Hello,
I have a Dell latitude 5410 with Intel ax 201 and suddenly WiFi doesn’t pick up any connection. It had happened a month earlier and I disabled radio control from bios and wifi came back.
Now not working even after rebooting.
Tried to connect through android USB tethering it doesn’t work either. I have no lan unfortunately
This is outcome of inxi, maybe someone has any idea please?
Kernel: 5.15.76-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e3416a73-0a57-4a9c-bc11-48948434a9c4 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 wm: kwin_wayland vt: 2
Type: Laptop System: Dell product: Latitude 5410 v: N/A
Mobo: Dell model: 030CV1 v: A01 serial: <superuser required> UEFI: Dell
v: 1.7.0 date: 08/02/2021
ID-1: BAT0 charge: 35.3 Wh (62.7%) condition: 56.3/68.0 Wh (82.8%)
volts: 15.9 min: 15.2 model: BYD DELL 3PCVM12 type: Li-poly serial: <filter>
status: discharging
RAM: total: 7.37 GiB used: 1.34 GiB (18.1%)
Info: model: Intel Core i5-10310U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 400/4400 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 35210
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-6:2 chip-ID: 1bcf:28c4 class-ID: 0e02
serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.4
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.2.1 renderer: Mesa Intel UHD Graphics (CML GT2)
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Dell driver: snd_hda_intel
chip-ID: 8086:02c8 class-ID: 0403
Sound API: ALSA v: k5.15.76-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4e class-ID: 0200
IF: eno2 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-10:3
chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 238.47 GiB used: 117.69 GiB (49.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SSSTC model: CL1-3D256-Q11 NVMe
SSSTC 256GB size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 22301116
temp: 20.9 C scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 117.69 GiB (50.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: e3416a73-0a57-4a9c-bc11-48948434a9c4
used: 324 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 5866-F579
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: Sunplus Innovation Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 1bcf:28c4 class-ID: 0e02 serial: <filter>
Device-2: 1-10:3 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.0 C pch: 27.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 212 Uptime: 5m wakeups: 274 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1340 libs: 354 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23 ```
