boot/efi raw-size: 1001 MiB size: 999 MiB (99.80%)
    used: 328 KiB (0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: C52E-DD5A
  ID-3: /home raw-size: 174.19 GiB size: 170.4 GiB (97.82%)
    used: 103.7 GiB (60.9%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 3c05e9c8-a423-467e-b26c-b3e64d78c4b5
  ID-1: swap-1 type: partition size: 9.77 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 0fc478b2-1d95-466e-bafd-6de6515a989b
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 11 rev: 2.0
  Device-1: 1-3:2 info: Apple Bluetooth Host Controller
    type: keyboard,mouse,bluetooth driver: btusb,hid-generic,usbhid
    interfaces: 6 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
  Device-2: 1-5:3 info: Apple Internal Keyboard/Trackpad (ISO)
    type: HID,keyboard,mouse driver: apple,bcm5974,usbhid interfaces: 5 rev: 2.0
    chip-ID: 05ac:0273 class-ID: 0300 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 67.0 C pch: 64.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1777 pm: pacman pkgs: 1771 libs: 465 tools: octopi,pamac,yay
    pm: flatpak pkgs: 6
    1: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    2: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    3: https://mirror.23m.com/manjaro/stable/$repo/$arch
    4: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    5: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 205
  1: cpu: 9.3% command: brave pid: 1912 mem: 322.4 MiB (4.1%)
  2: cpu: 4.3% command: konsole pid: 3020 mem: 105.6 MiB (1.3%)
  3: cpu: 3.5% command: brave pid: 1553 mem: 466.8 MiB (5.9%)
  4: cpu: 3.3% command: brave pid: 1600 mem: 180.4 MiB (2.3%)
  5: cpu: 2.4% command: systemsettings pid: 2927 mem: 331.9 MiB (4.2%)
  Memory top: 5 of 205
  1: mem: 466.8 MiB (5.9%) command: brave pid: 1553 cpu: 3.5%
  2: mem: 424.1 MiB (5.4%) command: plasmashell pid: 1159 cpu: 1.3%
  3: mem: 331.9 MiB (4.2%) command: systemsettings pid: 2927 cpu: 2.4%
  4: mem: 322.4 MiB (4.1%) command: brave pid: 1912 cpu: 9.3%
  5: mem: 298.1 MiB (3.8%) command: brave pid: 1789 cpu: 0.8%
  Processes: 205 Power: uptime: 35m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.91 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 261 default: graphical tool: systemctl
  Compilers: clang: 22.1.8 gcc: 16.1.1 Shell: Zsh v: 5.9.2
    running-in: konsole inxi: 3.3.41
Sorry, I’m not sure if the kernel before the update was the same. I had set the LTE kernel, 6.18, but am not sure if there is a minor update to it during the update.
Moderator edit: Merged consecutive posts
It is definitely not the kernel. I have not yet applied the latest update, but have been experiencing this issue of suspend getting cancelled by itself. I run 6.12 LTS kernel. If it is helpful to investigate, the first time laptop stayed awake on lid close, I tried systemctl suspend and got the error that a 2nd monitor is preventing suspend. There was no 2nd monitor, but I noticed there was one old one still configured in ~/.config/monitors.xml so I deleted the file, and then suspend started working but I still get spurious wakes now and then (usually after a few days of uptime)
$ sudo inxi -zv8
  Kernel: 6.12.95-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    root=UUID=c130d871-7a93-4340-8c66-770aef761da9 rw
    resume=UUID=76c311db-4302-4166-8656-b739cc2fac71 acpi_osi=Darwin
    intel_pstate=active keymap=mac-uk brcmfmac.feature_disable=0x82000
  Desktop: Cinnamon v: 6.6.8 tk: GTK v: 3.24.52 wm: Muffin v: 6.6.3 tools:
    avail: cinnamon-screensaver dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Apple product: MacBookPro12,1 v: 1.0 serial: <filter>
    Chassis: type: 9 v: Mac-E43C1C25D4880AD6 serial: <filter>
  Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12,1 serial: <filter>
    uuid: a0c41390-0e3f-5e5b-808b-6ebb3eef53c2 Firmware: UEFI vendor: Apple
    v: 425.0.0.0.0 date: 11/04/2020
  ID-1: BAT0 charge: 73.8 Wh (100%) condition: 73.8/72.6 Wh (101.7%)
    temp: 44.5 C volts: 12.57 min: 11.34 model: ifixit bq20z451 type: Li-ion
    serial: N/A charging: status: full cycles: 3
  System RAM: total: 16 GiB available: 15.52 GiB used: 10.03 GiB (64.6%)
    igpu: 64 MiB
  Array-1: capacity: 16 GiB note: est. slots: 2 modules: 2 EC: None
  Device-1: DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    manufacturer: 0x02FE part-no: 0x4544464232333241314D412D4A442D460000
    serial: <filter>
  Device-2: DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    serial: <filter>
  Message: No PCI Slot data found.
