Good day everyone . I am a musician looking to install the excellent Surge XT synthesizer ( Sorry cant post a link yet )
There is however only a .deb file and I have seen dire warnings , both here and around the web about installing these . I have spent a few days getting this music PC exactly as I want it so I am not inclined to break it now
I have the AUR working and octopi installed and cannot see Surge XT as yet . Is this likely to be added?
Well, what you could do ─ but this is entirely on your hands, and Manjaro will assume no responsibility if it breaks your system ─ is install debtap from the AUR and use that for converting the .deb file into an ALPM-compatible package that you can then install with pacman.
pamac build debtap
I’ve never used it, but I suppose its usage will be something along the lines of…
debtap name-of-package.deb
… and then followed by…
sudo pacman -U name-of-package.tar.zst
Be sure to check out first if the script has any options.
Thank you both again . I will wait a bit , its only just been released . I had already looked at debtap and decided that it was very much a dirty “last resort”
