If I run systemctl suspend or systemctl hibernate, I encounter a kernel panic.
I found this discussion but there wasn’t a solution at the end. I would like to fix it. How should I proceed?
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0d86c603-749a-4229-89cd-ee0bb4367343 rw quiet apparmor=1
security=apparmor resume=UUID=4070649a-698d-441f-83fd-b5d3373c12bf
udev.log_priority=3
Desktop: i3 4.19.1 info: i3bar vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: ASUSTeK product: ZenBook S UX391UA v: 1.0
serial: <filter>
Mobo: ASUSTeK model: UX391UA v: 1.0 serial: <filter>
UEFI: American Megatrends v: UX391UA.307 date: 04/27/2020
ID-1: BAT0 charge: 24.1 Wh (62.3%) condition: 38.7/50.0 Wh (77.3%)
volts: 7.9 min: 7.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Charging cycles: 782
RAM: total: 7.62 GiB used: 2 GiB (26.2%)
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 8 MiB bogomips: 32012
Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 799 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 13d3:56b9 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: picom v: git-dac85 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 166 size: 293x165mm (11.5x6.5")
diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.38 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-8:3 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 238.47 GiB used: 41.98 GiB (17.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD9SN8W256G1002
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3002 scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
used: 41.98 GiB (18.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 0d86c603-749a-4229-89cd-ee0bb4367343
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: E0EF-3CA8
dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 4070649a-698d-441f-83fd-b5d3373c12bf
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-5:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Device-2: 1-8:3 info: Intel Bluetooth wireless interface type: Bluetooth
Device-3: 1-9:4 info: Shenzhen Goodix Fingerprint Reader
type: Abstract (modem),CDC-Data driver: cdc_acm interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5201 class-ID: 0a00
serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 238 Uptime: 5m wakeups: 717 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1360 lib: 377
flatpak: 0 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.08
journalctl --no-pager --no-hostname -b-1 -p3 (run right after the system rebooted)
-- Journal begins at Sun 2021-10-17 12:52:54 IST, ends at Thu 2021-11-11 13:12:22 IST. --
Nov 11 12:57:55 kernel: x86/cpu: SGX disabled by BIOS.
Some more details asked in that thread
dinskid@dinskid-zenbooksux391ua ~$ journalctl --no-pager --no-hostname -b-1 -p3
dinskid@dinskid-zenbooksux391ua ~$ cat /etc/fstab |grep swap
UUID=4070649a-698d-441f-83fd-b5d3373c12bf swap swap defaults,noatime 0 0
dinskid@dinskid-zenbooksux391ua ~$ cat /etc/default/grub |grep resume
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=4070649a-698d-441f-83fd-b5d3373c12bf udev.log_priority=3"
dinskid@dinskid-zenbooksux391ua ~$ cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=0d86c603-749a-4229-89cd-ee0bb4367343 rw quiet apparmor=1 security=apparmor resume=UUID=4070649a-698d-441f-83fd-b5d3373c12bf udev.log_priority=3
dinskid@dinskid-zenbooksux391ua ~$ journalctl -u systemd-hibernate.service --no-pager --no-hostname
-- Journal begins at Sun 2021-10-17 12:52:54 IST, ends at Thu 2021-11-11 13:12:44 IST. --
Oct 29 21:48:55 systemd[1]: Starting Hibernate...
Oct 29 21:48:55 systemd-sleep[11319]: Entering sleep state 'hibernate'...
Oct 29 21:50:32 systemd-sleep[11319]: System returned from sleep state.
Oct 29 21:50:33 systemd[1]: systemd-hibernate.service: Deactivated successfully.
Oct 29 21:50:33 systemd[1]: Finished Hibernate.
Oct 29 21:50:33 systemd[1]: systemd-hibernate.service: Consumed 11.382s CPU time.
-- Boot 3be92d20f67645ecadcaa952d9008c65 --
Nov 11 11:35:41 systemd[1]: Starting Hibernate...
Nov 11 11:35:41 systemd-sleep[6481]: Entering sleep state 'hibernate'...
Nov 11 11:36:17 systemd-sleep[6481]: System returned from sleep state.
Nov 11 11:36:17 systemd[1]: systemd-hibernate.service: Deactivated successfully.
Nov 11 11:36:17 systemd[1]: Finished Hibernate.
Nov 11 11:36:17 systemd[1]: systemd-hibernate.service: Consumed 1.631s CPU time.
Nov 11 11:36:52 systemd[1]: Starting Hibernate...
Nov 11 11:36:52 systemd-sleep[6872]: Entering sleep state 'hibernate'...
Nov 11 11:38:16 systemd-sleep[6872]: System returned from sleep state.
Nov 11 11:38:16 systemd[1]: systemd-hibernate.service: Deactivated successfully.
Nov 11 11:38:16 systemd[1]: Finished Hibernate.
Nov 11 11:38:16 systemd[1]: systemd-hibernate.service: Consumed 1.669s CPU time.
-- Boot fd0aff27f08348b5bb971d985baa08ca --
Nov 11 12:05:34 systemd[1]: Starting Hibernate...
Nov 11 12:05:34 systemd-sleep[2919]: Entering sleep state 'hibernate'...
Nov 11 12:06:35 systemd-sleep[2919]: System returned from sleep state.
Nov 11 12:06:35 systemd[1]: systemd-hibernate.service: Deactivated successfully.
Nov 11 12:06:35 systemd[1]: Finished Hibernate.
Thank you.
