Sudo: timed out - how to install without rebuilding?
After issuing this command:
yay -Syyu
I was asked to immediately entered my password.
I’ve left my computer compiling for 9 hours and now it failed to install qt5-webengine, and a few others listed below - notably blackmagic decklink kernel module aswell.
I’m wondering how to install these without recompiling thanks! (o:
im afraid to reboot right now as the kernel module wasn’t installed properly.
Thanks!
[sudo] password for resove:
sudo: timed out reading password
sudo: a password is required
 -> error installing: [/home/resove/.cache/yay/qt5-webengine/qt5-webengine-5.15.19-4-x86_64.pkg.tar.zst /home/resove/.cache/yay/clutter/clutter-1.26.4-4-x86_64.pkg.tar.zst /home/resove/.cache/yay/gcc14/gcc14-libs-14.3.1+r516+g5998566829ee-1-x86_64.pkg.tar.zst /home/resove/.cache/yay/openssl-1.1/openssl-1.1-1.1.1.w-9-x86_64.pkg.tar.zst] - exit status 1
error installing: [/home/resove/.cache/yay/botan2/botan2-2.19.5-4-x86_64.pkg.tar.zst /home/resove/.cache/yay/ncurses5-compat-libs/ncurses5-compat-libs-6.6-1-x86_64.pkg.tar.zst /home/resove/.cache/yay/gcc14/gcc14-libs-14.3.1+r516+g5998566829ee-1-x86_64.pkg.tar.zst /home/resove/.cache/yay/gcc14/gcc14-14.3.1+r516+g5998566829ee-1-x86_64.pkg.tar.zst /home/resove/.cache/yay/qt5-webengine/qt5-webengine-5.15.19-4-x86_64.pkg.tar.zst /home/resove/.cache/yay/reiserfsprogs/reiserfsprogs-3.6.27-7-x86_64.pkg.tar.zst /home/resove/.cache/yay/stremio/stremio-4.4.183-1-x86_64.pkg.tar.zst /home/resove/.cache/yay/decklink/decklink-16.0-1-x86_64.pkg.tar.zst /home/resove/.cache/yay/qt5-websockets/qt5-websockets-5.15.18+kde+r2-1-x86_64.pkg.tar.zst /home/resove/.cache/yay/lib32-openssl-1.1/lib32-openssl-1.1-1.1.1.w-3-x86_64.pkg.tar.zst /home/resove/.cache/yay/clutter-gtk/clutter-gtk-1.8.4-5-x86_64.pkg.tar.zst /home/resove/.cache/yay/clutter/clutter-1.26.4-4-x86_64.pkg.tar.zst /home/resove/.cache/yay/openssl-1.1/openssl-1.1-1.1.1.w-9-x86_64.pkg.tar.zst /home/resove/.cache/yay/libtiff4/libtiff4-3.9.7-8-x86_64.pkg.tar.zst] - exit status 1
  Kernel: 6.12.73-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=xx rw quiet
    cryptdevice=UUID=xx:luks-xx
    root=/dev/mapper/luks-xx splash
    apparmor=1 security=apparmor
    resume=/dev/mapper/luks-xx
    udev.log_priority=3
  Desktop: GNOME v: 49.5 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy avail: lxlock dm: GDM v: 49.2 Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
  Mobo: ASUSTeK model: ProArt X570-CREATOR WIFI v: Rev X.0x serial: <filter>
    part-nu: SKU uuid: xx Firmware: UEFI
    vendor: American Megatrends v: 1505 date: 03/18/2024
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540e
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: AMD Ryzen 7 5700G with Radeon Graphics socket: AM4 bits: 64
    type: MT MCP arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500012
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3768 min/max: 400/4673 boost: enabled
    base/boost: 3800/4650 scaling: driver: amd-pstate-epp governor: performance
    volts: 1.4 V ext-clock: 100 MHz cores: 1: 3768 2: 3768 3: 3768 4: 3768
    5: 3768 6: 3768 7: 3768 8: 3768 9: 3768 10: 3768 11: 3768 12: 3768
    13: 3768 14: 3768 15: 3768 16: 3768 bogomips: 121423
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
    ssse3 svm
    affected
  Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti 16GB] vendor: Gigabyte
    driver: nouveau v: kernel non-free: 550-580.xx+
    status: current (as of 2025-11) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s ports: active: none empty: DP-1, DP-2,
    HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:2805 class-ID: 0300
  Device-2: Blackmagic Design DeckLink 4K Extreme 12G driver: N/A pcie:
    gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 bus-ID: 3e:00.0
    chip-ID: bdbd:a136 class-ID: 0400
  Device-3: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: HDMI-A-3 empty: DP-3,DP-4 bus-ID: 40:00.0
    chip-ID: 1002:1638 class-ID: 0300 temp: 31.0 C
  Display: unspecified server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
    compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4096x2160 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-3 mapped: HDMI-3 model: LG (GoldStar) TV SSCR2
    serial: <filter> built: 2024 res: mode: 4096x2160 hz: 30 scale: 100% (1)
    dpi: 65 gamma: 1.2 size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3")
    ratio: 16:9 modes: max: 3840x2160 min: 720x400
    device: 1 drv: zink device: 2 drv: swrast gbm: drv: radeonsi surfaceless:
    drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.2-arch1.1
    renoir ACO DRM 3.61 6.12.73-1-MANJARO) device-ID: 1002:1638
    memory: 1.95 GiB unified: no
  Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
  Device-1: NVIDIA AD106M High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:22bd
    class-ID: 0403
  Device-3: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 40:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-4: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASUSTeK
    bus-ID: 40:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.73-1-MANJARO status: kernel-api with: aoss
  Server-2: JACK v: 1.9.22 status: off with: nsmd status: off tools: N/A
  Server-3: PipeWire v: 1.6.2 status: n/a (root, process) with:
  Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 39:00.0
    chip-ID: 8086:2725 class-ID: 0280
  IF: wlp57s0 state: down mac: <filter>
  Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 3a:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp58s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:6 chip-ID: 8087:0032
    class-ID: e001
  Local Storage: total: 3.64 TiB used: 791.92 GiB (21.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Western Digital model: WD BLACK
    SN850P for PS5 2000GB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 620311WD temp: 43.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 42.9 C
    scheme: GPT
  ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (99.95%) used: 791.92 GiB (42.7%)
    fs: xfs block-size: 512 B dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-xx
    used: 696 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
    maj-min: 259:1
    dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-xx
  System Temperatures: cpu: 33.0 C mobo: 34.0 C gpu: amdgpu temp: 31.0 C
  Fan Speeds (rpm): cpu: 0
  Memory: total: 128 GiB note: est. available: 123.62 GiB
    used: 7.21 GiB (5.8%)
  Processes: 455 Power: uptime: 9h 54m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 49.41 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1825 libs: 536 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 0 Compilers: clang: 22.1.1 gcc: 15.2.1 alt: 13/14
    Shell: Sudo (sudo) v: 1.9.17p2 default: Bash v: 5.3.9
    running-in: gnome-terminal inxi: 3.3.40
in your sudoers, add Defaults:<your user name> !authenticate
forgive my ignorance, but im guessing you are referring to a file that i should edit that’s probably in
/etc/
but I don’t know what this sentence means (o:
The package is still in the cache.
You should be able to install it using pacman -U
sudo pacman -U /home/resove/.cache/yay/qt5-webengine/qt5-webengine-5.15.19-4-x86_64.pkg.tar.zst
To avoid issues like this - build all packages before you installation.
You may need to figure out the correct build order as some may be depending on other custom packages.
is it safe to reboot or will my gui break?
sudo pacman -U /home//resove/.cache/yay/decklink/decklink-16.0-1-x86_64.pkg.tar.zst
loading packages...
resolving dependencies...
Packages (1) decklink-16.0-1
Total Installed Size:  330.86 MiB
Net Upgrade Size:       47.88 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring                                            [##########################################] 100%
(1/1) checking package integrity                                          [##########################################] 100%
(1/1) loading package files                                               [##########################################] 100%
(1/1) checking for file conflicts                                         [##########################################] 100%
(1/1) checking available disk space                                       [##########################################] 100%
(1/2) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/2) Remove DKMS modules
(1/1) upgrading decklink                                                  [##########################################] 100%
(1/7) Reloading system manager configuration...
(2/7) Restarting marked services...
(3/7) Arming ConditionNeedsUpdate...
