Hello everyone.
A few days ago GRUB started showing up on boot for a couple seconds then booting Manjaro. I’ve not seen it before it used to always boot straight into Manjaro. In GRUB there are two entries: “Manjaro Linux” and “Manjaro Linux (on /dev/nvme0n1p2)”. No matter what (if any) I select it boots in the same Manjaro installation, I’ve never installed a second one anyway.
I don’t know exactly when it started and thus what I did before. I had some issues with Chromium though which freezes everything and turns everything black. I don’t think this is a related issue but it forced me to hard reset the PC and I can neither confirm nor deny that this started it.
I did some research and saw that /etc/default/grub can be edited to hide it on start. However I saw that in there GRUB_TIMEOUT_STYLE is already set to “hidden”. GRUB_TIMEOUT was set to “5”, I’ve changed it to “0” just to test and ran sudo update-grub. It just changed the timeout to 10 seconds and I reverted it.
I feel like this is slowing down my boot unnecessarily and would like to hide it again but I found no way to do so. I did see s/o mentioning setting the timeout to “0.0” but others commented it was weird so I rather stayed away from it. I’m pretty new and really don’t want to break anything.
Thank you in advance.
Just to be sure about the current active options set in your /etc/default/grub
grep -v ^# /etc/default/grub
This ist what mine looks like:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR='Manjaro'
GRUB_CMDLINE_LINUX_DEFAULT='mitigations=off quiet udev.log_priority=3 audit=0'
GRUB_CMDLINE_LINUX=""
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
GRUB_DISABLE_RECOVERY=true
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
GRUB_SAVEDEFAULT=true
I did alter the GRUB_CMDLINE_LINUX_DEFAULT line - but that is not important here.
I have seen threads with descriptions that look similar to yours.
Reinstalling grub was suggested and might be the solution.
sudo pacman -Syu install-grub
sudo install-grub
Thank you for your reply. Here is my output:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX_DEFAULT='quiet splash udev.log_priority=3'
GRUB_GFXMODE=auto
GRUB_SAVEDEFAULT=false
GRUB_DISABLE_OS_PROBER=false
Reinstalling GRUB sounds… exciting. The holding-my-breath-while-booting kind of exciting. I’ll let you review the output above first if that’s okay.
It was just for you to compare my pretty much unaltered file with what you have.
One thing I saw:
You have
active
This means:
it is NOT disabled - it is enabled
read the explanatory comments above each option:
The following is the default setting.
#GRUB_DISABLE_OS_PROBER=false
comment that option again if you are not dual booting
Research what install-grub does - nothing exiting.
Here is one thread with an example of what it does:
Totally broken system after December 2025 Stable Update - #82 by Nachlese
essentially this:
sudo cp /boot/efi/EFI/Manjaro/grubx64.efi /boot/efi/EFI/boot/bootx64.efi
Running install-grub is non-intrusive operation - it is Manjaro specific helper script designed to ensure compatibility between the manjaro loader and the grub efi default loader when reading the /boot/grub/grub.cfg - it also checks if your currently booted efi entry is manjaro.
If you don’t dual-boot with windows - comment the line `GRUB_DISABLE_OS_PROBER=false’ - already suggested.
My bad, I misinterpreted you there. Unlikely I would’ve picked up the uncommented line though so thank you for pointing that out. This was indeed the solution, commenting it out resulted in a boot without grub showing up. No clue how that happened, I have never touched that before and even after grub was showing, I have not messed with that particular line.
The explanatory comments sometimes don’t really explain a lot to me. And given that I have not touched this line myself at all I would’ve assumed everything is in order had I read it. Probably again my bad. On that note: Any educated guesses as to how this can happen? Something must’ve caused the change, right?
Thanks a lot for your time and support. Glad this was such an easy fix. =)
Many thanks to you as well. I do have my old Windows on another SSD but I just change the boot device in the UEFI in the rare case I need to boot into Windows so grub shouldn’t have anything to do with it.
I think (!) that this was the default once, but it got changed to be disabled by default some time ago.
Not sure - can’t remember.
If that happened, you should have (had) a .pacnew file - or perhaps still have it.
