Hi All,
I am no GURU, but after fighting with the dependencies for 2 weeks that couldn’t be satisfied no matter what answers I gave (Y/n, y/N, 1 or 2) or tried to remove/install after reading into all the problems and responses here with this latest update, I wanted to quit. Neither Konsole Terminal or Octopi could satisfy any updates.
I was running Manjaro 23.1 - Vulcan 23.1.4 - Gnome 45 and here’s what happened with sudo pacman -Syu
core 139.0 KiB 289 KiB/s 00:00 [------------------------------------] 100%
extra 8.3 MiB 811 KiB/s 00:11 [------------------------------------] 100%
community 29.0 B 345 B/s 00:00 [------------------------------------] 100%
multilib 146.3 KiB 754 KiB/s 00:00 [------------------------------------] 100%
:: Replace baloo5 with extra/baloo? [Y/n] Y
:: Replace breeze with extra/breeze5? [Y/n] Y
:: Replace ksysguard with extra/plasma-systemmonitor? [Y/n] Y
:: Replace kuserfeedback5 with extra/kuserfeedback? [Y/n] Y
:: Replace plasma-integration with extra/plasma5-integration? [Y/n] Y
:: Replace plasma5-themes-breath with extra/plasma6-themes-breath? [Y/n] Y
:: Replace plasma5-themes-breath-migration with extra/plasma6-themes-breath-migration? [Y/n] Y
resolving dependencies...
:: There are 2 providers available for qt6-multimedia-backend:
:: Repository extra
1) qt6-multimedia-ffmpeg 2) qt6-multimedia-gstreamer
Enter a number (default=1): 1
warning: removing 'jre11-openjdk-headless' from target list because it conflicts with 'jre11-openjdk'
:: jre11-openjdk and jre11-openjdk-headless are in conflict. Remove jre11-openjdk-headless? [y/N] N
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Or, changing answers and ended with this:
:: jre11-openjdk and jre11-openjdk-headless are in conflict. Remove jre11-openjdk-headless? [y/N] Y
:: installing clang (17.0.6-2) breaks dependency 'clang=16.0.6' required by shiboken2
What I wound up doing is going into the Application Launcher - System - Add/Remove Software - Update.
The Update wanted to remove some and add some to satisfy discrepancies. OK!
Boom Done! I’m now running Manjaro 24.0 - Wynsdey 24.0.1 - Gnome 46 (Kathmandu)
I now have a happy pacman. Because I refuse to go back to MS.
Sorry I can’t get this out of this block.
Thank you all for all your guidance on this amazing forum!
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
