Hello!
So, out of a sudden, my laptop does mot charge anymore, and the fan is almost on fullon all the time. I restarted the machine, did not change anything. Where does all this work come from? It accepts power by cable, so the battery does not drain, but it does not charge either…
yesterday it was really, really hot when I opened it, and the screen flickered; vanished after suspending.
I haven’t got any idea where to look for the problem… Help appreciated
sudo tlp-stat
Swipe your right index finger across the fingerprint reader
--- TLP 1.5.0 --------------------------------------------
+++ Configured Settings:
defaults.conf L0004: TLP_ENABLE="1"
defaults.conf L0005: TLP_WARN_LEVEL="3"
defaults.conf L0006: TLP_PERSISTENT_DEFAULT="0"
defaults.conf L0007: DISK_IDLE_SECS_ON_AC="0"
defaults.conf L0008: DISK_IDLE_SECS_ON_BAT="2"
defaults.conf L0009: MAX_LOST_WORK_SECS_ON_AC="15"
defaults.conf L0010: MAX_LOST_WORK_SECS_ON_BAT="60"
defaults.conf L0011: CPU_ENERGY_PERF_POLICY_ON_AC="balance_performance"
defaults.conf L0012: CPU_ENERGY_PERF_POLICY_ON_BAT="balance_power"
defaults.conf L0013: SCHED_POWERSAVE_ON_AC="0"
defaults.conf L0014: SCHED_POWERSAVE_ON_BAT="1"
defaults.conf L0015: NMI_WATCHDOG="0"
defaults.conf L0016: DISK_DEVICES="nvme0n1 sda"
defaults.conf L0017: DISK_APM_LEVEL_ON_AC="254 254"
defaults.conf L0018: DISK_APM_LEVEL_ON_BAT="128 128"
defaults.conf L0019: DISK_APM_CLASS_DENYLIST="usb ieee1394"
defaults.conf L0020: DISK_IOSCHED="keep keep"
defaults.conf L0021: SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
defaults.conf L0022: SATA_LINKPWR_ON_BAT="med_power_with_dipm min_power"
defaults.conf L0023: AHCI_RUNTIME_PM_ON_AC="on"
defaults.conf L0024: AHCI_RUNTIME_PM_ON_BAT="auto"
defaults.conf L0025: AHCI_RUNTIME_PM_TIMEOUT="15"
defaults.conf L0026: PCIE_ASPM_ON_AC="default"
defaults.conf L0027: PCIE_ASPM_ON_BAT="default"
defaults.conf L0028: RADEON_DPM_PERF_LEVEL_ON_AC="auto"
defaults.conf L0029: RADEON_DPM_PERF_LEVEL_ON_BAT="auto"
defaults.conf L0030: RADEON_POWER_PROFILE_ON_AC="default"
defaults.conf L0031: RADEON_POWER_PROFILE_ON_BAT="default"
defaults.conf L0032: WIFI_PWR_ON_AC="off"
defaults.conf L0033: WIFI_PWR_ON_BAT="on"
defaults.conf L0034: WOL_DISABLE="Y"
defaults.conf L0035: SOUND_POWER_SAVE_ON_AC="1"
defaults.conf L0036: SOUND_POWER_SAVE_ON_BAT="1"
defaults.conf L0037: SOUND_POWER_SAVE_CONTROLLER="Y"
defaults.conf L0038: BAY_POWEROFF_ON_AC="0"
defaults.conf L0039: BAY_POWEROFF_ON_BAT="0"
defaults.conf L0040: BAY_DEVICE="sr0"
defaults.conf L0041: RUNTIME_PM_ON_AC="on"
defaults.conf L0042: RUNTIME_PM_ON_BAT="auto"
defaults.conf L0043: RUNTIME_PM_DRIVER_DENYLIST="mei_me nouveau radeon"
defaults.conf L0044: USB_AUTOSUSPEND="1"
defaults.conf L0045: USB_EXCLUDE_AUDIO="1"
defaults.conf L0046: USB_EXCLUDE_BTUSB="0"
defaults.conf L0047: USB_EXCLUDE_PHONE="0"