  Info: model: Intel Core i7-5557U socket: BGA1168 (U3E1) note: check bits: 64
    type: MT MCP arch: Broadwell gen: core 5 level: v3 note: check
    built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61)
    desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1101 min/max: 500/3400 base/boost: 3400/3100 scaling:
    driver: intel_pstate governor: powersave volts: 1.1 V ext-clock: 25 MHz
    cores: 1: 1101 2: 1101 3: 1101 4: 1101 bogomips: 24808
    vulnerable
    affected
  Display: x11 server: X.Org v: 21.1.24 with: Xwayland v: 24.1.13 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43")
    modes: 2560x1600
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Info: Tools: de: kscreen-doctor gpu: gputop, intel_gpu_top, lsgpu
    x11: xdpyinfo, xprop, xrandr
    class-ID: 0403
  Device-3: Broadcom 720p FaceTime HD Camera driver: facetimehd v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570
    class-ID: 0480
  API: ALSA v: k6.12.95-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.7 status: n/a (root, process) with:
    1: pipewire-pulse status: active 2: pipewire-media-session status: active
    3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli
  IF-ID-1: docker0 state: down mac: <filter>
  Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
    chip-ID: 0a12:0001 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter> lmp-v: 14 status:
    discoverable: no pairing: no
  Device-2: Apple Bluetooth Host Controller driver: N/A type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 05ac:8290
    class-ID: ef00
  Local Storage: total: 465.92 GiB used: 282.5 GiB (60.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0512G
    family: SD/SM/TS...E/F/G SSDs size: 465.92 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: SA0Q temp: 45 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 3y 113d 20h cycles: 29676
  ID-1: / raw-size: 65 GiB size: 63.68 GiB (97.97%) used: 38.86 GiB (61.0%)
    fs: ext4 block-size: 4096 B dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: c130d871-7a93-4340-8c66-770aef761da9
  ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%)
    used: 35.8 MiB (18.2%) fs: vfat block-size: 512 B dev: /dev/sda1
    maj-min: 8:1 label: EFI uuid: 67E3-17ED
  ID-3: /home raw-size: 305.46 GiB size: 299.6 GiB (98.08%)
    used: 238.59 GiB (79.6%) fs: ext4 block-size: 4096 B dev: /dev/sda6
    maj-min: 8:6 label: N/A uuid: c5872da1-250d-4a30-92f7-0a026b1dcd53
  Kernel: swappiness: 50 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: partition size: 20 GiB used: 5.02 GiB (25.1%)
    priority: -2 dev: /dev/sda5 maj-min: 8:5 label: N/A
    uuid: 76c311db-4302-4166-8656-b739cc2fac71
  ID-1: /dev/sda2 maj-min: 8:2 size: 74.51 GiB fs: cs_fvault2 label: N/A
    uuid: 4aa61a5f-bafe-4d52-abc4-c6ce4bd3e9dc
  ID-2: /dev/sda3 maj-min: 8:3 size: 619.9 MiB fs: hfsplus
    label: Recovery HD uuid: bf47f9b0-0b5c-3e0d-8139-d3fc63a1e497
  Device-1: 1-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Device-2: 1-3:3 info: Apple Bluetooth Host Controller type: Bluetooth
    driver: N/A rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    chip-ID: 05ac:8290 class-ID: ef00
  Device-3: 1-5:4 info: Apple Internal Keyboard/Trackpad (ISO)
  System Temperatures: cpu: 62.0 C pch: 65.0 C mobo: N/A
  Packages: pm: pacman pkgs: 2237 libs: 514 tools: pamac,yay
    1: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    4: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    6: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    7: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    9: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    10: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    11: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    12: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    13: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    14: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    15: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    18: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    20: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    21: https://mirrors2.manjaro.org/stable/$repo/$arch
