Since last week my superbar isn’t working as it should
I cannot slect wifi networks and neither can access bluetooth and volume control
Is the a command that reinstalls the bar? I cannot reinstall the os as I use it for work purposes.
what you see in the pic is just wifi signal
superbar? sounds like an AUR PKGBUILD - if it is then rebuilding would suffice
pamac build superbar
target not found: superbar
Then what is your environment, where did you get it and how did you install it?
I have xfce, manjaro 20.1
I have no idea what that superbar is - it must be something you installed.
It’s the bar that is default installed on the bottom of the screen where you find menu, apps, etc.
I call it superbar because I come from windows
On Linux, it’s called a panel.
It’s only called a “superbar” in Windows 7, even then I never hear anyone use that term. Every other version is called a Task Bar.
so… how do I rebuild my broken panel
