The Vulkan update for RPi 4 (v3dv) was merged to mesa recently, on 20th Oct.
It can also be found in the mesa source history when filtered by v3dv (commits 27th Nov onward).
Sorry, I am unable to include links in my posts.
I was wondering if Manjaro on aarch64 will also get this and do we expect graphics performance improvements because of this?
I see my version is 20.2.3-1 (built on Tue 24 Nov 2020)
at 19:09:45 ❯ pacman -Q --info mesa
Version : 20.2.3-1
Description : An open-source implementation of the OpenGL specification
Architecture : aarch64
URL : https://www.mesa3d.org/
Licenses : custom
Groups : None
Provides : mesa-libgl opengl-driver
Depends On : libdrm wayland libxxf86vm libxdamage libxshmfence libelf libomxil-bellagio
libunwind llvm-libs lm_sensors libglvnd zstd vulkan-icd-loader
Optional Deps : opengl-man-pages: for the OpenGL API man pages
mesa-vdpau: for accelerated video playback
libva-mesa-driver: for accelerated video playback
Required By : gtk3 libglvnd mpv qt5-base
Optional For : None
Conflicts With : mesa-libgl
Replaces : mesa-libgl
Installed Size : 52.66 MiB
Packager : Arch Linux ARM Build System <builder+n1@archlinuxarm.org>
Build Date : Tue 24 Nov 2020 11:56:45 PM IST
Install Date : Wed 09 Dec 2020 08:21:29 PM IST
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
I haven’t been able to try it out yet. I found out that I don’t have a USB 3.0 flash drive (its been ages since I used one) and my Mac doesn’t have SD Card port
I changed to mesa-20.3 (not the git version) and Vulkan support is not working… it should be. But OpenGL hardware acceleration is working. I am sure the Vulkan support will be restored soon.
$ vblank_mode=0 glxgears
ATTENTION: default value of option vblank_mode overridden by environment.
7488 frames in 5.0 seconds = 1497.563 FPS
7693 frames in 5.0 seconds = 1538.531 FPS
7641 frames in 5.0 seconds = 1528.133 FPS
7387 frames in 5.0 seconds = 1477.278 FPS
$ glxinfo | grep OpenGL
OpenGL vendor string: Broadcom
OpenGL renderer string: V3D 4.2
OpenGL version string: 2.1 Mesa 20.3.0
OpenGL shading language version string: 1.20
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 20.3.0
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
OpenGL ES profile extensions:
To test for Vulkan support, the easiest is to install vulkan-tools.
This is what it looks like when no support:
$ vulkaninfo
Cannot create Vulkan instance.
This problem is often caused by a faulty installation of the Vulkan driver or attempting to use a GPU that does not support Vulkan.
ERROR at /build/vulkan-tools/src/Vulkan-Tools-1.2.162/vulkaninfo/vulkaninfo.h:666:vkCreateInstance failed with ERROR_INCOMPATIBLE_DRIVER
I’m using KDE and also switched to Wayland on my RPi 400 since compositing is broken with kwin, at least with all the latest packages (starting with mesa 20.3, kwin X11 doesn’t play nice with it).
Plasma wayland works really great, a fantastic experience.
I compiled mesa-git with zink enabled and tried to force opengl through vulkan this way. The opengl test apps worked great but KDE X11 had some corrupted visuals but that might also be due to the broken compositing.
I’m not sure how kde wayland works because doesn’t wayland use EGL ? The kde display options offer opengl though.
The fps from glxgears in the above tests were run while using a 1920x1080 monitor.
This is while using a 4K monitor:
2922 frames in 5.0 seconds = 584.382 FPS
3314 frames in 5.0 seconds = 662.731 FPS
2849 frames in 5.0 seconds = 569.761 FPS
2875 frames in 5.0 seconds = 574.981 FPS
2885 frames in 5.0 seconds = 576.985 FPS
Much improved from my previous tests, about 20x better. Before these recent updates, it struggled to stay above 30 fps. It still bounces around a bit when I run the test longer, so I think there is more improvement to come.
and firefox 84.0 with layers.acceleration.force-enabled set to true in the about:config, h264ify with 60fps blocked and performance is absolutely nuts. I am absolutely pleased with how it’s handling youtube and what this machine is pulling off.
Note that my overclock settings are really pushing rpi400 to its limits so if you want to adapt similar options USE AT YOUR OWN RISK!!
—glxgears test run in the default window size @ 1920x1080
8962 frames in 5.0 seconds = 1792.285 FPS
9068 frames in 5.0 seconds = 1813.500 FPS
8981 frames in 5.0 seconds = 1796.108 FPS
8905 frames in 5.0 seconds = 1780.945 FPS
9118 frames in 5.0 seconds = 1823.481 FPS
If anyone has any other optimization suggestions please let us know!