    22: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    24: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    25: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    26: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    27: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    28: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    30: https://manjaro.ynh.ovh/stable/$repo/$arch
    31: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    32: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    33: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    34: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    35: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    36: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    37: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 279
  1: cpu: 7.3% command: firefox pid: 65872 mem: 392.6 MiB (2.4%)
  2: cpu: 4.5% command: firefox pid: 2667 mem: 984.7 MiB (6.1%)
  3: cpu: 3.0% command: sudo pid: 71582 mem: 9.33 MiB (0.0%)
  4: cpu: 1.4% command: code pid: 54897 mem: 256.3 MiB (1.6%)
  5: cpu: 1.1% command: rust-analyzer pid: 54993 mem: 1489.6 MiB (9.3%)
  Memory top: 5 of 279
  1: mem: 1489.6 MiB (9.3%) command: rust-analyzer pid: 54993 cpu: 1.1%
  2: mem: 984.7 MiB (6.1%) command: firefox pid: 2667 cpu: 4.5%
  3: mem: 594.6 MiB (3.7%) command: firefox pid: 3014 cpu: 0.5%
  4: mem: 493.1 MiB (3.1%) command: firefox pid: 2988 cpu: 0.7%
  5: mem: 472.4 MiB (2.9%) command: firefox pid: 3851 cpu: 0.4%
  Processes: 279 Power: uptime: 1d 19h 34m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: suspend avail: platform,
    shutdown, reboot, test_resume image: 6.05 GiB
    services: csd-power,thermald,upowerd Init: systemd v: 261
  Compilers: clang: 22.1.6 gcc: 16.1.1 Shell: Sudo (sudo) v: 1.9.17p2
    default: Bash v: 5.3.15 running-in: gnome-terminal inxi: 3.3.41
Sleep with lid closed had been working quite reliably for me for a long time, except perhaps some rare occasions in the past. There had been a notification sound when it got to sleep and a repeated notification when it didn’t. But in recent updates, that notifications disappeared.
BTW, I don’t have ~/.config/monitors.xml
same for me also, until last update. We are both running on Macbook 12,1 … so must be a some driver. I disabled bluetooth the last couple of days, and have not experience wakes since. But don’t know if it helps, because for me the wakes were always intermittent.
bluetooth is perhaps not a factor for me. Soon after every start, I toggle it off, pretty annoying it’s set to come on on every start.
@XJia’s issue is that suspend by closing the lid stopped working after the latest update. In your (@ohell) case however i don’t even understand whether you updated or not?
Yes, you have a somewhat similar MacBook. But you use different desktop environments. That’s why you had an issue with suspend regarding monitor configuration under Cinnamon I suppose and @XJia is using KDE Plasma. The latter got a major upgrade to 6.7.3 with the latest update and this could have caused @XJia’s issue with suspend which looks different from yours. If you would like to get support with your issue there should be a separate topic for this. We can’t support two different issues in a single topic – this will lead only to confusions.
@XJia Have you checked the energy options in the Plasma system settings?
