This is a install that worked since a few years until recently
inxi
sudo inxi --admin --verbosity=7 --filter --no-host --width 22 ✘ 5s
Kernel: 5.15.94-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=3487ba3d-1cba-4cdc-a043-c420ebca2aca rw rootflags=subvol=@
bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
modprobe.blacklist=ccp udev.log_priority=3 audit=0 sysrq_always_enabled=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: B450 Pro4 serial: <filter>
UEFI: American Megatrends v: P1.10 date: 06/19/2018
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
status: discharging
Device-2: hidpp_battery_1 model: Logitech K520 serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
RAM: total: 46.98 GiB used: 26.01 GiB (55.4%)
Array-1: capacity: 256 GiB slots: 4 EC: None max-module-size: 64 GiB
note: est.
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: spec: 2134 MT/s actual: 1067 MT/s volts: curr: 1.2
min: 1.2 max: 1.2 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3200C16-16GIS serial: N/A
Device-2: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: spec: 2134 MT/s actual: 1067 MT/s volts: curr: 1.2
part-no: F4-3000C16-8GISB serial: N/A
Device-3: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 7 2700 socket: AM4 bits: 64 type: MT MCP arch: Zen+
gen: 2 level: v3 note: check built: 2018-21 process: GF 12nm
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 1550 min/max: 1550/3200 boost: enabled
base/boost: 3200/4100 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.0 V ext-clock: 100 MHz cores: 1: 1550 2: 1550 3: 1550 4: 1550
5: 1550 6: 1550 7: 1550 8: 1550 9: 1550 10: 1550 11: 1550 12: 1550 13: 1550
14: 1550 15: 1550 16: 1550 bogomips: 102225
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GK107 [GeForce GT 740] vendor: eVga.com. driver: nouveau
v: kernel non-free: series: 470.xx+ status: legacy-active (EOL~2023/24)
arch: Kepler code: GKxxx process: TSMC 28nm built: 2012-18 pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DVI-D-1,DVI-I-1 bus-ID: 01:00.0 chip-ID: 10de:0fc8
class-ID: 0300 temp: 39.0 C
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte
driver: nouveau v: kernel non-free: 525.xx+ status: current (as of 2023-02)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: HDMI-A-2 empty: DP-1, DVI-D-2, HDMI-A-3, HDMI-A-4 bus-ID: 27:00.0
chip-ID: 10de:1c82 class-ID: 0300 temp: 57.0 C
Device-3: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-6.1:4 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: xfwm v: 4.18.0 driver: X: loaded: modesetting
alternate: fbdev,vesa dri: nouveau gpu: nouveau display-ID: :1.0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-2 res: 3840x2160 dpi: 163 size: 600x340mm (23.62x13.39")
diag: 690mm (27.15") modes: N/A
API: OpenGL v: 4.3 Mesa 22.3.5 renderer: NV137 direct-render: Yes
Device-1: NVIDIA GK107 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
bus-ID: 1-6.1:4 v: kernel pcie: chip-ID: 046d:085c gen: 1 class-ID: 0102
serial: <filter> speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 27:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-3: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 29:00.3
chip-ID: 1022:1457 class-ID: 0403
Device-4: Logitech C922 Pro Stream Webcam type: USB
Sound API: ALSA v: k5.15.94-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.65 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: c000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-6.2:5 chip-ID: 0a12:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 7.79 TiB used: 582.04 GiB (7.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 42AZS6AC temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 53d 23h cycles: 721
read-units: 24,233,089 [12.4 TB] written-units: 39,909,201 [20.4 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH31000G
family: Marvell based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 10RL temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 208d 10h cycles: 1585
ID-3: /dev/sdb maj-min: 8:16 vendor: A-Data model: SP610 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2C temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 37d 18h cycles: 3282
read: 361 MiB written: 504.1 MiB Old-Age: UDMA CRC errors: 446
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: Expansion HDD
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 1901 scheme: GPT
SMART Message: A mandatory SMART command failed. Various possible causes.