(4/7) Install DKMS modules
==> ERROR: Missing proc kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing lib64 kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing boot kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing sys kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing lib kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing srv kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing root kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing sys kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing rootfs-pkgs.txt kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing home kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing root kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing crypto_keyfile.bin kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing opt kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing var kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing usr kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing boot kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing sbin kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing dev kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing dev kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing var kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing usr kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing home kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing etc kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing desktopfs-pkgs.txt kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing etc kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing tmp kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing rootfs-pkgs.txt kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing desktopfs-pkgs.txt kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing mnt kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing bin kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing lib kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing run kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing srv kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing bin kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing proc kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing mnt kernel headers for module blackmagic-io/16.0a14.
==> ERROR: Missing tmp kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing opt kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing run kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing sbin kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing crypto_keyfile.bin kernel headers for module blackmagic/16.0a14.
==> ERROR: Missing lib64 kernel headers for module blackmagic-io/16.0a14.
(5/7) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
==> Starting build: '6.12.77-1-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [microcode]
  -> Running build hook: [kms]
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [plymouth]
  -> Running build hook: [encrypt]
  -> Running build hook: [openswap]
==> WARNING: you are using potentially dangerous unlock_method keyfile, please make sure you know what you are doing
==> WARNING: https://docs.kernel.org/power/swsusp.html
==> WARNING: https://wiki.archlinux.org/title/Dm-crypt/Swap_encryption#busybox-based_initramfs
==> WARNING: keyfile_device_mount_options variable is not set and unlock_method is set to keyfile
  -> Running build hook: [resume]
  -> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
  -> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
  -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
==> Starting build: '6.6.128-1-MANJARO'
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
(6/7) Updating icon theme caches...
(7/7) Updating the desktop file MIME type cache...
I have no idea - because I don’t know what you are trying to achieve - I cannot predict the result.
Perhaps you should install all the packages mentioned on the error line
But you are on thin ice here - it looks very much like trouble - especially the gcc14 part worries me as this is an important system component.
With knowing what your goal is - it looks like an army of :dragon_face:
:high_voltage: :warning: :dragon: :dragon:
I would recommend that you also check to see if any of those AUR packages that yay is building are actually needed on your system. For example, qt5-webengine was removed from the repos last year, so no packages in the repos require it.
reiserfs hasn’t been in the kernel since linux613, so unless you have a drive formatted as reiserfs (is that why you are still on linux612?), then you can safely remove reiserfsprogs from your system.
To list all foreign packages (i.e. packages not in Manjaro’s repos) on your system, run the command:
pamac list -m
You can check each package’s dependencies to see if it is required by any other package with the following command:
pamac info the_package_name
For example:
pamac info reiserfsprogs
You should probably check for orphaned packages too. These are packages which were installed as dependencies of other packages which have since been removed from your system, or no longer require the orphaned package due to a change in dependencies.
To list your orphaned packages:
pamac list -o
Finally, when updating your system, you should always update the repo packages first:
sudo pacman -Syu
or
pamac update --no-aur
I don’t use yay, so I’m not sure of the exact command to run to skip the AUR when updating.
i need webengine*(edit) for stremio, im on 6.12 for blackmagic resolve’s decklink video card, for resolve studio, a few old external disks i need to access possibly for a film project were delivered in reiserfs, and i haven’t converted them for something else yet.
manjaro thinks there’s quite a few orphans, but i know i use those apps like cmake and some of these installed ones for dependencies for these programs i compiled myself
thanks for all that info though!
i’ll reference yay documentation for the rest - and start a new topic for a different graphics issue if it perists after this update.
If we split the above out in a a way we can understand - it appears you have all the necessary packages - you simply have to run the below command - pointing to all packages in one go.
:warning: :high_voltage:
Copy paste the command - should do the trick - but gcc14 is problematic and may cause interference with the system gcc.
sudo pacman -U \
 /home/resove/.cache/yay/botan2/botan2-2.19.5-4-x86_64.pkg.tar.zst \
 /home/resove/.cache/yay/ncurses5-compat-libs/ncurses5-compat-libs-6.6-1-x86_64.pkg.tar.zst \
 /home/resove/.cache/yay/gcc14/gcc14-libs-14.3.1+r516+g5998566829ee-1-x86_64.pkg.tar.zst \
 /home/resove/.cache/yay/gcc14/gcc14-14.3.1+r516+g5998566829ee-1-x86_64.pkg.tar.zst \
 /home/resove/.cache/yay/qt5-webengine/qt5-webengine-5.15.19-4-x86_64.pkg.tar.zst \
 /home/resove/.cache/yay/reiserfsprogs/reiserfsprogs-3.6.27-7-x86_64.pkg.tar.zst \
 /home/resove/.cache/yay/stremio/stremio-4.4.183-1-x86_64.pkg.tar.zst \
 /home/resove/.cache/yay/decklink/decklink-16.0-1-x86_64.pkg.tar.zst \
 /home/resove/.cache/yay/qt5-websockets/qt5-websockets-5.15.18+kde+r2-1-x86_64.pkg.tar.zst \
 /home/resove/.cache/yay/lib32-openssl-1.1/lib32-openssl-1.1-1.1.1.w-3-x86_64.pkg.tar.zst \
 /home/resove/.cache/yay/clutter-gtk/clutter-gtk-1.8.4-5-x86_64.pkg.tar.zst \
 /home/resove/.cache/yay/clutter/clutter-1.26.4-4-x86_64.pkg.tar.zst \
 /home/resove/.cache/yay/openssl-1.1/openssl-1.1-1.1.1.w-9-x86_64.pkg.tar.zst \
Validate the result - I am still worried about the gcc14 packages since it interferes with the systems gcc - you are on very thin ice - perhaps you should ensure you are using unstable branch and run a full update before rebooting
Manjaro uses gcc15 - so you are about to wreck your system completely - I think you should reconsider what you are doing.
 $ mbn info gcc -q
Branch         : archlinux
Version        : 15.2.1+r604+g0b99615a8aef-1
Repository     : core
Build Date     : Mon 09 Feb 2026 14:52:14
Packager       : Frederik Schwan <freswa@archlinux.org>
Branch         : unstable
Repository     : core
Branch         : testing
Repository     : core
Branch         : stable
Repository     : core
Thanks @scotty65 and @ManjaroDevOps
I did in fact pacman -Syyu before I did yay -Syyu
Sometimes the AUR either has not had packages I needed or been unreliable (a package I wanted wasn’t maintained) for me, so I just built and installed a few from the source, but some of the build scripts I’ve seen install dependencies, and while I would often try and manually look for each of the dependencies in the official repos or the AUR first, sometimes I couldn’t find them and had to manually install them.
Im really unsure how to parse all this information and understand how i’d go about fixing the installation as I can see a lot of stuff there in these lists that I’d need to have a system that does what I need, but I can also see a lot of bloat. I’m really unsure of how to proceed other than to move to a fixed release and build a static setup that works for video editing, and then giveup rolling releases for everything else I use? which usually means I can’t use it as the old static OSes like RockyOS that blackmagic recommends, that don’t support modern apps like the current versions of Signal Messenger or Element Messenger, or even playing back modern media files outside the video editing software.
I was able to use a slightly older kernel and still have a working workstation until recently, and now I am trying to play catchup with updates and not sure what to do with this specific system. The other systems dont have this issue, i just update them normally with add/remove software program and i don’t even think any of them have any foreign packages, or like 1-2 compared to this system.