The energy section remains the same through the update.
on power, close lid → screen off
on battery, close lid → sleep
when sleeping, enter: Standby
Just a shot in the dark: Change this to sleep and apply to save the settings again. Although i doubt this will make a difference :man_shrugging:
hesitate setting that, as waking from sleep shuts off wifi, and the issue at hand appears not about closing the lid, but sleep itself, as it happens when manually setting to sleep with lid open.
Perhaps i don’t understand the problem.
What is the situation now? Is it perhaps close lid → not sleep? Or is it close lid → sleep as wished but whenever the system wakes up from sleep the wifi is gone? Or is it that the system wakes up on its own unexpectedly?
Then check what triggered the wake up with
journalctl -b | grep -i "wakeup\|suspend\|resume"
Did a couple more tests, results vary:
  1. manually set to sleep, lid open, a bit later, tap a key, log in, wifi worked.
  2. manually set to sleep, lid open, a bit later, tap a key, log in, wifi stoped working, had to restart (I don’t know how to start wifi from command line).
  3. close lid on battery, with settings:
    a bit later, open lid, screen came right on, apparently not sleeping, wifi worked
  4. close lid on battery, with settings:
    on power, close lid → sleep
    a bit later, open lid, (wake from sleep), log in, wifi works
~ journalctl -b -1 | grep -i "wakeup\|suspend\|resume"
Jul 25 18:49:06 MacManj kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=06f2f8c6-47ea-444a-97a1-44629f02874f rw quiet splash resume=UUID=0fc478b2-1d95-466e-bafd-6de6515a989b udev.log_priority=3
Jul 25 18:49:06 MacManj kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=06f2f8c6-47ea-444a-97a1-44629f02874f rw quiet splash resume=UUID=0fc478b2-1d95-466e-bafd-6de6515a989b udev.log_priority=3
Jul 25 18:49:20 MacManj rtkit-daemon[1153]: Handling system-suspend using logind.
Jul 25 19:51:58 MacManj systemd-logind[871]: suspend requested from client PID 6374 ('plasmashell') (unit user@1000.service)...
Jul 25 19:51:58 MacManj systemd-logind[871]: The system will suspend now!
Jul 25 19:51:58 MacManj ModemManager[923]: <msg> [sleep-monitor-systemd] system is about to suspend
Jul 25 19:51:59 MacManj systemd[1]: Starting System Suspend...
Jul 25 19:51:59 MacManj systemd-sleep[8406]: Performing sleep operation 'suspend'...
Jul 25 19:51:59 MacManj kernel: PM: suspend entry (deep)
Jul 25 19:52:57 MacManj kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jul 25 19:52:57 MacManj kernel: ACPI: PM: Low-level resume complete
Jul 25 19:52:58 MacManj systemd-sleep[8406]: System returned from sleep operation 'suspend'.
Jul 25 19:52:58 MacManj kernel: PM: suspend exit
Jul 25 19:52:58 MacManj kernel: Process accounting resumed
Jul 25 19:52:58 MacManj systemd[1]: systemd-suspend.service: Deactivated successfully.
Jul 25 19:52:58 MacManj systemd[1]: Finished System Suspend.
Jul 25 19:52:58 MacManj systemd[1]: Reached target Suspend.
Jul 25 19:52:58 MacManj systemd-logind[871]: Operation 'suspend' finished.
Jul 25 19:52:58 MacManj systemd[1]: Stopped target Suspend.
Jul 25 19:52:58 MacManj rtkit-daemon[1153]: Resumed scheduling 6 threads.
Jul 25 19:52:58 MacManj org_kde_powerdevil[6395]: [  6492][1242.525190] (ldbus_handle_message)Received dbus signal PrepareForSleep(false=resume)
Jul 25 19:53:38 MacManj systemd-logind[871]: suspend requested from client PID 6374 ('plasmashell') (unit user@1000.service)...
Jul 25 19:53:38 MacManj systemd-logind[871]: The system will suspend now!