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD-RAM GH22NS30 rev: 1.01
dev-links: cdrom
ID-1: / raw-size: 900 GiB size: 900 GiB (100.00%) used: 582.03 GiB (64.7%)
fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 3487ba3d-1cba-4cdc-a043-c420ebca2aca
ID-2: /.snapshots raw-size: 900 GiB size: 900 GiB (100.00%)
used: 582.03 GiB (64.7%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: 3487ba3d-1cba-4cdc-a043-c420ebca2aca
ID-3: /boot/efi raw-size: 953 MiB size: 951.1 MiB (99.80%)
used: 8.2 MiB (0.9%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: C579-EF17
ID-4: /home raw-size: 900 GiB size: 900 GiB (100.00%)
ID-5: /home/.snapshots raw-size: 900 GiB size: 900 GiB (100.00%)
ID-6: /var/nosnap raw-size: 900 GiB size: 900 GiB (100.00%)
ID-7: /var/nosnap/.snapshots raw-size: 900 GiB size: 900 GiB (100.00%)
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 1024 MiB fs: vfat label: N/A
uuid: B027-5E71
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 1024 KiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 900 GiB fs: btrfs label: N/A
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1006.73 GiB fs: btrfs label: N/A
uuid: 94567c06-a951-4b6a-923f-3d5bc37e760a
ID-5: /dev/sda3 maj-min: 8:3 size: 28.13 GiB fs: N/A label: N/A uuid: N/A
ID-6: /dev/sdb1 maj-min: 8:17 size: 512 MiB fs: vfat label: EFI
uuid: 8CFB-34DD
ID-7: /dev/sdb2 maj-min: 8:18 size: 476.44 GiB fs: N/A label: N/A uuid: N/A
ID-8: /dev/sdc1 maj-min: 8:33 size: 1024 MiB fs: exfat label: N/A
uuid: 679B-3D0F
ID-9: /dev/sdc2 maj-min: 8:34 size: 10 GiB fs: N/A label: N/A uuid: N/A
ID-10: /dev/sdc3 maj-min: 8:35 size: 1.95 TiB fs: btrfs label: 1
uuid: 03417033-3745-4ae7-9451-efafcbb9124e
ID-11: /dev/sdc5 maj-min: 8:37 size: 1000 GiB fs: btrfs label: 3
uuid: e4bd7c8c-c9e1-440a-9ce0-76d6e93b655e
ID-12: /dev/sdc6 maj-min: 8:38 size: 1000 GiB fs: btrfs label: 4
uuid: eb645c31-0cd4-43a5-90b4-077b6d98cd70
ID-13: /dev/sdc7 maj-min: 8:39 size: 646.53 GiB fs: btrfs label: 5
uuid: 1c90b365-7ec4-48ee-9545-dad484a85750
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:2 info: X10 Wireless Transceiver (ACPI-compliant)
type: <vendor specific> driver: ati_remote interfaces: 1 rev: 1.1
speed: 1.5 Mb/s power: 2mA chip-ID: 0bc7:0006 class-ID: 0000
Hub-2: 1-6:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-6.1:4 info: Logitech C922 Pro Stream Webcam type: Video,Audio
power: 500mA chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Device-2: 1-6.2:5 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-3:2 info: Seagate RSS LLC Expansion HDD type: Mass Storage
driver: uas interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA
chip-ID: 0bc2:2037 class-ID: 0806 serial: <filter>
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 3-2:2 info: Manufacturer hub ports: 4 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a05:7211 class-ID: 0900
Device-1: 3-2.2:4 info: MosArt Wireless Keyboard/Mouse type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 062a:4101 class-ID: 0301
Device-2: 3-2.3:6 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-3: 3-2.4:8 info: Xenta 2.4G Receiver type: Keyboard,Mouse
chip-ID: 1d57:fa23 class-ID: 0301
Hub-6: 3-3:3 info: Transcend Information microSD/SD/CF UHS-II Card Reader
[RDF8 RDF9] ports: 4 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 8564:4000 class-ID: 0900
Device-1: 3-3.2:5 info: Areson Corp Elecom MR-K013 Multicard Reader
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 25a7:fa61 class-ID: 0301
Device-2: 3-3.4:7 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 49.0 C mobo: N/A
GPU: device: nouveau temp: 39.0 C mV: 975.00 device: nouveau temp: 57.0 C
fan: 0
Processes: 548 Uptime: 10h 3m wakeups: 41 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 2368 libs: 493 tools: pamac,trizen
Shell: Zsh (sudo) v: 5.9 running-in: kitty inxi: 3.3.25
There’s been crazy behavior lately. And it only seems to hit the 2nd seat.
1) Black screen while login (since sometime in 2022)
When the computer starts, there is a graphical login at the 1st seat. I log in and everything works fine.
The screen for the 2nd seat remains dark. But with htop it is visible that lightdm is active. In the 2nd seat, when I enter the password for the second user, the desktop is activated on the second screen and everything is fine.
I haven’t found a solution to this yet. So I live with that.
2) Random freeze on seat 2 (since sometime 2023)
When working on seat 2, the mouse and keyboard sometimes seem to disconnect, or the GUI seems to freeze. (But the programs stay active according to htop)
I need to end the xfce session from a terminal at seat1. Then screen 2 goes dark and seat2 can log in again.
This is not good because sometimes work is lost that way.
3) Random screen failure (for maybe 4-8 weeks)
When someone is working on Seat2, the screen goes black at a random time (as if you disconnected the monitor cable). Then after 1 to 5 seconds the screen will resume as if nothing happened. This happens at random times. Luckily not too often.
I was thinking maybe my hardware is starting to fail and I need a new graphics card for 2nd place.
4) Random logouts at seat 2 (for maybe 2 or 3 weeks)
The other issues still exist, but in addition, while you’re working, the screen may go black and you’re logged out. Entering the password will give you a clean new session ![]()
This is very bad because work is lost that way.