Over the last 2-3 years that’s resulted in this mess:
# pamac list -m
botan2                            2.19.5-4                     AUR  22.9 MB
clutter                           1.26.4-4                     AUR  18.1 MB
clutter-gtk                       1.8.4-5                      AUR  252.4 kB
cogl                              1.22.8-5                     AUR  4.8 MB
decklink                          16.0-1                       AUR  346.9 MB
gcc13                             13.4.1+r80+gd6ebfe4-1        AUR  163.1 MB
gcc13-libs                        13.4.1+r80+gd6ebfe4-1        AUR  731.8 kB
gcc14                             14.3.1+r516+g5998566829ee-1  AUR  181.2 MB
gcc14-libs                        14.3.1+r516+g5998566829ee-1  AUR  918.2 kB
glew1.10                          1.10.0-4                     AUR  522.1 kB
gnome-shell-extension-x11gestures 25-1                         AUR  38.9 kB
gstreamer0.10                     0.10.36-20                   AUR  11.1 MB
gstreamer0.10-base                0.10.36-13                   AUR  9.2 MB
gtk2                              2.24.33-5                    AUR  38.2 MB
lib32-glew1.10                    1.10.0-6                     AUR  509.1 kB
lib32-gtk2                        2.24.33-5                    AUR  6.2 MB
lib32-libappindicator-gtk2        12.10.0.r298-5               AUR  66.1 kB
lib32-libdbusmenu-gtk2            16.04.0-7                    AUR  67.1 kB
lib32-libgcrypt15                 1.5.6-8                      AUR  532.9 kB
lib32-libidn11                    1.33-3                       AUR  206.2 kB
lib32-libindicator-gtk2           12.10.1-11                   AUR  68.6 kB
lib32-libjpeg6-turbo              1.5.3-4                      AUR  372.6 kB
lib32-libpng12                    1.2.59-3                     AUR  355.4 kB
lib32-librtmp0                    2.6-1                        AUR  116.0 kB
lib32-libtiff4                    3.9.7-6                      AUR  412.7 kB
lib32-libudev0-shim               2-1                          AUR  13.6 kB
lib32-libvpx1.3                   1.3.0-4                      AUR  1.8 MB
lib32-openssl-1.0                 1.0.2.u-4                    AUR  3.2 MB
lib32-openssl-1.1                 1.1.1.w-2                    AUR  3.0 MB
libdbusmenu-gtk2                  16.04.0.r498-3               AUR  136.1 kB
libgcrypt15                       1.5.6-7                      AUR  544.5 kB
libidn11                          1.33-3                       AUR  210.9 kB
libindicator-gtk2                 12.10.1-11                   AUR  99.8 kB
libjpeg6-turbo                    1.5.3-3                      AUR  344.6 kB
liboil                            0.3.17-3                     AUR  1.5 MB
libpng12                          1.2.59-2                     AUR  569.1 kB
librtmp0                          2.4-6                        AUR  108.5 kB
libtiff4                          3.9.7-8                      AUR  447.8 kB
libudev0-shim                     2-2                          AUR  14.1 kB
libvisual                         0.4.2-2                      AUR  571.4 kB
ncurses5-compat-libs              6.6-1                        AUR  1.2 MB
openssl-1.0                       1.0.2.u-7                    AUR  5.9 MB
openssl-1.1                       1.1.1.w-9                    AUR  5.4 MB
qt5-webchannel                    5.15.18+kde+r3-1             AUR  234.0 kB
qt5-webengine                     5.15.19-4                    AUR  167.0 MB
qt5-websockets                    5.15.18+kde+r2-1             AUR  298.0 kB
reiserfsprogs                     3.6.27-7                     AUR  614.9 kB
steam-native-runtime              1.0.0.75-8                   AUR  8.2 kB
stremio                           4.4.183-1                    AUR  12.8 MB
# pamac list -o
adobe-source-code-pro-fonts 2.042u+1.062i+1.026vf-2      extra     2.0 MB
appstream-glib              0.8.3-3                      extra     3.8 MB
boost                       1.89.0-4                     extra     195.3 MB
breezy                      3.3.21-2                     extra     60.4 MB
cantarell-fonts             1:0.311-1                    extra     198.0 kB
cmake                       4.2.3-1                      extra     97.4 MB
dejagnu                     1.6.3-16                     extra     625.4 kB
doxygen                     1.16.1-3                     extra     21.8 MB
dynamic-wallpaper           0.1.0-3                      extra     100.1 kB
electron34                  34.5.8-1                     extra     270.9 MB
electron35                  35.7.5-1                     extra     283.7 MB
electron36                  36.9.3-1                     extra     284.9 MB
electron37                  37.5.1-1                     extra     296.3 MB
electron38                  38.8.0-1                     extra     291.8 MB
gcc-ada                     15.2.1+r604+g0b99615a8aef-1  core      168.9 MB
gcc-d                       15.2.1+r604+g0b99615a8aef-1  core      131.4 MB
gnome-common                3.18.0-5                     extra     20.9 kB
go                          2:1.26.1-1                   extra     225.9 MB
gobject-introspection       1.86.0-2                     extra     3.3 MB
gperf                       3.3-2                        extra     243.6 kB
js128                       128.14.0-1                   extra     79.9 MB
kauth                       6.24.0-1                     extra     425.6 kB
kwindowsystem5              5.116.0-2                    extra     729.3 kB
lib32-libcap                2.77-1                       multilib  96.8 kB
libayatana-indicator        0.9.4-1                      extra     120.0 kB
libgnome-games-support      1.8.2-4                      extra     189.9 kB
libgnome-games-support-2    2.0.2-1                      extra     196.3 kB
libinstpatch                1.1.7-2                      extra     1.2 MB
libomxil-bellagio           0.9.3-5                      extra     612.3 kB
libtar                      1.2.20-7                     extra     85.7 kB
meson                       1.10.2-1                     extra     16.9 MB
nasm                        3.01-1                       extra     5.5 MB
python-sphinx               9.1.0-1                      extra     24.9 MB
qt6-wayland                 6.10.2-1                     extra     5.0 MB
vala                        0.56.18-5                    extra     15.1 MB
valgrind                    3.25.1-4                     extra     78.0 MB
vcdimager                   2.0.1-7                      extra     823.8 kB
vulkan-headers              1:1.4.341.0-1                extra     38.5 MB
webkit2gtk                  2.50.6-1                     extra     134.1 MB
yasm                        1.3.0-9                      extra     3.9 MB
# pacreport --unowned-files
Unowned Files:
  /.manjaro-tools
  /boot/efi/
  /boot/grub/
  /crypto_keyfile.bin
  /desktopfs-pkgs.txt
  /etc/.pwd.lock
  /etc/.updated
  /etc/NetworkManager/system-connections/TELUS8521.nmconnection
  /etc/NetworkManager/system-connections/Wired connection 1.nmconnection
  /etc/X11/xorg.conf.d/00-keyboard.conf
  /etc/adjtime
  /etc/audisp/
  /etc/audit/plugins.d/
  /etc/audit/rules.d/
  /etc/ca-certificates/extracted/ca-bundle.trust.crt
  /etc/ca-certificates/extracted/cadir/
  /etc/ca-certificates/extracted/edk2-cacerts.bin
  /etc/ca-certificates/extracted/email-ca-bundle.pem
  /etc/ca-certificates/extracted/java-cacerts.jks
  /etc/ca-certificates/extracted/objsign-ca-bundle.pem
  /etc/ca-certificates/extracted/tls-ca-bundle.pem
  /etc/colord/
  /etc/cups/subscriptions.conf.O
  /etc/dconf/db/ibus
  /etc/dconf/db/local
  /etc/default/keyboard
  /etc/default/locale
  /etc/fonts/conf.d/10-hinting-slight.conf
  /etc/fonts/conf.d/10-scale-bitmap-fonts.conf
  /etc/fonts/conf.d/10-yes-antialias.conf
  /etc/fonts/conf.d/11-lcdfilter-default.conf
  /etc/fonts/conf.d/20-unhint-small-dejavu-lgc-sans-mono.conf
  /etc/fonts/conf.d/20-unhint-small-dejavu-lgc-sans.conf
  /etc/fonts/conf.d/20-unhint-small-dejavu-lgc-serif.conf
  /etc/fonts/conf.d/20-unhint-small-dejavu-sans-mono.conf
  /etc/fonts/conf.d/20-unhint-small-dejavu-sans.conf
  /etc/fonts/conf.d/20-unhint-small-dejavu-serif.conf
  /etc/fonts/conf.d/20-unhint-small-vera.conf
  /etc/fonts/conf.d/30-metric-aliases.conf
  /etc/fonts/conf.d/40-nonlatin.conf
  /etc/fonts/conf.d/45-generic.conf
  /etc/fonts/conf.d/45-latin.conf
  /etc/fonts/conf.d/46-noto-sans.conf
  /etc/fonts/conf.d/46-noto-serif.conf
  /etc/fonts/conf.d/48-spacing.conf
  /etc/fonts/conf.d/49-sansserif.conf
  /etc/fonts/conf.d/50-user.conf
  /etc/fonts/conf.d/51-local.conf
  /etc/fonts/conf.d/57-dejavu-sans-mono.conf
  /etc/fonts/conf.d/57-dejavu-sans.conf
  /etc/fonts/conf.d/57-dejavu-serif.conf
  /etc/fonts/conf.d/58-dejavu-lgc-sans-mono.conf
  /etc/fonts/conf.d/58-dejavu-lgc-sans.conf
  /etc/fonts/conf.d/58-dejavu-lgc-serif.conf
  /etc/fonts/conf.d/60-generic.conf
  /etc/fonts/conf.d/60-latin.conf
  /etc/fonts/conf.d/65-fonts-persian.conf