Jul 25 19:53:38 MacManj ModemManager[923]: <msg> [sleep-monitor-systemd] system is about to suspend
Jul 25 19:53:40 MacManj systemd[1]: Starting System Suspend...
Jul 25 19:53:40 MacManj systemd-sleep[8801]: Performing sleep operation 'suspend'...
Jul 25 19:53:40 MacManj kernel: PM: suspend entry (deep)
Jul 25 19:56:25 MacManj kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jul 25 19:56:25 MacManj kernel: ACPI: PM: Low-level resume complete
Jul 25 19:56:26 MacManj systemd-sleep[8801]: System returned from sleep operation 'suspend'.
Jul 25 19:56:26 MacManj kernel: PM: suspend exit
Jul 25 19:56:26 MacManj kernel: Process accounting resumed
Jul 25 19:56:26 MacManj org_kde_powerdevil[6395]: [  6492][1450.622923] (ldbus_handle_message)Received dbus signal PrepareForSleep(false=resume)
Jul 25 19:56:26 MacManj systemd[1]: systemd-suspend.service: Deactivated successfully.
Jul 25 19:56:26 MacManj systemd[1]: Finished System Suspend.
Jul 25 19:56:26 MacManj systemd[1]: Reached target Suspend.
Jul 25 19:56:26 MacManj systemd-logind[871]: Operation 'suspend' finished.
Jul 25 19:56:26 MacManj systemd[1]: Stopped target Suspend.
Jul 25 19:56:26 MacManj rtkit-daemon[1153]: Resumed scheduling 6 threads.
Jul 25 19:58:46 MacManj org_kde_powerdevil[6395]: [  6529][1591.093073] (recently_resumed_from_sleep_by_clocktime) Resume from sleep detected by BOOTTIME/MONOTONIC
Jul 25 19:58:47 MacManj org_kde_powerdevil[6395]: [  6529]    Time since last resume from sleep: 140.470 seconds = 140470 millisec (140470147931nanosec)
Jul 25 19:58:47 MacManj org_kde_powerdevil[6395]: [  6529][1591.202461] open() EACCES failure, recently resumed from sleep: false
Jul 25 19:58:47 MacManj org_kde_powerdevil[6395]: [  6529][1591.305823] (recently_resumed_from_sleep_by_clocktime) Called within 5 sec of reset
Jul 25 19:58:47 MacManj org_kde_powerdevil[6395]: [  6529]    Time since last resume from sleep: 140.682 seconds = 140683 millisec (140682900538nanosec)
Jul 25 19:58:47 MacManj org_kde_powerdevil[6395]: [  6529][1591.346269] open() EACCES failure, recently resumed from sleep: false
Jul 25 19:58:47 MacManj org_kde_powerdevil[6395]: [  6529][1591.449622] (recently_resumed_from_sleep_by_clocktime) Called within 5 sec of reset
Jul 25 19:58:47 MacManj org_kde_powerdevil[6395]: [  6529][1591.449624] (dw_watch_display_connections) Recently resumed from sleep detected
Jul 25 19:58:48 MacManj org_kde_powerdevil[6395]: [  6529][1592.906980] (recently_resumed_from_sleep_by_clocktime) Called within 5 sec of reset
Jul 25 19:58:48 MacManj org_kde_powerdevil[6395]: [  6529]    Time since last resume from sleep: 142.284 seconds = 142284 millisec (142284053129nanosec)
Jul 25 19:58:48 MacManj org_kde_powerdevil[6395]: [  6529][1592.943927] open() EACCES failure, recently resumed from sleep: false
Jul 25 19:58:48 MacManj org_kde_powerdevil[6395]: [  6529][1593.051439] (recently_resumed_from_sleep_by_clocktime) Called within 5 sec of reset
Jul 25 19:58:48 MacManj org_kde_powerdevil[6395]: [  6529]    Time since last resume from sleep: 142.428 seconds = 142429 millisec (142428516365nanosec)
Jul 25 19:58:48 MacManj org_kde_powerdevil[6395]: [  6529][1593.095259] open() EACCES failure, recently resumed from sleep: false
