sorry for the poor title. Anyway, I am running Manjaro Gnome on Kernel 6.0.6-1 and I am running in issues which prevent me from updating, both from pacman and from the graphical interface.
From Pacman:
sudo pacman -Syu ✔ 4m 20s
core is up to date
extra is up to date
community is up to date
multilib is up to date
linux-surface is up to date
error: could not open file /var/lib/pacman/local/boost-1.80.0-2/desc: No such file or directory
:: Replace nerd-fonts-terminus with community/ttf-terminus-nerd? [Y/n] n
resolving dependencies...
:: ttf-terminus-nerd and nerd-fonts-terminus are in conflict. Remove nerd-fonts-terminus? [y/N] n
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
and from the graphical interface:
I just get a window telling me:
invalid or corrupted package
with only a “close” button
I can’t seem to locate the problem. Does anybody know where to start?
I tried:
sudo pacman -Scc ✔
Cache directory: /var/cache/pacman/pkg/
:: Do you want to remove ALL files from cache? [y/N] y
removing all files from cache...
Database directory: /var/lib/pacman/
:: Do you want to remove unused repositories? [Y/n] y
removing unused sync repositories...
and
sudo pamac reinstall boost-libs ✔ 5s
Preparing...
Warning: boost-libs-1.80.0-3 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
To reinstall (1):
boost-libs 1.80.0-3 extra 2,2 MB
Total download size: 2,2 MB
Apply transaction ? [y/N] y
Download of boost-libs (1.80.0-3) started
Download of boost-libs (1.80.0-3) finished
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Reinstalling boost-libs (1.80.0-3)... [1/1]
ldconfig: File /usr/lib/libQt5Help.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Designer.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5DesignerComponents.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Help.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5DesignerComponents.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5Help.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5DesignerComponents.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5Designer.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Help.so.5.15.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5DesignerComponents.so.5.15.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5Designer.so.5.15.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5Designer.so.5.15 is empty, not checked.
If you response with n to a question the whole transaction is cancelled.
Answering with “y” doesn’t change much, I believe:
sudo pacman -Syu ✔
core is up to date
extra is up to date
:: Replace nerd-fonts-terminus with community/ttf-terminus-nerd? [Y/n] y
warning: could not fully load metadata for package boost-1.80.0-2
error: failed to prepare transaction (invalid or corrupted package)
sudo pacman -S --dbonly boost 1 ✘
The first command works, but then:
pamac install ttf-terminus-nerd 1 ✘
Preparing...
Warning: could not fully load metadata for package boost-1.80.0-2
Error: Failed to prepare transaction: invalid or corrupted package