  /etc/fonts/conf.d/65-nonlatin.conf
  /etc/fonts/conf.d/66-noto-sans.conf
  /etc/fonts/conf.d/66-noto-serif.conf
  /etc/fonts/conf.d/69-unifont.conf
  /etc/fonts/conf.d/69-urw-bookman.conf
  /etc/fonts/conf.d/69-urw-c059.conf
  /etc/fonts/conf.d/69-urw-d050000l.conf
  /etc/fonts/conf.d/69-urw-fallback-backwards.conf
  /etc/fonts/conf.d/69-urw-fallback-generics.conf
  /etc/fonts/conf.d/69-urw-fallback-specifics.conf
  /etc/fonts/conf.d/69-urw-gothic.conf
  /etc/fonts/conf.d/69-urw-nimbus-mono-ps.conf
  /etc/fonts/conf.d/69-urw-nimbus-roman.conf
  /etc/fonts/conf.d/69-urw-nimbus-sans.conf
  /etc/fonts/conf.d/69-urw-p052.conf
  /etc/fonts/conf.d/69-urw-standard-symbols-ps.conf
  /etc/fonts/conf.d/69-urw-z003.conf
  /etc/fonts/conf.d/80-delicious.conf
  /etc/fonts/conf.d/90-synthetic.conf
  /etc/gdm/custom.conf.pacnew
  /etc/gnome-remote-desktop/
  /etc/group-
  /etc/gshadow-
  /etc/hosts.pacnew
  /etc/locale.conf
  /etc/locale.gen.pacnew
  /etc/localtime
  /etc/machine-id
  /etc/makepkg.conf.d/fortran.conf.pacnew
  /etc/mhwd-x86_64.conf
  /etc/mkinitcpio.conf.pacnew
  /etc/modprobe.d/mhwd-gpu.conf
  /etc/modules-load.d/mhwd-gpu.conf
  /etc/openswap.conf.pacnew
  /etc/openvpn/
  /etc/os-release
  /etc/pacman.conf.pacnew
  /etc/pacman.d/gnupg/
  /etc/pacman.d/mirrorlist
  /etc/pacreport.conf
  /etc/pam.d/polkit-1
  /etc/passwd-
  /etc/passwd.pacnew
  /etc/plymouth/plymouthd.confe
  /etc/printcap
  /etc/shadow-
  /etc/shells.pacnew
  /etc/ssh/ssh_host_ecdsa_key
  /etc/ssh/ssh_host_ecdsa_key.pub
  /etc/ssh/ssh_host_ed25519_key
  /etc/ssh/ssh_host_ed25519_key.pub
  /etc/ssh/ssh_host_rsa_key
  /etc/ssh/ssh_host_rsa_key.pub
  /etc/subgid-
  /etc/subuid-
  /etc/sudoers.d/10-installer
  /etc/systemd/system/bluetooth.target.wants/
  /etc/systemd/system/dbus-org.bluez.service
  /etc/systemd/system/dbus-org.freedesktop.ModemManager1.service
  /etc/systemd/system/dbus-org.freedesktop.nm-dispatcher.service
  /etc/systemd/system/dbus-org.freedesktop.timesync1.service
  /etc/systemd/system/default.target
  /etc/systemd/system/display-manager.service
  /etc/systemd/system/getty.target.wants/
  /etc/systemd/system/multi-user.target.wants/
  /etc/systemd/system/network-online.target.wants/
  /etc/systemd/system/printer.target.wants/
  /etc/systemd/system/sockets.target.wants/
  /etc/systemd/system/sysinit.target.wants/
  /etc/systemd/system/timers.target.wants/
  /etc/systemd/user/graphical-session-pre.target.wants/
  /etc/systemd/user/pipewire-session-manager.service
  /etc/systemd/user/pipewire.service.wants/
  /etc/systemd/user/sockets.target.wants/
  /etc/timezone
  /etc/userdb/
  /etc/vconsole.conf
  /etc/xdg/menus/applications-merged/com.blackmagicdesign.resolve.menu
  /etc/xml/catalog
  /opt/resolve/
  /rootfs-pkgs.txt
  /usr/lib/gconv/gconv-modules.cache
  /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders.cache
  /usr/lib/gio/modules/giomodule.cache
  /usr/lib/graphviz/config8
  /usr/lib/gtk-2.0/2.10.0/immodules.cache
  /usr/lib/gtk-3.0/3.0.0/immodules.cache
  /usr/lib/lib/
  /usr/lib/libDaVinciPanelAPI.so
  /usr/lib/libFairlightPanelAPI.so
  /usr/lib/libcurl-compat.so.4
  /usr/lib/locale/locale-archive
  /usr/lib/udev/hwdb.bin
  /usr/lib/udev/rules.d/75-davincikb.rules
  /usr/lib/udev/rules.d/75-davincipanel.rules
  /usr/lib/udev/rules.d/75-sdx.rules
  /usr/lib32/gconv/gconv-modules.cache
  /usr/lib32/gdk-pixbuf-2.0/2.10.0/loaders.cache
  /usr/lib32/gtk-2.0/2.10.0/immodules.cache
  /usr/lib32/libcurl-compat.so.4
  /usr/share/applications/com.blackmagicdesign.rawplayer.desktop
  /usr/share/applications/com.blackmagicdesign.rawspeedtest.desktop
  /usr/share/applications/com.blackmagicdesign.resolve-CaptureLogs.desktop
  /usr/share/applications/com.blackmagicdesign.resolve-DaVinciRemoteMonitoring.desktop
  /usr/share/applications/com.blackmagicdesign.resolve-Installer.desktop
  /usr/share/applications/com.blackmagicdesign.resolve-Panels.desktop
  /usr/share/applications/com.blackmagicdesign.resolve.desktop
  /usr/share/applications/defaults.list
  /usr/share/desktop-directories/com.blackmagicdesign.resolve.directory
  /usr/share/glib-2.0/schemas/gschemas.compiled
  /usr/share/icons/Adwaita/icon-theme.cache
  /usr/share/icons/AdwaitaLegacy/icon-theme.cache
  /usr/share/icons/HighContrast/icon-theme.cache
  /usr/share/icons/Papirus-Dark-Maia/icon-theme.cache
  /usr/share/icons/Papirus-Dark/icon-theme.cache
  /usr/share/icons/Papirus-Light-Maia/icon-theme.cache
  /usr/share/icons/Papirus-Light/icon-theme.cache
  /usr/share/icons/Papirus-Maia/icon-theme.cache
  /usr/share/icons/Papirus/icon-theme.cache
  /usr/share/icons/breeze-dark/icon-theme.cache
  /usr/share/icons/breeze/icon-theme.cache
  /usr/share/icons/hicolor/256x256/apps/blackmagicraw-player.png
  /usr/share/icons/hicolor/256x256/apps/blackmagicraw-speedtest.png
  /usr/share/icons/hicolor/256x256/mimetypes/application-x-braw-clip.png
  /usr/share/icons/hicolor/256x256/mimetypes/application-x-braw-sidecar.png
  /usr/share/icons/hicolor/256x256/mimetypes/gnome-mime-application-x-braw-clip.png
  /usr/share/icons/hicolor/256x256/mimetypes/gnome-mime-application-x-braw-sidecar.png
  /usr/share/icons/hicolor/48x48/apps/blackmagicraw-player.png
  /usr/share/icons/hicolor/48x48/apps/blackmagicraw-speedtest.png
  /usr/share/icons/hicolor/48x48/mimetypes/application-x-braw-clip.png
  /usr/share/icons/hicolor/48x48/mimetypes/application-x-braw-sidecar.png
  /usr/share/icons/hicolor/48x48/mimetypes/gnome-mime-application-x-braw-clip.png
  /usr/share/icons/hicolor/48x48/mimetypes/gnome-mime-application-x-braw-sidecar.png
  /usr/share/icons/hicolor/64x64/apps/DaVinci-Resolve.png
  /usr/share/icons/hicolor/64x64/apps/DaVinci-ResolveDbKey.png
  /usr/share/icons/hicolor/64x64/apps/DaVinci-ResolveProj.png
  /usr/share/icons/hicolor/64x64/mimetypes/application-x-resolvebin.png
  /usr/share/icons/hicolor/64x64/mimetypes/application-x-resolvedbkey.png
  /usr/share/icons/hicolor/64x64/mimetypes/application-x-resolveproj.png
  /usr/share/icons/hicolor/64x64/mimetypes/application-x-resolvetemplatebundle.png
  /usr/share/icons/hicolor/64x64/mimetypes/application-x-resolvetimeline.png
  /usr/share/icons/hicolor/64x64/mimetypes/gnome-mime-application-x-resolvebin.png
  /usr/share/icons/hicolor/64x64/mimetypes/gnome-mime-application-x-resolvedbkey.png
  /usr/share/icons/hicolor/64x64/mimetypes/gnome-mime-application-x-resolveproj.png
  /usr/share/icons/hicolor/64x64/mimetypes/gnome-mime-application-x-resolvetemplatebundle.png
  /usr/share/icons/hicolor/64x64/mimetypes/gnome-mime-application-x-resolvetimeline.png
  /usr/share/icons/hicolor/icon-theme.cache
  /usr/share/info/dir
  /usr/share/perl5/vendor_perl/XML/SAX/ParserDetails.ini
  /var/.updated
  /var/BlackmagicDesign/
  /var/db/sudo/lectured/1000
/var/lib/boltd/
  /var/lib/colord/
  /var/lib/flatpak/
  /var/lib/fprint/
  /var/lib/fwupd/
  /var/lib/gdm/.cache/
  /var/lib/gdm/.config/
  /var/lib/gdm/.local/
  /var/lib/gdm/.migrated-dyn-users
  /var/lib/gdm/Desktop/
  /var/lib/gdm/Documents/
  /var/lib/gdm/Downloads/
  /var/lib/gdm/Music/
  /var/lib/gdm/Pictures/
  /var/lib/gdm/Public/
  /var/lib/gdm/Templates/
  /var/lib/gdm/Videos/
  /var/lib/gdm/seat0/
  /var/lib/geoclue/
  /var/lib/gnome-remote-desktop/
  /var/lib/lastlog/
  /var/lib/libuuid/
  /var/lib/logrotate.status
  /var/lib/machines/
  /var/lib/mhwd/db/2020-12-30-update
  /var/lib/mhwd/local/pci/video-linux/
  /var/lib/openvpn/
  /var/lib/os-prober/labels
  /var/lib/pacman-mirrors/status.json
  /var/lib/pacman/sync/
  /var/lib/plymouth/boot-duration
  /var/lib/polkit-1/
  /var/lib/portables/
  /var/lib/power-profiles-daemon/
  /var/lib/private/
  /var/lib/rpcbind/
  /var/lib/systemd/catalog/
  /var/lib/systemd/coredump/
  /var/lib/systemd/ephemeral-trees/
  /var/lib/systemd/linger/
  /var/lib/systemd/network/
  /var/lib/systemd/pstore/
  /var/lib/systemd/random-seed
  /var/lib/systemd/rfkill/
  /var/lib/systemd/timers/
  /var/lib/systemd/timesync/
  /var/lib/tpm2-tss/
  /var/lib/transmission/
Unneeded Packages Installed Explicitly:
  acpi                                            	 23.95 K - Client for battery, power, and thermal readings
  acpid                                           	136.50 K - A daemon for delivering ACPI power management events with netlink support
  amd-ucode                                       	602.97 K - Microcode update image for AMD CPUs
  android-tools                                   	  6.38 M - Android platform tools
 *apparmor                                        	  4.99 M - Mandatory Access Control (MAC) using Linux Security Module (LSM)
  ardour                                          	105.53 M - Professional-grade digital audio workstation (pro-audio)
  audacity                                        	 41.77 M - A program that lets you manipulate digital audio waveforms (pro-audio)
  b43-fwcutter                                    	 44.75 K - firmware extractor for the b43 kernel module
  baobab                                          	  1.62 M - A graphical directory tree analyzer (gnome)
