I’ve been having some issues with suspend not working with my system, which led me to distro-hop for a while to see if I could resolve it. I decided to come back to Manjaro/XFCE since that’s ultimately what I’m most comfortable with.
I’m still having this issue, but after spending a few days researching it, I have only managed to narrow it down.
Live USB: The suspend feature works perfectly fine as expected where my system gets saved to RAM and the PC shuts down to the expected low power state.
Initial Install: The suspend feature works here just as expected.
System Update: The problem occurs after I update the system. There’s the expected flood or packages that need to be installed, including a bunch of NVidia related ones. When I update everything, something causes suspend and hibernate to break. My guess is that it’s something that happens when I update the NVidia related packages specifically.
Observations: With suspend broken, the system dmesg/journalctl reports that the system has entered into sleep, however the system hangs and doesn’t go into the low power state. Power remains active, monitors disconnect and go to sleep, and nothing wakes the system (keyboard/mouse) and requires a reset to recover from.
Question:
How do I determine what is exactly breaking the suspend once I upgrade the system? If it is something to do with NVidia or the scripts that are provided, how to I change this to allow suspend to work again?
Kernel: 6.1.30-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=79720590-7d0b-4567-aafe-30e1c4442ea3 rw quiet splash apparmor=1
security=apparmor resume=UUID=e4ddc3df-ee4e-4538-ad30-7aa2c49d009b
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7C34 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: MEG X570 GODLIKE (MS-7C34) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.D2
date: 03/23/2021
System RAM: available: 31.26 GiB used: 3.84 GiB (12.3%)
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2311 high: 3598 min/max: 2200/4761 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3598 2: 2200
3: 2052 4: 2013 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2199 11: 2200
12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 17: 3500 18: 2122 19: 2200
20: 2200 21: 2200 22: 2200 23: 2200 24: 3500 25: 2200 26: 2199 27: 2200
28: 2200 29: 2200 30: 2200 31: 2200 32: 2200 bogomips: 224069
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: eVga.com.
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 2f:00.0 chip-ID: 10de:1e07
class-ID: 0300
Device-2: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: eVga.com.
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 30:00.0 chip-ID: 10de:1e07
class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: nvidia gpu: nvidia,nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5120x2880 s-dpi: 96 s-size: 1355x762mm (53.35x30.00")
s-diag: 1555mm (61.2") monitors: <missing: xrandr>
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA TU102 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 10de:10f7
class-ID: 0403
Device-2: NVIDIA TU102 High Definition Audio vendor: eVga.com.
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 30:00.1 chip-ID: 10de:10f7
class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 32:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Logitech G435 Wireless Gaming Headset
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 11-4:2 chip-ID: 046d:0acb class-ID: 0300
serial: <filter>
API: ALSA v: k6.1.30-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Realtek vendor: Micro-Star MSI driver: r8169 v: kernel pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s port: c000
bus-ID: 29:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF: enp41s0 state: down mac: <filter>
Device-2: Realtek Killer E3000 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
port: b000 bus-ID: 2a:00.0 chip-ID: 10ec:3000 class-ID: 0200
IF: enp42s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 2b:00.0
chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:8 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 6.37 TiB used: 101.85 GiB (1.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: FireCuda 520 SSD
ZP2000GM30002 size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: STNSC014
temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD50NMZW-59BCBS0
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 4800 serial: <filter>
fw-rev: 4004 scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.37%) used: 20.71 GiB (1.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 79720590-7d0b-4567-aafe-30e1c4442ea3
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 86F4-E87A
ID-3: /run/media/tellik/Storage raw-size: 4.55 TiB size: 4.55 TiB (100.00%)
used: 81.14 GiB (1.7%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: Storage
uuid: 29A8970140C374AC
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: e4ddc3df-ee4e-4538-ad30-7aa2c49d009b
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-1:2 info: MCT Elektronikladen QUADRO type: HID
driver: aquacomputer_d5next,usbhid interfaces: 2 rev: 2.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 2mA chip-ID: 0c70:f00d
class-ID: 0300 serial: <filter>
Device-2: 1-2:3 info: MCT Elektronikladen QUADRO type: HID
Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Hub-4: 3-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Hub-5: 3-1.4:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Device-1: 3-1.4.3:6 info: Logitech USB Receiver type: mouse,keyboard,HID
lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c547 class-ID: 0300
Device-2: 3-1.4.4:7 info: Logitech USB Receiver type: mouse,keyboard,HID
Device-3: 3-4:8 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-4: 3-5:9 info: MCT Elektronikladen aquaero type: keyboard,HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0c70:f001 class-ID: 0300
serial: <filter>
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-7: 4-1:2 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Device-1: 4-1.2:4 info: Western Digital Game Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 1058:2630 class-ID: 0806
serial: <filter>
Hub-8: 4-1.4:3 info: Realtek Hub ports: 4 rev: 3.2
Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 5-5:2 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c34 class-ID: 0300
serial: <filter>
Hub-10: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-11: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-12: 8-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-13: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-14: 10-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-15: 11-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 11-4:2 info: Logitech G435 Wireless Gaming Headset
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
chip-ID: 046d:0acb class-ID: 0300 serial: <filter>
Hub-16: 12-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 36.8 C mobo: N/A gpu: nvidia temp: 26 C
Processes: 489 Uptime: 1h 16m wakeups: 3 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1041 pm: pacman pkgs: 1034 libs: 313 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 7 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.27
