The following is the output that i got:
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.6-x86_64
root=UUID=0498ffbc-cac5-4b2b-b2c4-d57bf653036e rw quiet splash apparmor=1
security=apparmor resume=UUID=7f098986-059f-4696-86c0-46b403b3973e
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: HP product: 260-P020il v: N/A serial: Chassis:
type: 3 serial: N/A
I’m unable to post the full output here though.
There is no reason that you can’t. Use the </>
button instead of the quotes - this produces a scrollable preformatted text box. If you’re concerned about privacy, don’t be, as that command also filters out any personally identifiable information - that’s what --filter
and no-host
does.
Thanks for suggesting that.
the output is here:
udev.log_priority=3
Type: Desktop System: HP product: 260-P020il v: N/A serial: <filter> Chassis:
type: 3 serial: N/A
Mobo: HP model: 81B4 v: 00 serial: <filter> part-nu: W2T12AA#ACJ
uuid: ea351743-31b5-aa5f-34eb-938471d22146 UEFI-[Legacy]: AMI v: F.13
date: 08/02/2016
System RAM: total: 4 GiB available: 3.68 GiB used: 2.97 GiB (80.6%)
igpu: 64 MiB
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: ChannelA-DIMM0 type: no module installed
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 4 GiB
speed: 2133 MT/s volts: curr: 1.2 width (bits): data: 64 total: 64
manufacturer: SK Hynix part-no: HMA451U6AFR8N-TF serial: <filter>
Slot: 0 type: PCIe lanes: 16 status: in use info: J6B2 length: long
volts: 3.3 bus-ID: 00:01.0
Slot: 1 type: PCIe lanes: 1 status: in use info: J6B1 length: short
volts: 3.3 bus-ID: 00:1c.3
Info: model: Intel Core i3-6100T socket: U3E1 bits: 64 type: MT MCP
arch: Skylake-S gen: core 6 level: v3 note: check built: 2015
process: Intel 14nm family: 6 model-id: 0x5E (94) stepping: 3
microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/3200 base/boost: 3100/8300 scaling:
driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 25610
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: DP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.12 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-size: <missing: xdpyinfo>
Monitor-1: DP-1 model: HP 19ka serial: <filter> built: 2016 res: 1366x768
hz: 60 dpi: 85 gamma: 1.2 chroma: red: x: 0.635 y: 0.333 green: x: 0.329
y: 0.624 blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.329
size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9
modes: 1366x768, 1280x1024, 1280x800, 1280x720, 1024x768, 800x600,
640x480, 720x400
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:1912 memory: 3.6 GiB unified: yes
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
status: off 2: wireplumber status: active 3: pipewire-alsa type: plugin
vendor: Hewlett-Packard RTL8111/8168/8411 driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 01:00.0
IF: enp1s0 state: down mac: <filter>
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:b723
class-ID: 0280
Info: services: NetworkManager,wpa_supplicant
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 0bda:b008
Local Storage: total: 931.51 GiB used: 37.05 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA100
tech: HDD rpm: 7200 serial: <filter> fw-rev: A800 scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW DU8A6SH rev: DHS3
dev-links: cdrom
ID-1: / raw-size: 200 GiB size: 195.8 GiB (97.90%) used: 19.64 GiB (10.0%)
fs: ext4 block-size: 4096 B dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 0498ffbc-cac5-4b2b-b2c4-d57bf653036e
ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
used: 211.9 MiB (41.5%) fs: vfat block-size: 512 B dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: 70C0-0730
ID-3: /home raw-size: 260 GiB size: 254.86 GiB (98.02%)
used: 16.14 GiB (6.3%) fs: ext4 block-size: 4096 B dev: /dev/sda5
maj-min: 8:5 label: N/A uuid: f193157b-9b74-4058-8c3e-be4935b678ee
ID-1: swap-1 type: partition size: 8 GiB used: 1.07 GiB (13.4%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 7f098986-059f-4696-86c0-46b403b3973e
ID-1: /dev/sda2 maj-min: 8:2 size: 8 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/sda6 maj-min: 8:6 size: 300 GiB fs: ext4 label: N/A
uuid: b9c6e770-b479-4299-8a6d-a41fe471d0b1
Device-1: 1-7:2 info: Lite-On Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 04ca:004b class-ID: 0300