  btrfsmaintenance                                	 40.06 K - Scripts for btrfs maintenance tasks
  chromium                                        	396.86 M - A web browser built for speed, simplicity, and security
  clonezilla                                      	 15.75 M - ncurses partition and disk imaging/cloning program
  collision                                       	  2.18 M - GUI tool to generate, compare and verify MD5, SHA-1, SHA-256, SHA-512, Blake3, CRC32 and Adler32 hashes (gnome-circle)
  cpupower                                        	626.36 K - Linux kernel tool to examine and tune power saving related features of your processor (linux-tools)
 *cuda                                            	  4.66 G - NVIDIA's GPU programming toolkit
  darktable                                       	178.73 M - Utility to organize and develop raw images
  decklink                                        	330.86 M - Drivers for Blackmagic Design DeckLink, Intensity or Multibridge video editing cards
  deja-dup                                        	 51.54 M - Easy to use backup tool based on Restic (gnome-circle)
 *dmidecode                                       	208.19 K - Desktop Management Interface table related utilities
  dmraid                                          	314.03 K - Device mapper RAID interface
 *dnsmasq                                         	  2.20 M - Lightweight, easy to configure DNS forwarder and DHCP server
  element-desktop                                 	529.00 M - Glossy Matrix collaboration client — desktop version.
  endeavour                                       	  2.00 M - Personal task manager (Formerly GNOME Todo) (gnome-extra)
  ex-vi-compat                                    	 43.36 M - The ex and vi commands based on vim's compatibility modes
  exfat-utils                                     	234.52 K - Utilities for exFAT file system
 *f2fs-tools                                      	582.95 K - Tools for Flash-Friendly File System (F2FS)
  fdupes                                          	 97.30 K - a program for identifying or deleting duplicate files residing within specified directories
  ffmpeg-audio-thumbnailer                        	176.00 B - Minimal thumbnailer for audio files using ffmpeg that can be used by file managers to create thumbnails for audio files
  ffmpegthumbnailer                               	280.73 K - Lightweight video thumbnailer that can be used by file managers
  file-roller                                     	  4.15 M - Create and modify archives (gnome-extra)
  firefox                                         	281.76 M - Fast, Private & Safe Web Browser
 *fprintd                                         	  2.58 M - D-Bus service to access fingerprint readers (fprint)
  fragments                                       	 20.63 M - BitTorrent client for GNOME (gnome-circle)
  gimp                                            	186.20 M - GNU Image Manipulation Program
  glibc-locales                                   	221.92 M - Pregenerated locales for GNU C Library
  gnome-backgrounds                               	 23.71 M - Background images and data for GNOME (gnome)
  gnome-boxes                                     	213.48 M - Simple GNOME application to access virtual systems (gnome-extra)
 *gnome-browser-connector                         	125.96 K - Native browser connector for integration with extensions.gnome.org
  gnome-calculator                                	 10.28 M - GNOME Scientific calculator (gnome)
  gnome-calendar                                  	  2.89 M - Simple and beautiful calendar application designed to perfectly fit the GNOME desktop (gnome)
  gnome-characters                                	  2.74 M - A character map application (gnome)
  gnome-chess                                     	  2.77 M - Play the classic two-player boardgame of chess (gnome-extra)
  gnome-clocks                                    	  1.66 M - Clocks applications for GNOME (gnome)
  gnome-connections                               	  2.04 M - Remote desktop client for the GNOME desktop environment (gnome)
  gnome-contacts                                  	 10.30 M - Contacts Manager for GNOME (gnome)
 *gnome-control-center                            	 28.74 M - GNOME's main interface to configure various aspects of the desktop (gnome)
 *gnome-disk-utility                              	  6.55 M - Disk Management Utility for GNOME (gnome)
  gnome-firmware                                  	 27.39 M - Manage firmware on devices supported by fwupd
  gnome-font-viewer                               	  1.15 M - A font viewer utility for GNOME (gnome)
 *gnome-layout-switcher                           	  7.07 M - A simple GUI for choosing GNOME desktop layout
  gnome-logs                                      	  1.39 M - A log viewer for the systemd journal (gnome)
  gnome-maps                                      	  6.91 M - Find places around the world (gnome)
  gnome-mines                                     	  1.39 M - Clear hidden mines from a minefield (gnome-extra)
 *gnome-remote-desktop                            	  2.53 M - GNOME Remote Desktop server (gnome)
  gnome-shell-extension-gsconnect                 	  1.43 M - KDE Connect implementation with GNOME Shell integration
  gnome-shell-extension-legacy-theme-auto-switcher	  2.57 K - Change the GTK3 theme to light/dark variant based on the system color scheme on GNOME 42
  gnome-shell-extension-x11gestures               	 38.01 K - Enable GNOME Shell multi-touch gestures on X11
  gnome-system-monitor                            	  4.97 M - View current processes and monitor system state (gnome)
  gnome-terminal                                  	  8.32 M - The GNOME Terminal Emulator
  gnome-text-editor                               	  2.81 M - A simple text editor for the GNOME desktop (gnome)
  gnome-themes-extra                              	  4.23 M - Extra GNOME themes (legacy HighContrast icon theme and index files for Adwaita)
  gnome-tour                                      	  2.19 M - Guided tour and greeter for GNOME (gnome)
  gnome-user-docs                                 	 61.09 M - User documentation for GNOME (gnome)
 *gnome-user-share                                	  8.92 M - Easy to use user-level file sharing for GNOME (gnome)
  gnome-weather                                   	767.89 K - Access current weather conditions and forecasts (gnome)
 *gnuchess                                        	624.41 K - Play chess against the computer on a terminal and an engine for graphical chess frontends
  gparted                                         	 17.35 M - A Partition Magic clone, frontend to GNU Parted
 *grilo-plugins                                   	  3.42 M - A collection of plugins for the Grilo framework (gnome)
 *grub-btrfs                                      	105.85 K - Include btrfs snapshots in GRUB boot options
  grub-theme-manjaro                              	  2.48 M - Manjaro Linux grub theme
  gthumb                                          	 14.46 M - Image browser and viewer for the GNOME Desktop
  gtksourceview-pkgbuild                          	 38.67 K - PKGBUILD syntax highlight support in GtkSourceView
  gufw                                            	  3.77 M - Uncomplicated way to manage your Linux firewall
 *gvfs-afc                                        	221.70 K - Virtual filesystem implementation for GIO - AFC backend (Apple mobile devices) (gnome)
 *gvfs-dnssd                                      	137.55 K - Virtual filesystem implementation for GIO - DNS-SD and WebDAV backend (macOS file sharing) (gnome)
 *gvfs-google                                     	  9.86 M - Virtual filesystem implementation for GIO - Google Drive backend (gnome)
 *gvfs-gphoto2                                    	152.75 K - Virtual filesystem implementation for GIO - gphoto2 backend (PTP camera, MTP media player) (gnome)
 *gvfs-mtp                                        	152.80 K - Virtual filesystem implementation for GIO - MTP backend (Android, media player) (gnome)
 *gvfs-nfs                                        	 50.31 K - Virtual filesystem implementation for GIO - NFS backend (gnome)
 *gvfs-onedrive                                   	411.66 K - Virtual filesystem implementation for GIO - Microsoft OneDrive backend (gnome)
 *gvfs-smb                                        	 85.31 K - Virtual filesystem implementation for GIO - SMB/CIFS backend (Windows file sharing) (gnome)
 *gvfs-wsdd                                       	658.21 K - Virtual filesystem implementation for GIO - Web Services Dynamic Discovery backend (Windows discovery) (gnome)
  handbrake                                       	 57.06 M - Multithreaded video transcoder
 *harvid                                          	158.97 K - HTTP Ardour Video Daemon
  htop                                            	386.54 K - Interactive process viewer
  iagno                                           	 12.45 M - Dominate the board in a classic version of Reversi