In the logs i find:
journalctl --system --since -10h|grep nouveau ✔
Mär 09 16:10:04 manjaro18 kernel: nouveau 0000:01:00.0: Direct firmware load for nouveau/nve7_fuc084 failed with error -2
Mär 09 16:10:04 manjaro18 kernel: nouveau 0000:01:00.0: Direct firmware load for nouveau/nve7_fuc084d failed with error -2
Mär 09 16:10:04 manjaro18 kernel: nouveau 0000:01:00.0: msvld: unable to load firmware data
Mär 09 16:10:04 manjaro18 kernel: nouveau 0000:01:00.0: msvld: init failed, -19
Mär 09 17:12:36 manjaro18 kernel: nouveau 0000:01:00.0: Direct firmware load for nouveau/nve7_fuc084 failed with error -2
Mär 09 17:12:36 manjaro18 kernel: nouveau 0000:01:00.0: Direct firmware load for nouveau/nve7_fuc084d failed with error -2
Mär 09 17:12:36 manjaro18 kernel: nouveau 0000:01:00.0: msvld: unable to load firmware data
Mär 09 17:12:36 manjaro18 kernel: nouveau 0000:01:00.0: msvld: init failed, -19
But i fear this is not the problem showing, but the re-login ![]()
prior to these lines there is no indication of a problem
cat x-0.log
cat x-0.log
X.Org X Server 1.21.1.7
Current Operating System: Linux manjaro18 5.15.94-1-MANJARO #1 SMP PREEMPT Tue Feb 14 19:45:58 UTC 2023 x86_64
Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64 root=UUID=3487ba3d-1cba-4cdc-a043-c420ebca2aca rw rootflags=subvol=@ bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash modprobe.blacklist=ccp udev.log_priority=3 audit=0 sysrq_always_enabled=1
Current version of pixman: 0.42.2
Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Mar 9 07:32:51 2023
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE) event8 - MOSART Semi. 2.4G Keyboard Mouse: client bug: event processing lagging behind by 25ms, your system is too slow
(EE) event8 - MOSART Semi. 2.4G Keyboard Mouse: client bug: event processing lagging behind by 29ms, your system is too slow
(EE) event8 - MOSART Semi. 2.4G Keyboard Mouse: client bug: event processing lagging behind by 26ms, your system is too slow
(EE) event8 - MOSART Semi. 2.4G Keyboard Mouse: client bug: event processing lagging behind by 21ms, your system is too slow
(EE) event8 - MOSART Semi. 2.4G Keyboard Mouse: client bug: event processing lagging behind by 31ms, your system is too slow
(EE) event8 - MOSART Semi. 2.4G Keyboard Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
(EE) event8 - MOSART Semi. 2.4G Keyboard Mouse: client bug: event processing lagging behind by 23ms, your system is too slow
cat x-1.log
cat x-1.log
(==) Log file: "/var/log/Xorg.1.log", Time: Thu Mar 9 07:32:51 2023
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 30ms, your system is too slow
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 26ms, your system is too slow
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 29ms, your system is too slow
(EE) event4 - Compx 2.4G Receiver Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 35ms, your system is too slow
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 23ms, your system is too slow
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 27ms, your system is too slow
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 25ms, your system is too slow
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 24ms, your system is too slow
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 28ms, your system is too slow
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 22ms, your system is too slow
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Symbol map for key <RALT> redefined
> Using last definition for conflicting fields
Errors from xkbcomp are not fatal to the X server
(EE) event12 - Logitech K270: client bug: event processing lagging behind by 29ms, your system is too slow
(EE) event12 - Logitech K270: client bug: event processing lagging behind by 33ms, your system is too slow
(EE) event12 - Logitech K270: client bug: event processing lagging behind by 21ms, your system is too slow
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 32ms, your system is too slow
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 33ms, your system is too slow
(EE) event12 - Logitech K270: client bug: event processing lagging behind by 26ms, your system is too slow
(EE) event12 - Logitech K270: client bug: event processing lagging behind by 31ms, your system is too slow
(EE) event12 - Logitech K270: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
(EE) event12 - Logitech K270: client bug: event processing lagging behind by 30ms, your system is too slow
(EE) event12 - Logitech K270: client bug: event processing lagging behind by 23ms, your system is too slow
(EE) event12 - Logitech K270: client bug: event processing lagging behind by 35ms, your system is too slow
(EE) event12 - Logitech K270: client bug: event processing lagging behind by 25ms, your system is too slow
(EE) event4 - Compx 2.4G Receiver Mouse: client bug: event processing lagging behind by 31ms, your system is too slow
(EE) event12 - Logitech K270: client bug: event processing lagging behind by 28ms, your system is too slow
(EE) event12 - Logitech K270: client bug: event processing lagging behind by 22ms, your system is too slow
There are some (EE) Warnings in xorg logfiles.
