Hello,
If this post is not for here I will delete it!
I have sudden reboots and this time i caught the message that it gives me while rebooting:
[0.663756] mce: [Hardware Error]: CPU 5: Machine Check: 0 Bank 5: bca0000000000108
[0.663764] mce: [Hardware Error]: TSC 0 ADDR 7fa740657dc0 MISC d012000100000000 SYND 4d000000 IPID 500b000000000
[0.663773] mce: [Hardware Error]: PROCESSOR 2:a20f12 TIME 1704674494 SOCKET 0 APIC a microcode a201204
I’ve got a picture of it and wrote it down. So at first I thought that it may be my PSU and i changed it with bigger, more powerful one. It wasn’t the case. After that I changed the motherboard, which wasn’t the problem either. After that I changed the CPU too, but funny story, it wasn’t the problem again.
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=809ab622-c274-4d31-9f9b-9c714537dbc1 rw quiet splash
resume=UUID=735b360b-4cae-4cf7-ac6d-d1a8c1e6388f udev.log_priority=3
Desktop: GNOME v: 45.2 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM v: 45.0.1
Type: Desktop Mobo: Micro-Star model: MAG X570S TORPEDO MAX (MS-7D54) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.00
date: 07/09/2021
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA201204
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 3773 high: 4000 min/max: 2200/5484 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3999 2: 3999
3: 3999 4: 3999 5: 3999 6: 4000 7: 3998 8: 3997 9: 4000 10: 3999 11: 3998
12: 4000 13: 2200 14: 3999 15: 2200 16: 3989 bogomips: 128053
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 2f:00.0
chip-ID: 1002:731f class-ID: 0300
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: Acer VG240Y V serial: <filter> built: 2020
res: 1920x1080 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 model: Acer VG240Y serial: <filter> built: 2020
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 (navi10 LLVM
16.0.6 DRM 3.54 6.5.13-7-MANJARO) device-ID: 1002:731f memory: 7.81 GiB
unified: no display-ID: :0.0
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2
chip-ID: 0db0:a073 class-ID: 0300
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api
Server-2: PipeWire v: 1.0.0 status: off tools: pw-cli
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 26:00.0
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 28:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 2.04 TiB used: 496.44 GiB (23.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS100T2B0A-00SM50 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 20WD
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 240GB
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 04RL scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: HDWD110
tech: HDD rpm: 7200 serial: <filter> fw-rev: A8R0 scheme: GPT
ID-1: / raw-size: 214.57 GiB size: 210.14 GiB (97.94%) used: 18.13 GiB (8.6%)
fs: ext4 dev: /dev/sdb3 maj-min: 8:19
ID-2: /boot/efi raw-size: 1 GiB size: 1023 MiB (99.80%)
used: 288 KiB (0.0%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
used: 478.32 GiB (52.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 56.8 C mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 58.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 434 Uptime: 35m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 8.05 GiB (25.7%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1115 libs: 395 tools: gnome-software,pamac,yay
pm: appimage pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.31
If anyone have any clue I will be very greatful, because this thing is annoying and it doesn’t stop no matter what.
Thanks in advance!
Edit: Giving better system info.
cscs
8 January 2024 01:15
2
Decent system info:
inxi -Fazy
General guide on getting and formatting information, etc:
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links whene…
cscs
8 January 2024 01:24
4
talasum:
Kernel 6.5 is EOL.
Please install 6.1,6.6, reboot into one of those LTS kernels, and remove 6.5
You have BIOS updates available.
Which detail everything from security to amd support.
So you should probably do that.
If my search is correct
https://www.msi.com/Motherboard/MAG-X570S-TORPEDO-MAX/support
Okay, I will change the kernel and update BIOS, with my older motherboard i was up to date with BIOS and I was using LTS kernel and it was the same. Will keep you updated on what happens after kernel change and BIOS update!
cscs
8 January 2024 01:38
6
Its a good start … if not … it may be this, which it does seem to match
https://wiki.archlinux.org/title/Ryzen#Random_reboots
Which you would still want updated BIOS for.
The ‘solution’ in that case would be
To solve this problem you need to supply higher voltage to your CPU so that it is stable when running at peak frequencies.
The easiest way to achieve this is to use the AMD curve optimiser which is accessible via your motherboard’s bios. Access it and put a positive offset of 4 points, which will increase the voltage your CPU is getting at higher loads.
Note
Okay, now I’m downloading the BIOS file and will update it soon.
About your NOTE, I don’t overclock so it should be fine.
I will try this solution you gave me and will report back after some testing!
There it is with kernel 6.6 and latest BIOS:
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Type: Desktop Mobo: Micro-Star model: MAG X570S TORPEDO MAX (MS-7D54) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.80
date: 10/26/2023
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
desc: 1x32 MiB
Speed (MHz): avg: 2682 high: 3597 min/max: 2200/4662 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3597 2: 2200
3: 3400 4: 2879 5: 3400 6: 2200 7: 2880 8: 2879 9: 2200 10: 2200 11: 3400
12: 2200 13: 2200 14: 2200 15: 2200 16: 2885 bogomips: 108834
16.0.6 DRM 3.54 6.6.8-2-MANJARO) device-ID: 1002:731f memory: 7.81 GiB
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api
Local Storage: total: 2.04 TiB used: 508.14 GiB (24.4%)
scheme: GPT
ID-1: / raw-size: 214.57 GiB size: 210.14 GiB (97.94%) used: 18.25 GiB (8.7%)
used: 489.89 GiB (53.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 58.0 C
Processes: 420 Uptime: 3m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 4.38 GiB (14.0%) Init: systemd v: 254
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.31