  inetutils                                       	  1.09 M - A collection of common network programs
 *install-grub                                    	  7.44 K - GNU Grub (2) Install Script on Updates
  intel-ucode                                     	 30.24 M - Microcode update files for Intel CPUs
  inxi                                            	  1.36 M - Full featured CLI system information tool
 *jdk-openjdk                                     	548.15 M - OpenJDK Java 25 development kit
 *jfsutils                                        	952.65 K - JFS filesystem utilities
  jnettop                                         	 78.10 K - A top-like console network traffic visualizer
 *kvantum-manjaro                                 	 12.44 M - Maia and Breath themes for Kvantum
  lib32-opencl-nvidia                             	 17.58 M - OpenCL implemention for NVIDIA (32-bit)
  libc++                                          	 16.29 M - LLVM C++ standard library
 *libdvdcss                                       	 54.74 K - Portable abstraction library for DVD decryption
 *libpamac-flatpak-plugin                         	 73.95 K - Flatpak plugin for Pamac
 *libreoffice-still                               	528.58 M - LibreOffice maintenance branch
 *linux612                                        	145.25 M - The Linux 6.12 kernel and modules
 *linux66                                         	135.01 M - The Linux66 kernel and modules
 *logrotate                                       	100.65 K - Rotates system logs automatically
  lollypop                                        	  7.12 M - Music player for GNOME
 *lvm2                                            	  8.96 M - Logical Volume Manager 2 utilities
 *malcontent                                      	763.98 K - Parental control support for applications (gnome)
 *man-db                                          	  2.50 M - A utility for reading man pages
  man-pages                                       	  5.63 M - Linux man pages
  manjaro-alsa                                    	 16.65 M - Manjaro meta package for complete ALSA support
 *manjaro-application-utility                     	299.12 K - A simple application utility for Manjaro Linux
  manjaro-browser-settings                        	 86.66 K - Manjaro Linux settings browser defaults
  manjaro-gnome-extension-settings                	  1.00 K - Manjaro Linux GNOME extensions settings
  manjaro-gstreamer                               	805.92 K - Manjaro meta package for complete Gstreamer support
  manjaro-hello                                   	374.20 K - A tool providing access to documentation and support for new Manjaro users.
  manjaro-input                                   	351.37 K - Manjaro meta package for complete input support
  manjaro-modem                                   	252.89 K - Manjaro meta package for complete modem support
  manjaro-pipewire                                	  2.71 K - Manjaro meta package for complete PipeWire support.
  manjaro-printer                                 	260.69 M - Manjaro meta package for complete printing support
  manjaro-release                                 	115.00 B - Manjaro's release definition
 *manjaro-settings-manager-notifier               	583.05 K - Manjaro Linux System Settings Tool (Notifier)
  manjaro-settings-samba                          	 62.23 M - Adds an smb.conf file for Manjaro and enables samba
  manjaro-system                                  	386.00 B - Manjaro Linux System - Update script
  manjaro-zsh-config                              	 12.07 M - Zsh configuration for manjaro
  memtest86+                                      	153.53 K - Advanced memory diagnostic tool legacy BIOS version
  memtest86+-efi                                  	154.86 K - Advanced memory diagnostic tool EFI version
 *mesa-utils                                      	781.30 K - Essential Mesa utilities
  mkinitcpio-openswap                             	  7.70 K - Mkinitcpio openswap hook
  nano-syntax-highlighting                        	203.64 K - Nano editor syntax highlighting enhancements
  nautilus-admin                                  	233.74 K - Extension for Nautilus to do administrative operations
  nautilus-empty-file                             	802.00 B - Provides context menu 'New Document' functionality for Nautilus
  ncurses5-compat-libs                            	  1.16 M - System V Release 4.0 curses emulation library, ABI 5
  network-manager-sstp                            	908.80 K - NetworkManager VPN plugin for SSTP (with GUI)
 *networkmanager                                  	 15.97 M - Network connection manager and user applications
  networkmanager-openconnect                      	  8.19 M - NetworkManager VPN plugin for OpenConnect (with GUI)
  networkmanager-openvpn                          	  1.64 M - NetworkManager VPN plugin for OpenVPN (with GUI)
  networkmanager-pptp                             	707.14 K - NetworkManager VPN plugin for PPTP (with GUI)
  networkmanager-strongswan                       	  4.15 M - Strongswan NetworkManager plugin
  networkmanager-vpnc                             	618.52 K - NetworkManager VPN plugin for VPNC (with GUI)
 *new-session-manager                             	397.82 K - Audio session manager
  nfs-utils                                       	  2.40 M - Support programs for Network File Systems
 *noto-fonts-cjk                                  	298.79 M - Google Noto CJK fonts
 *noto-fonts-extra                                	331.28 M - Google Noto TTF fonts - additional variants
 *nss-mdns                                        	107.70 K - glibc plugin providing host name resolution via mDNS
  obs-studio                                      	 42.58 M - Free, open source software for live streaming and recording
 *opencl-mesa                                     	106.53 M - Open-source OpenCL drivers
 *os-prober                                       	 77.49 K - Utility to detect other OSes on a set of drives
  pacutils                                        	453.47 K - Helper tools for libalpm
 *pamac-gnome-integration                         	 14.31 K - Pamac GNOME integration
  papirus-maia-icon-theme                         	  9.56 M - Manjaro variation of Papirus icon theme
  patchelf                                        	261.94 K - Small utility to modify the dynamic linker and RPATH of ELF executables
  plasmatube                                      	412.02 M - Kirigami YouTube video player based on QtMultimedia and youtube-dl (kde-applications kde-multimedia)
  plymouth-theme-manjaro                          	  2.25 M - Plymouth theme for Manjaro
 *power-profiles-daemon                           	141.95 K - Makes power profiles handling available over D-Bus
  python-numpy                                    	 47.61 M - Scientific tools for Python
  qt5-multimedia                                  	  3.40 M - Classes for audio, video, radio and camera functionality (qt5)
  qt5-websockets                                  	291.04 K - Provides WebSocket communication compliant with RFC 6455 (qt5)
 *qt5ct                                           	895.92 K - Qt5 Configuration Utility
 *qt6ct                                           	686.23 K - Qt 6 Configuration Utility
  quadrapassel                                    	  1.00 M - Fit falling blocks together (Tetris-like game for GNOME) (gnome-extra)
  reiserfsprogs                                   	600.48 K - Reiserfs utilities
 *rygel                                           	  9.52 M - UPnP AV MediaServer and MediaRenderer (gnome)
  s-nail                                          	  1.01 M - Environment for sending and receiving mail
 *seahorse                                        	  7.10 M - GNOME application for managing PGP keys
  signal-desktop                                  	390.99 M - Signal Private Messenger for Linux
 *simple-scan                                     	 33.00 M - Simple scanning utility (gnome)
  snapshot                                        	  5.45 M - Take pictures and videos (gnome)
  sof-firmware                                    	 42.80 M - Sound Open Firmware
 *squashfs-tools                                  	939.28 K - Tools for squashfs, a highly compressed read-only filesystem for Linux
  stremio                                         	 89.00 M - A one-stop hub for video content aggregation (Movies, TV shows, series, live television or web channels)
  sushi                                           	  7.75 M - A quick previewer for Nautilus (gnome)
  sysfsutils                                      	 88.82 K - System Utilities Based on Sysfs
 *system-config-printer                           	  8.37 M - A CUPS printer configuration tool and status applet
  timeshift-autosnap-manjaro                      	  6.63 K - Timeshift auto-snapshot script which runs before package upgrade using Pacman hook.
