I just upgraded the base-devel package in Manjaro. Now after rebooting it showed me error
Failed to start Authorization Manager.
I changed my grub configuration and login to my account using terminal.
But whenever I run the command to update or upgrade anything to fix it. It again throws an error.
e.g. pacman -Syu
pacman: /usr/lib/libc.so.6: version ‘GLIBC_2.33’ not found (required by pacman)
pacman: /usr/lib/libc.so.6: version ‘GLIBC_2.33’ not found (required by /usr/lib/libalpm.so.12)
As you can see in this case, neither sudo neither Pacman is working as both are dependent on this GLIBC_2.33. To fix or update this package I again need Pacman to work.
I am a fresh user of Manjaro. I don’t know exactly how to do this. Can you please explain me how to do this ?
All I know is my root partition is installed on my sda9 partition
do not need chroot.
in manjaro live mount your system partitions and now enter this commands :
sudo pacman -S arch-install-scripts
pacstrap -i /mnt glibc lib32-glibc
Pacman not broken in live manjaro
he most install arch-install-scripts with pacman in live manjaro after use pacstrap to install glibc and lib32-glibc.
or he can use your commands
yes.
DO NOT ! remove any pkg which you do not know
and sorry if i not able to type English correctly.
i am 12 ! years old and my language not en.
i am Iran and my language is Persian.
for example i remove all pkg with k is first letters in arch and after “I CAN NOT USE SUDO AND PACMAN AND MY SYSTEM NOT BOOT”
I fixed this with live arch.
