Edit: As I needed a quick “solution” to get work done, I took the L and just started fresh on a new Manjaro installation. This time making backups and trying to do everything right.
Hi guys, I had issues with my kernel update and once I figured out a fix for that I now have this issue shown below:
sudo: error in /etc/sudo.conf, line 0 while loading plugin "sudoers_policy"
sudo: unable to load /usr/lib/sudo/sudoers.so: libldap-2.4.so.2: cannot open shared object file: No such file or directory
sudo: fatal error, unable to load plugins
Anytime I try to use sudo to install anything I get this error. I tried the following which I saw on another post:
su
and enter the root password you set at install, then run:
pacman -Syyu sudo libsasl
then reboot the system
systemctl reboot
However when I run the below command, I get an error regarding an invalid or corrupted package.
core 168.9 KiB 207 KiB/s 00:01 [#######################################################################################] 100%
extra 1901.2 KiB 1621 KiB/s 00:01 [#######################################################################################] 100%
community 7.0 MiB 1914 KiB/s 00:04 [#######################################################################################] 100%
multilib 174.0 KiB 352 KiB/s 00:00 [#######################################################################################] 100%
warning: libsasl-2.1.27-3 is up to date -- reinstalling
resolving dependencies...
error: could not open file /var/lib/pacman/local/lib32-mesa-21.3.5-1/desc: No such file or directory
warning: could not fully load metadata for package lib32-mesa-21.3.5-1
error: failed to prepare transaction (invalid or corrupted package)
Edit: I now also tried to fix this by using su and then running the following commands but still no luck.
pacman-mirrors -f && pacman -Syyu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
0.592 United_States : https://mirrors.gigenet.com/manjaro/
1.533 United_States : https://mirror.arvancloud.com/manjaro/
0.410 Canada : https://mirror.csclub.uwaterloo.ca/manjaro/
0.658 Canada : https://muug.ca/mirror/manjaro/
0.934 Costa_Rica : https://mirrors.ucr.ac.cr/manjaro/
0.489 United_States : https://mirror.math.princeton.edu/pub/manjaro/
1.714 United_States : https://mirrors.ocf.berkeley.edu/manjaro/
0.467 Canada : https://mirror.0xem.ma/manjaro/
0.554 United_States : https://repo.ialab.dsu.edu/manjaro/
0.407 Canada : https://osmirror.org/manjaro/
0.899 United_States : https://mirrors.sonic.net/manjaro/
::INFO Writing mirror list
::Canada : https://osmirror.org/manjaro/stable/$repo/$arch
::Canada : https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
::Canada : https://mirror.0xem.ma/manjaro/stable/$repo/$arch
::United_States : https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
::United_States : https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
::United_States : https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
::Canada : https://muug.ca/mirror/manjaro/stable/$repo/$arch
::United_States : https://mirrors.sonic.net/manjaro/stable/$repo/$arch
::Costa_Rica : https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
::United_States : https://mirror.arvancloud.com/manjaro/stable/$repo/$arch
::United_States : https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core 168.9 KiB 406 KiB/s 00:00 [#######################################] 100%
extra 1901.2 KiB 5.58 MiB/s 00:00 [#######################################] 100%
community 7.0 MiB 10.6 MiB/s 00:01 [#######################################] 100%
multilib 174.0 KiB 2.98 MiB/s 00:00 [#######################################] 100%
I’m relatively new to manjaro and linux as a whole, any help would be greatly appreciated, if you need any further information please let me know.
Thanks in advance.