defaults.conf L0048: USB_EXCLUDE_PRINTER="1"
defaults.conf L0049: USB_EXCLUDE_WWAN="0"
defaults.conf L0050: USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN="0"
defaults.conf L0051: RESTORE_DEVICE_STATE_ON_STARTUP="0"
defaults.conf L0052: RESTORE_THRESHOLDS_ON_BAT="0"
defaults.conf L0053: NATACPI_ENABLE="1"
defaults.conf L0054: TPACPI_ENABLE="1"
defaults.conf L0055: TPSMAPI_ENABLE="1"
/etc/tlp.conf L0425: START_CHARGE_THRESH_BAT0="70"
/etc/tlp.conf L0426: STOP_CHARGE_THRESH_BAT0="85"
+++ System Info
System = LENOVO ThinkPad X230 2325ZKJ
BIOS = G2ETB7WW (2.77 )
OS Release = Manjaro Linux
Kernel = 5.15.60-1-MANJARO #1 SMP PREEMPT Thu Aug 11 13:14:05 UTC 2022 x86_64
/proc/cmdline = BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=45cc9148-4826-498d-a298-0d2a04986429 rw quiet apparmor=1 security=apparmor udev.log_priority=3
Init system = systemd
Boot mode = BIOS (CSM, Legacy)
+++ TLP Status
State = enabled
RDW state = not installed
Last run = 10:43:42 PM, 648 sec(s) ago
Mode = AC
Power source = AC
Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
>>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
>>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
+++ Processor
CPU model = Intel(R) Core(TM) i5-3320M CPU @ 2.60GHz
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver = intel_cpufreq
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = schedutil
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = conservative ondemand userspace powersave performance schedutil
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 1200000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 3300000 [kHz]
/sys/devices/system/cpu/cpu1..cpu3: omitted for clarity, use -v to show all
/sys/devices/system/cpu/intel_pstate/status = passive
/sys/devices/system/cpu/intel_pstate/min_perf_pct = 36 [%]
/sys/devices/system/cpu/intel_pstate/max_perf_pct = 100 [%]
/sys/devices/system/cpu/intel_pstate/no_turbo = 0
/sys/devices/system/cpu/intel_pstate/hwp_dynamic_boost = (not available)
/sys/devices/system/cpu/intel_pstate/turbo_pct = 33 [%]
/sys/devices/system/cpu/intel_pstate/num_pstates = 22
/sys/devices/system/cpu/cpu0/power/energy_perf_bias = 6 (default) [EPB]
/sys/module/workqueue/parameters/power_efficient = Y
/proc/sys/kernel/nmi_watchdog = 0
+++ Platform Profile
/sys/firmware/acpi/platform_profile = (not available)
/sys/firmware/acpi/platform_profile_choices = (not available)
/sys/devices/platform/thinkpad_acpi/dytc_lapmode = (not available)
+++ Temperatures
/proc/acpi/ibm/thermal = 52 0 0 0 0 0 0 0 [°C]
/proc/acpi/ibm/fan = 3337 [/min]
+++ File System
/proc/sys/vm/laptop_mode = 0
/proc/sys/vm/dirty_writeback_centisecs = 1500
/proc/sys/vm/dirty_expire_centisecs = 1500
/proc/sys/vm/dirty_ratio = 20
/proc/sys/vm/dirty_background_ratio = 10
+++ Disks
Devices = nvme0n1 sda
/dev/nvme0n1: not present.