Jul 25 19:58:49 MacManj org_kde_powerdevil[6395]: [  6529][1593.204758] (recently_resumed_from_sleep_by_clocktime) Called within 5 sec of reset
Jul 25 19:58:49 MacManj org_kde_powerdevil[6395]: [  6529][1593.204769] (dw_watch_display_connections) Recently resumed from sleep detected
Jul 25 19:58:50 MacManj org_kde_powerdevil[6395]: [  6529][1594.677732] (recently_resumed_from_sleep_by_clocktime) Called within 5 sec of reset
Jul 25 19:58:50 MacManj org_kde_powerdevil[6395]: [  6529]    Time since last resume from sleep: 144.054 seconds = 144055 millisec (144054805785nanosec)
Jul 25 19:58:50 MacManj org_kde_powerdevil[6395]: [  6529][1594.718413] open() EACCES failure, recently resumed from sleep: false
Jul 25 19:58:50 MacManj org_kde_powerdevil[6395]: [  6529][1594.825644] (recently_resumed_from_sleep_by_clocktime) Called within 5 sec of reset
Jul 25 19:58:50 MacManj org_kde_powerdevil[6395]: [  6529]    Time since last resume from sleep: 144.202 seconds = 144203 millisec (144202718461nanosec)
Jul 25 19:58:50 MacManj org_kde_powerdevil[6395]: [  6529][1594.863932] open() EACCES failure, recently resumed from sleep: false
Jul 25 19:58:50 MacManj org_kde_powerdevil[6395]: [  6529][1594.967619] (recently_resumed_from_sleep_by_clocktime) Called within 5 sec of reset
Jul 25 19:58:50 MacManj org_kde_powerdevil[6395]: [  6529][1594.967624] (dw_watch_display_connections) Recently resumed from sleep detected
redid tests 3 and 4,
4 behaves behaves the same
retried a couple more:
manually set to sleep, lid open, a bit later, screen came on, log in, wifi stoped working.
manually set to sleep, lid open, a bit later, tap a key, log in, wifi stoped working.
redid test 4 a couple more times, some 10 seconds after closing the lid, the light on the back of the screen turns on, indicating screen is on, I login, and found no wifi.
when wifi doesn’t work, the following commands from the " Fixing Wi-Fi Connection" page don’t help at all:
$ nmcli networking off
$ nmcli networking on
$ nmcli radio wifi off
$ nmcli radio wifi on
$ sudo systemctl restart NetworkManager.service
$ sudo systemctl restart systemd-networkd
So the situation appears very unpredictable.
Perhaps this helps
https://www.baeldung.com/linux/wifi-connection-fix-no-reboot
In particular https://www.baeldung.com/linux/wifi-connection-fix-no-reboot#2-turning-off-wireless-power-management
updated my previous response
@XJia I have the script below that runs on suspend resume. Note the logging I added to see which events are causing wake-up … but have not yet had a spurious wake after adding this, so no info yet. You might find this useful also. just save as executable file in /usr/lib/systemd/system-sleep/:
@jofi to clarify, I have not installed this update yet. I decided to join the discussion 'cos @XJia 's issue was same as the one I faced after last update. Also, I’m pretty sure that issue is spurious wake-up, rather than specifically anything to do with lid close. Because I was getting the same issue if I put laptop to sleep with systemctl suspend or even systemctl hibernate
also, as I mentioned, it has so far been OK once I disabled Bluetooth. But I have the wake even logger logging events now, will post here with wake counter outputs if I encounter the issue again.
#!/bin/bash
case $1 in
  pre)
    grep -H . /sys/class/wakeup/wakeup*/event_count > /tmp/suspend_events.txt
    if [ -d /sys/module/brcmfmac_wcc ]; then
      /sbin/modprobe -r brcmfmac_wcc brcmfmac
    else
    fi
    /sbin/modprobe -r facetimehd
    sleep 1
    tlp suspend
  post)
    tlp resume
    sleep 1
    /sbin/modprobe brcmfmac
    openvpn reconnect
    /sbin/modprobe facetimehd
    diff /tmp/suspend_events.txt <(grep -H . /sys/class/wakeup/wakeup*/event_count) > /tmp/resume_events_diff.txt
esac
Whether or not it is the same issue is unclear. It could as well be a different issue.
This is the point of the “Fixing Wi-Fi Connection Problems After a Suspend Without Rebooting”.
I think there are two issues. One issue is the unexpected wake-up. For this you could find out what triggered the wake-up by investigating the journalctl. I only gave an example command restricting the search to the boot session with -b, but since you can recall the time of the wake-up you can just go by the timestamps.
Now the other issue is the broken wifi after sleep. The article explains the reason for this and tells you how to prevent it. Please notice if the wifi comes up broken, I don’t think at this point it can make any difference of whether you interact with the networkmanager via the Plasma gui or via command line - it won’t help.
Rather either turning off wireless power management or trying to reload the wifi driver would be options I think.
I went through extended testing assisted by Claude. Disabled quite a few things, booted back to kernel 6.12, didn’t help: the sleep basically all wakes up after about 10 seconds. Now, not much time to test for the exact trigger, I ended up disabling every possible trigger with:
sudo tee /etc/systemd/system/disable-acpi-wakeup.service << 'EOF'
[Unit]
Description=Disable spurious ACPI wakeup sources
After=multi-user.target
[Service]
Type=oneshot
ExecStart=/bin/sh -c 'for dev in RP01 RP02 RP03 ARPT RP05 RP06 XHC1 LID0; do echo $dev > /proc/acpi/wakeup; done'
[Install]
WantedBy=multi-user.target
EOF
sudo systemctl daemon-reload
sudo systemctl enable --now disable-acpi-wakeup.service
~ cat /proc/acpi/wakeup
Device  S-state   Status   Sysfs node
PEG0      S3    *disabled
EC        S4    *disabled  platform:PNP0C09:00
HDEF      S3    *disabled  pci:0000:00:1b.0
RP01      S3    *disabled  pci:0000:00:1c.0
RP02      S3    *disabled  pci:0000:00:1c.1
RP03      S3    *disabled  pci:0000:00:1c.2
ARPT      S4    *disabled  pci:0000:03:00.0
RP05      S3    *disabled  pci:0000:00:1c.4
RP06      S3    *disabled  pci:0000:00:1c.5
SPIT      S3    *disabled  spi:spi-APP000D:00
XHC1      S3    *disabled  pci:0000:00:14.0
ADP1      S4    *disabled  platform:ACPI0003:00
LID0      S4    *disabled  platform:PNP0C0D:00
so only the power button wake it up. The sleep appears to hold.
For the wifi, I ended up with (similar to @ohell suggestion, thanks)
sudo tee /usr/lib/systemd/system-sleep/wifi-reset << 'EOF'
#!/bin/sh
case "$1/$2" in
  post/*)
    sleep 1
    modprobe brcmfmac
esac
EOF
sudo chmod +x /usr/lib/systemd/system-sleep/wifi-reset
Without using the wifi script, these commands re-activate wifi after wakeup:
sudo systemctl stop NetworkManager
sudo ip link set wlp3s0 down
sudo rmmod brcmfmac_wcc
sudo rmmod brcmfmac
sleep 2
sudo modprobe brcmfmac
sudo systemctl start NetworkManager
Now suspend and wifi appear to be working.
BTW, without touching anything on wifi after wakeup, sometimes wifi is up and sometimes not. Perhaps that suggest some kind of a race condition somewhere?
Perhaps one speculation on the cause of the issue:
in prior versions of Manjaro (or Arch), the settings of the triggers were provided somewhere (I don’t remember I set them when using Manjaro, I sure did that in the old days of using Ubuntu), then in this version they were somehow removed or overridden?
