My system is up to date, but when I put the laptop to sleep the Power light / indictator that should pulse when the system is sleeping remains on. My laptop is a Lenovo IdeaPad 5i Pro (11th Gen Intel(R) Core™ i5-1135G7 @ 2.40GHz 2.42 GHz).
For information, I have also changed to the LTS Recommended kernel 6.6.3.1.
How can I resolve this issue please? Many thanks.
Check if kernel 6.1 is better for your system.
Check if a newer firmware is available and see the Arch wiki if there is known issues with your system.
Thank you. I tried kernel 6.1.64-1, and looked at the ArchWiki for Lenovo to no avail. Is there anything else I can try? Thank you.
I have no idea Why is it an issue?
Rather cosmetic I you ask me and not something one cannot live with.
I am happy to live with the issue if I am sure the system is sleeping when I ask it to. Is there a way of checking this?
from
$ systemctl --help
System Commands:
is-system-running Check whether system is fully running
default Enter system default mode
rescue Enter system rescue mode
emergency Enter system emergency mode
halt Shut down and halt the system
poweroff Shut down and power-off the system
reboot Shut down and reboot the system
kexec Shut down and reboot the system with kexec
soft-reboot Shut down and reboot userspace
exit [EXIT_CODE] Request user instance or container exit
switch-root [ROOT [INIT]] Change to a different root file system
suspend Suspend the system
hibernate Hibernate the system
hybrid-sleep Hibernate and suspend the system
suspend-then-hibernate Suspend the system, wake after a period of
time, and hibernate
Thank you. I can Suspend the system from running systemctl suspend
however, the power light remains on, and does not pulse as it would normally when sleeping. systemctl is-system-running
reports running.
Using a 5.15 kernel solved the issue here on a Lenovo Ideapad 14ITL05.
All 6.xx kernels have the problem.
Thank you so much. Installing kernel 5.15 fixed the issue for me, and the power light now pulses when the system is suspended.
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