/dev/sda:
Type = SATA
Disk ID = ata-CT500MX500SSD1_200225FE18E1
Model = CT500MX500SSD1
Firmware = M3CR023
APM Level = 254
Status = active/idle
TRIM = supported
Host = host0
Scheduler = [mq-deadline] kyber bfq none (multi queue)
Runtime PM:
/sys/block/sda/device/power/control = on, autosuspend_delay_ms = 15000
+++ AHCI Link Power Management (ALPM) :: SATA Links
/sys/bus/pci/devices/0000:00:1f.2/ata1/host0/scsi_host/host0/link_power_management_policy = med_power_with_dipm -- sda
/sys/bus/pci/devices/0000:00:1f.2/ata2/host1/scsi_host/host1/link_power_management_policy = med_power_with_dipm
/sys/bus/pci/devices/0000:00:1f.2/ata3/host2/scsi_host/host2/link_power_management_policy = med_power_with_dipm -- sdb
/sys/bus/pci/devices/0000:00:1f.2/ata4/host3/scsi_host/host3/link_power_management_policy = med_power_with_dipm
/sys/bus/pci/devices/0000:00:1f.2/ata5/host4/scsi_host/host4/link_power_management_policy = med_power_with_dipm
/sys/bus/pci/devices/0000:00:1f.2/ata6/host5/scsi_host/host5/link_power_management_policy = med_power_with_dipm
+++ AHCI Port Runtime Power Management :: SATA/ATA Ports
/sys/bus/pci/devices/0000:00:1f.2/ata1/power/control = on -- sda
/sys/bus/pci/devices/0000:00:1f.2/ata2/power/control = on
/sys/bus/pci/devices/0000:00:1f.2/ata3/power/control = on -- sdb
/sys/bus/pci/devices/0000:00:1f.2/ata4/power/control = on
/sys/bus/pci/devices/0000:00:1f.2/ata5/power/control = on
/sys/bus/pci/devices/0000:00:1f.2/ata6/power/control = on
+++ Docks and Device Bays
/sys/devices/platform/dock.0: battery_bay = no battery
/sys/devices/platform/dock.1: ata_bay = no drive (or powered off)
/sys/devices/platform/dock.2: dock_station = undocked
+++ Intel Graphics
/sys/class/drm/card0/device/driver = i915
/sys/class/drm/card0/power/rc6_enable = 3 (enabled + deep)
/sys/kernel/debug/dri/0/i915_fbc_status = FBC disabled: disabled at runtime per module param
/sys/module/i915/parameters/enable_psr = -1 (use per-chip default)
/sys/class/drm/card0/gt_min_freq_mhz = 350 [MHz]
/sys/class/drm/card0/gt_max_freq_mhz = 1200 [MHz]
/sys/class/drm/card0/gt_boost_freq_mhz = 1200 [MHz]
/sys/class/drm/card0/gt_RPn_freq_mhz = 350 [MHz] (GPU min)
/sys/class/drm/card0/gt_RP0_freq_mhz = 1200 [MHz] (GPU max)
+++ Wireless
bluetooth = on
nfc = none (no device)
wifi = on
wwan = none (no device)
hci0(btusb) : bluetooth, not connected
wlp3s0(iwlwifi) : wifi, connected, power management = off
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save = 1
/sys/module/snd_hda_intel/parameters/power_save_controller = Y
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = [default] performance powersave powersupersave (using BIOS preferences)
+++ PCIe Runtime Power Management
Enable devices = (disabled)
Disable devices = (disabled)
Device denylist = (disabled)
Driver denylist = mei_me nouveau radeon
/sys/bus/pci/devices/0000:00:00.0/power/control = on (0x060000, Host bridge, ivb_uncore)
/sys/bus/pci/devices/0000:00:02.0/power/control = on (0x030000, VGA compatible controller, i915)
/sys/bus/pci/devices/0000:00:14.0/power/control = on (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:00:16.0/power/control = on (0x078000, Communication controller, mei_me)
/sys/bus/pci/devices/0000:00:16.3/power/control = on (0x070002, Serial controller, serial)
/sys/bus/pci/devices/0000:00:19.0/power/control = on (0x020000, Ethernet controller, e1000e)