 *tk                                              	 12.27 M - A windowing toolkit for use with tcl
  totem                                           	  6.51 M - Movie player for the GNOME desktop based on GStreamer
 *touche                                          	551.69 K - The desktop application to configure Touchégg
  transmission-gtk                                	  4.43 M - Fast, easy, and free BitTorrent client (GTK+ GUI)
  ttf-hack                                        	  1.21 M - A hand groomed and optically balanced typeface based on Bitstream Vera Mono.
  ttf-indic-otf                                   	  2.56 M - Indic Opentype Fonts collection
 *unace                                           	143.13 K - An extraction tool for the proprietary ace archive format
 *unrar                                           	409.15 K - The RAR uncompression program
 *update-grub                                     	561.00 B - GNU Grub (2) Update Menu Script
  vlc                                             	 49.26 M - Free and open source cross-platform multimedia player and framework
  webapp-manager                                  	  6.08 M - Run websites as if they were apps
 *wget                                            	  5.69 M - Network utility to retrieve files from the web
  whois                                           	244.74 K - Intelligent WHOIS client
 *wireless-regdb                                  	305.81 K - Central Regulatory Domain Database
  xf86-video-amdgpu                               	166.17 K - X.org amdgpu video driver (xorg-drivers)
  xf86-video-ati                                  	476.67 K - X.org ati video driver (xorg-drivers)
  xf86-video-intel                                	  2.26 M - X.org Intel i810/i830/i915/945G/G965+ video drivers (xorg-drivers)
  xf86-video-nouveau                              	210.90 K - Open Source 3D acceleration driver for nVidia cards (xorg-drivers)
 *xfsprogs                                        	  4.40 M - XFS filesystem utilities
 *xjadeo                                          	445.49 K - A simple video player that is synchronized to jack transport
 *xorg-server                                     	  3.72 M - Xorg X server (xorg)
  yay                                             	  9.42 M - Yet another yogurt. Pacman wrapper and AUR helper written in go.
Unneeded Packages Installed As Dependencies:
 *7zip                       	  6.25 M - File archiver for extremely high compression
  adobe-source-code-pro-fonts	  1.86 M - Monospaced font family for user interface and coding environments
 *android-udev               	 38.44 K - Udev rules to connect Android devices to your linux box
  appstream-glib             	  3.67 M - Objects and methods for reading and writing AppStream metadata
 *audacity-docs              	 33.68 M - A program that lets you manipulate digital audio waveforms - documentation
 *avisynthplus               	  5.70 M - An improved version of the AviSynth frameserver
 *base-devel                 	  5.34 M - Basic tools to build Manjaro Linux packages
  boost                      	186.28 M - Free peer-reviewed portable C++ source libraries (development headers)
  botan2                     	 21.88 M - Crypto library written in C++ (legacy version)
  breezy                     	 70.42 M - A decentralized revision control system with support for Bazaar and Git file formats
  cantarell-fonts            	193.33 K - Humanist sans serif font
  clutter-gtk                	 22.03 M - Clutter integration with GTK+
  cmake                      	 95.56 M - A cross-platform open-source make system
 *dcraw                      	542.88 K - Decodes any raw image from any digital camera
  dejagnu                    	  1.00 M - Framework for testing other programs
  doxygen                    	 21.43 M - Documentation system for C++, C, Java, IDL and PHP
  dynamic-wallpaper          	 97.80 K - Dynamic wallpaper creator for GNOME 42 and beyond
  electron34                 	258.38 M - Build cross platform desktop apps with web technologies
  electron35                 	270.56 M - Build cross platform desktop apps with web technologies
  electron36                 	271.74 M - Build cross platform desktop apps with web technologies
  electron37                 	282.62 M - Build cross platform desktop apps with web technologies
  electron38                 	278.25 M - Build cross platform desktop apps with web technologies
 *game-devices-udev          	 22.07 K - Udev rules for controllers
  gcc-ada                    	161.08 M - Ada front-end for GCC (GNAT)
  gcc-d                      	136.79 M - D frontend for GCC
  gcc13                      	156.24 M - The GNU Compiler Collection - C and C++ frontends (13.x.x)
  gcc14                      	173.67 M - The GNU Compiler Collection - C and C++ frontends (14.x.x)
 *gdb                        	 35.36 M - The GNU Debugger
  gnome-common               	  3.32 M - Common development macros for GNOME
 *gnuplot                    	  3.80 M - Plotting package which outputs to X11, PostScript, PNG, GIF, and others
  go                         	215.42 M - Core compiler tools for the Go programming language
  gobject-introspection      	 14.88 M - Introspection system for GObject-based libraries
 *gpart                      	 58.66 K - Partition table rescue/guessing tool
  gperf                      	237.93 K - Perfect hash function generator
  gstreamer0.10-base         	 19.39 M - GStreamer Multimedia Framework Base plugin libraries
 *intel-media-sdk            	 68.74 M - Legacy API for hardware video acceleration on Intel GPUs (Broadwell to Rocket Lake)
 *jre8-openjdk               	 98.28 M - OpenJDK Java 8 full runtime environment
  js128                      	 76.22 M - JavaScript interpreter and libraries - Version 128
  kauth                      	770.92 K - Abstraction to system policy and authentication features (kf6)
  kwindowsystem5             	712.20 K - Access to the windowing system (kf5)
 *ladspa                     	196.94 K - Linux Audio Developer's Simple Plugin API (LADSPA)
  lib32-libcap               	  1.17 M - POSIX 1003.1e capabilities (32-bit)
  libayatana-indicator       	401.28 K - Ayatana Indicators shared library
  libgnome-games-support     	185.43 K - Code shared between GNOME games
  libgnome-games-support-2   	191.73 K - Code shared between GNOME games
  libinstpatch               	  1.12 M - Instrument file software library
 *liboggz                    	  2.11 M - A simple programming interface for reading and writing Ogg files and streams
  liboil                     	  1.47 M - Liboil is a library of simple functions that are optimized for various CPUs.
  libomxil-bellagio          	597.94 K - An opensource implementation of the OpenMAX Integration Layer API
  libtar                     	 83.67 K - C library for manipulating POSIX tar files
  libvisual                  	557.99 K - Abstraction library that comes between applications and audio visualisation plugins
 *linux-firmware-meta        	358.39 M - Firmware files for Linux - Default set (Meta Package)
 *lua-socket                 	  1.25 M - Networking support library for the Lua language
  meson                      	 17.12 M - High productivity build system
 *mtools                     	396.71 K - A collection of utilities to access MS-DOS disks
  nasm                       	  5.26 M - 80x86 assembler designed for portability and modularity
 *openbsd-netcat             	 47.40 K - TCP/IP swiss army knife. OpenBSD variant.