Device-2: 1-8:3 info: Chicony HP USB Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 04f2:0923 class-ID: 0301
Device-3: 1-9:4 info: Realtek 3-in-1 (SD/SDHC/SDXC) Card Reader
type: mass storage driver: ums-realtek interfaces: 1 rev: 2.0
chip-ID: 0bda:0153 class-ID: 0806 serial: <filter>
Device-4: 1-10:5 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:b008 class-ID: e001 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1300 pm: pacman pkgs: 1296 libs: 371 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 4
1: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
2: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
3: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
4: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
5: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
6: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
7: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
8: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 221
1: cpu: 100% command: ps pid: 28544 mem: 4.11 MiB (0.1%)
2: cpu: 10.1% command: firefox pid: 20504 mem: 417.3 MiB (11.0%)
3: cpu: 7.2% command: firefox pid: 1314 mem: 431.0 MiB (11.4%)
4: cpu: 5.0% command: firefox pid: 25412 mem: 293.4 MiB (7.7%)
5: cpu: 1.9% command: firefox pid: 2507 mem: 347.1 MiB (9.2%)
Memory top: 5 of 221
1: mem: 431.0 MiB (11.4%) command: firefox pid: 1314 cpu: 7.2%
2: mem: 417.3 MiB (11.0%) command: firefox pid: 20504 cpu: 10.1%
3: mem: 347.1 MiB (9.2%) command: firefox pid: 2507 cpu: 1.9%
4: mem: 293.4 MiB (7.7%) command: firefox pid: 25412 cpu: 5.0%
5: mem: 190.1 MiB (5.0%) command: firefox pid: 4930 cpu: 1.7%
Processes: 221 Power: uptime: 4h 37m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.46 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.34
Much better, thanks.
Now, I (and others) have already given information needed to install VirtualBox.
One important consideration (after seeing your system specs) is that you don’t have enough system RAM (only 4GB) to comfortably create much more than a virtual machine with extremely limited requirements (very early Windows versions, perhaps).
I don’t know what your intended use case is, however, my suggestion is to re-think this very carefully (and invest in more RAM).
With your system, you could either buy another 4GB identical to your existing Hynix module, for a total of 8GB of RAM; or buy a new 16GB kit (2x 8GB modules) or buy a new (and supported) 32GB kit (2x 16GB modules) and max-out to the full 32GB capability of your machine.
The more, the better, if you want to run VM’s well enough to actually use.
Cheers.
I have downloaded Oracle VM Virtual box in my desktop. and, when i'm starting it, I'm getting that error,
[manjaro ~]# virtualbox
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (6.6.26-1-MANJARO) or it failed to
load. Please recompile the kernel module and install it by
sudo /sbin/vboxconfig
You will not be able to start VMs until this problem is fixed.
it shows like this.
and, when I run the following command in my terminal,
It throws an error. and shows that,
sudo: /sbin/vboxconfig: command not found
I have also tried
pamac install linux510-virtualbox-host-modules
please help me, i’ve also rebooted many times after installation of virtual machine, still i’m getting this error. How can i solve it.
Please do not create duplicate topics. I’ve merged them both here.
I think we told you at least 3 different times what are you doing wrong [summary: you download something from somewhere, trying to run nonexisting commands for other distros] and how to fix it [just install 2 things from the package manager]. Did you read any of those answers at all? The next thing will be that someone remotely fixes it for you via teamviewer or similar, but such services are usually paid and generally not the point of the forum support of a free linux distro. And if you are so helpless you cannot even read a wiki page, linux is not for you. I think i will soon be out of this topic.
Sorry, I cannot contribute any further, and still keep my sanity.
Cheers.
For the sake of completion of the topic: the problem maybe have nothing to do with virtualbox. Search the forum for PGP signatures, there are many topics and even a tutorial.
system
Closed
6 May 2024 17:39
32