/sys/bus/pci/devices/0000:00:1a.0/power/control = on (0x0c0320, USB controller, ehci-pci)
/sys/bus/pci/devices/0000:00:1b.0/power/control = on (0x040300, Audio device, snd_hda_intel)
/sys/bus/pci/devices/0000:00:1c.0/power/control = on (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1c.1/power/control = on (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1c.2/power/control = on (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1d.0/power/control = on (0x0c0320, USB controller, ehci-pci)
/sys/bus/pci/devices/0000:00:1f.0/power/control = on (0x060100, ISA bridge, lpc_ich)
/sys/bus/pci/devices/0000:00:1f.2/power/control = on (0x010601, SATA controller, ahci)
/sys/bus/pci/devices/0000:00:1f.3/power/control = on (0x0c0500, SMBus, i801_smbus)
/sys/bus/pci/devices/0000:02:00.0/power/control = on (0x088001, System peripheral, sdhci-pci)
/sys/bus/pci/devices/0000:03:00.0/power/control = on (0x028000, Network controller, iwlwifi)
+++ USB
Autosuspend = enabled
Device allowlist = (not configured)
Device denylist = (not configured)
Exclude audio = enabled
Exclude bluetooth = disabled
Exclude phones = disabled
Exclude printers = enabled
Exclude WWAN = disabled
Bus 002 Device 002 ID 8087:0024 control = auto, autosuspend_delay_ms = 0 -- Intel Corp. Integrated Rate Matching Hub (hub)
Bus 002 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 2.0 root hub (hub)
Bus 001 Device 005 ID 5986:02d2 control = auto, autosuspend_delay_ms = 2000 -- Acer, Inc ThinkPad Integrated Camera (uvcvideo)
Bus 001 Device 004 ID 0a5c:21e6 control = auto, autosuspend_delay_ms = 2000 -- Broadcom Corp. BCM20702 Bluetooth 4.0 [ThinkPad] (btusb)
Bus 001 Device 003 ID 147e:2020 control = auto, autosuspend_delay_ms = 2000 -- Upek TouchChip Fingerprint Coprocessor (WBF advanced mode) (no driver)
Bus 001 Device 002 ID 8087:0024 control = auto, autosuspend_delay_ms = 0 -- Intel Corp. Integrated Rate Matching Hub (hub)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 2.0 root hub (hub)
Bus 004 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 3.0 root hub (hub)
Bus 003 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 2.0 root hub (hub)
+++ Battery Care
Plugin: thinkpad
Supported features: charge thresholds
Driver usage:
* natacpi (thinkpad_acpi) = active (charge thresholds)
* tpacpi-bat (acpi_call) = inactive (kernel module 'acpi_call' not installed)
Parameter value ranges:
* START_CHARGE_THRESH_BAT0/1: 0(off)..96(default)..99
* STOP_CHARGE_THRESH_BAT0/1: 1..100(default)
+++ ThinkPad Battery Status: BAT0 (Main / Internal)
/sys/class/power_supply/BAT0/manufacturer = SANYO
/sys/class/power_supply/BAT0/model_name = 45N1023
/sys/class/power_supply/BAT0/cycle_count = 0 (or not supported)
/sys/class/power_supply/BAT0/energy_full_design = 48840 [mWh]
/sys/class/power_supply/BAT0/energy_full = 51030 [mWh]
/sys/class/power_supply/BAT0/energy_now = 30250 [mWh]
/sys/class/power_supply/BAT0/power_now = 0 [mW]
/sys/class/power_supply/BAT0/status = Not charging
/sys/class/power_supply/BAT0/charge_control_start_threshold = 70 [%]
/sys/class/power_supply/BAT0/charge_control_end_threshold = 85 [%]
Charge = 59.3 [%]
Capacity = 104.5 [%]
+++ Recommendations
* Install acpi_call kernel module for ThinkPad battery recalibrationInstall ethtool to disable Wake-on-LAN
* Install smartmontools for disk drive health info
