Kernel Panic when entering Hibernation
Manjaro KDE - Kernel 5.10.15-1-MANJARO
What is the issue?
Currently, whenever I try to enter a state of “Hibernation” on my system I get a guaranteed “Kernel Panic” every single time. The system in it’s current state has never previously given me ANY other “Kernel Panic’s” and as this is the first time I have setup & attempted to use the “Hibernate” feature I am pretty sure that the issue (Kernel Panic) is only triggerable by attempting to “Hibernate”.
The problem is that because it is entering a “Kernel Panic” every time, the “Hibernation” feature becomes unusable and it is rather disappointing that for me such a feature is currently not available to be utilised.
The exact text that the system outputs is as follows:
(Please take note that I am having to type this in manually and it is NOT copied from the system itself!)
[445.546863] Kernel Panic - not syncing: stack-protector: Kernel stack is corrupted in: sata_pmp_error_handler+0x97b/0x980
[445.551968] CPU: 0 PID: 373 Comm: scsi_eh_11 Tainted: G W 0E 5.10.15-1-MANJARO #1
[445.552005] Hardware name: Gigabyte Technology Co. , Ltd. X399 DESIGNARE EX/X399 DESIGNARE EX-CF, BIOS F12i 09/24/2019
[445.552050] Call Trace:
[445.552069] dump_stack+0x6b/0x83
[445.552088] panic+0x112/0x2e8
[445.552104] ? sata_pmp_error_handler+0x97b/0x980
[445.552127] __stack_chk_fail+0x10/0x10
[445.552146] sata_pmp_error_handler+0x97b/0x980
[445.552168] ? ahci_do_hardreset+0x170/0x170
[445.552189] ? ahci_stop_engine+0xb0/0xb0
[445.552208] ? ahci_do_softreset+0x280/0x280
[445.552229] ? trace_event_raw_event_ata_qc_complete_template+0x170/0x170
[445.552260] ahci_error_handler+0x3e/0x70
[445.552280] ata_scsi_port_error_handler+0x3cd/0x880
[445.552303] ata_scsi_error+0x91/0xc0
[445.552322] scsi error_handler+0xd1/0x510
[445.552342] ? scsi_eh_get_sense+0x210/0x210
[445.552363] kthread+0x133/0x150
[445.552380] ? __kthread_bind_mask+0x60/0x60
[445.552401] ret_from_fork+0x22/0x30
[445.552843] Kernel Offset: 0x20000000 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffffbfffffff)
[446.132813] —[ end Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: sata_pmp_error_handler+0x97b/0x980 ]—
I am at a loss as to what exactly is not working as it should, so if anyone at all could lend me a hand in diagnosing this issue then it would be most helpful.
Thank you in advance to anyone that steps forwards