 *opencl-clhpp               	  5.30 M - OpenCL C++ header files
 *perl-image-exiftool        	 17.66 M - Read and write EXIF information
 *python-html5lib            	  1.88 M - A Python HTML parser/tokenizer based on the WHATWG HTML5 spec
 *python-pytest              	  4.97 M - Simple powerful testing with Python
  python-sphinx              	 66.77 M - Python documentation generator
 *python-wxpython            	 53.21 M - Cross-platform GUI toolkit
 *qt5-graphicaleffects       	538.51 K - Graphical effects for use with Qt Quick 2 (qt5)
  qt6-wayland                	  4.74 M - Provides APIs for Wayland (qt6)
  steam-native-runtime       	108.26 M - Native replacement for the Steam runtime using system libraries
 *udftools                   	390.01 K - Linux tools for UDF filesystems and DVD/CD-R(W) drives
 *v4l2loopback-dkms          	112.29 K - v4l2-loopback device – module sources
  vala                       	 32.82 M - Compiler for the GObject type system
  valgrind                   	 75.46 M - Tool to help find memory-management problems in programs
  vcdimager                  	804.51 K - A full-featured mastering suite for authoring disassembling and analyzing Video CD's and Super Video CD's
 *vlc-plugins-all            	 43.70 M - Free and open source cross-platform multimedia player and framework - all plugins
  vulkan-headers             	 36.73 M - Vulkan header files and API registry (vulkan-devel)
  webkit2gtk                 	127.87 M - Web content engine for GTK
 *wl-clipboard               	100.27 K - Command-line copy/paste utilities for Wayland
 *xclip                      	 30.67 K - Command line interface to the X11 clipboard
 *xorg-xhost                 	 23.79 K - Server access control program for X (xorg-apps xorg)
 *xorg-xrdb                  	 40.89 K - X server resource database utility (xorg-apps xorg)
 *xorg-xset                  	 40.07 K - User preference utility for X (xorg-apps xorg)
  yasm                       	  3.73 M - A rewrite of NASM to allow for multiple syntax supported (NASM, TASM, GAS, etc.)
Unneeded Packages In A Dependency Cycle:
  mhwd                   	204.35 K - Manjaro Linux Hardware Detection library and application
  mhwd-amdgpu            	  1.00 K - MHWD module-ids for amdgpu
  mhwd-ati               	  3.87 K - MHWD module-ids for ati 19.1.0
  mhwd-db                	  1.02 M - Manjaro Linux Hardware Detection Database
  mhwd-nvidia            	  1.11 K - MHWD module-ids for nvidia 590.48.01
  mhwd-nvidia-390xx      	  1.90 K - MHWD module-ids for nvidia 390.157
  mhwd-nvidia-470xx      	  1.79 K - MHWD module-ids for nvidia 470.256.02
  mhwd-nvidia-570xx      	  1.87 K - MHWD module-ids for nvidia 570.211.01
  mhwd-nvidia-575xx      	  1.86 K - MHWD module-ids for nvidia 575.64.05
  nvidia-driver-assistant	971.55 K - Detect and install the best NVIDIA driver packages for the system
Installed Packages Not In A Repository:
  clutter                          	 21.79 M - A toolkit for creating fast, portable, compelling dynamic UIs
  cogl                             	  4.57 M - An object oriented GL/GLES Abstraction/Utility Layer
  gcc13-libs                       	714.67 K - Runtime libraries shipped by GCC (13.x.x)
  gcc14-libs                       	896.67 K - Runtime libraries shipped by GCC (14.x.x)
  glew1.10                         	509.83 K - A cross-platform C/C++ extension loading library
  gstreamer0.10                    	 10.62 M - GStreamer Multimedia Framework
  gtk2                             	 36.47 M - GObject-based multi-platform GUI toolkit (legacy)
  lib32-glew1.10                   	497.15 K - A cross-platform C/C++ extension loading library
  lib32-gtk2                       	 10.02 M - GObject-based multi-platform GUI toolkit (legacy, 32-bit)
  lib32-libappindicator-gtk2       	 64.56 K - Allow applications to extend a menu via Ayatana indicators in Unity, KDE or Systray (GTK+ 2 library, 32-bit)
  lib32-libdbusmenu-gtk2           	198.42 K - Library for passing menus over DBus (GTK+ 2 library, 32-bit)
  lib32-libgcrypt15                	520.45 K - General purpose cryptographic library based on the code from GnuPG
  lib32-libidn11                   	201.39 K - Implementation of the Stringprep, Punycode and IDNA specifications
  lib32-libindicator-gtk2          	164.46 K - Set of symbols and convenience functions for Ayatana indicators (GTK+ 2 library, 32-bit)
  lib32-libjpeg6-turbo             	363.87 K - libjpeg derivative with accelerated baseline JPEG compression and decompression
  lib32-libpng12                   	347.04 K - A collection of routines used to create PNG format graphics files
  lib32-librtmp0                   	113.25 K - Toolkit for RTMP streams
  lib32-libtiff4                   	403.00 K - Library for manipulation of TIFF images
  lib32-libudev0-shim              	 13.28 K - libudev.so.0 compatibility library for systems with newer udev versions (32 bit)
  lib32-libvpx1.3                  	  1.73 M - VP8 and VP9 codec
  lib32-openssl-1.0                	  3.09 M - The Open Source toolkit for Secure Sockets Layer and Transport Layer Security
  lib32-openssl-1.1                	  2.90 M - The Open Source toolkit for Secure Sockets Layer and Transport Layer Security
  libdbusmenu-gtk2                 	132.87 K - Library for passing menus over DBus (GTK+ 2 library)
  libgcrypt15                      	531.70 K - General purpose cryptographic library based on the code from GnuPG
  libidn11                         	205.95 K - Implementation of the Stringprep, Punycode and IDNA specifications
  libindicator-gtk2                	 97.43 K - Set of symbols and convenience functions for Ayatana indicators (GTK+ 2 library)
  libjpeg6-turbo                   	336.48 K - libjpeg derivative with accelerated baseline JPEG compression and decompression
  libpng12                         	555.72 K - A collection of routines used to create PNG format graphics files
  librtmp0                         	105.95 K - Toolkit for RTMP streams
  libtiff4                         	437.34 K - Library for manipulation of TIFF images - Interface version (SONAME) 4
  libudev0-shim                    	 13.77 K - libudev.so.0 compatibility library for systems with newer udev versions
  libvpx1.3                        	  1.75 M - VP8 and VP9 codec
  openssl-1.0                      	  5.64 M - The Open Source toolkit for Secure Sockets Layer and Transport Layer Security
  openssl-1.1                      	  5.18 M - The Open Source toolkit for Secure Sockets Layer and Transport Layer Security
  qt5-webchannel                   	228.51 K - Provides access to QObject or QML objects from HTML clients for seamless integration of Qt applications with HTML/JavaScript clients (qt5)
  qt5-webengine                    	183.88 M - Provides support for web applications using the Chromium browser project (qt5)
Package Cache Size:
  /var/cache/pacman/pkg/ 25.84 G (19.32 G not installed)
:backhand_index_pointing_down: :wink:
man yay | less -p sudoloop
The packages are already built, so if you ran an update again, yay will find the package and install it. Or you can manually install the package from ~/.cache/yay/<package-name>/.
idk how i missed this :woman_facepalming:
thank you so much for pointing this out too! this is almost more important that the solution to prevent it from happening again.
yay --help | grep sudo
Stremio has a flatpak version. In cases like these it is way more recommended than building qt5-webengine from source.
I would try to clean the mess if i were you, it will bite you in the posterior soon enough again. At least clean the orphans.
I would recommend to combine
$ sudo pacman -Syu
$ yay -Sua
in the future and not to update while you are away. :wink:
flatpaks and snaps almost never seem to work smoothly for me in Manjaro. I always get flashbanged by them with light mode, and they often require a lot of work to be able to just drag and drop files in to them as attachments, the experience was so frustrating I found it less frustrating to build webengine than deal with flatpaks and their permissions and flashbangs.
I know this mess of packages needs to be cleaned. I was authoring a post for guidance on that, but I don’t even know where to begin - there’s what I want to do with the machine, the current configuration, and then what’s now broken on it, as well as how I expect the broken bits to behave. This was an installation that was done in great haste while I was in a panic throwing together a working environment at all costs, because RockyOS wouldn’t let me install modern applications I needed to run, but was the only way to get support from Blackmagic for the Resolve Studio software and Decklink hardware at the time.
im debating starting over, but really dislike having to re-customize all my settings and use massive amounts of bandwidth to re-sync a lot of git repos like LineageOS, AOSP, and the ones in my AUR list there, I don’t have the disk space to have more than a mirror backup right now.
I think I might start an libre office calc file and chart all my dependencies and actually needed software and then when I’m done start trouble shooting my broken graphics configuration, as I’m also unable to use my nvidia card for encoding right now, and some apps just stopped loading like Resolve Studio.
Just feels super overwhelming right now - :anxious_face_with_sweat:
