I also encountered sudden freezes repeatedly on kernel 6.6.74-1. Partly the mouse pointer was still moving slowly but got out of control and I made a hard reboot via PC-RESET button.
My solution to this problem was a fallback to the prior 6.1.126-1 kernel version that’s still installed on the system. After reboot and kernel downgrade no sudden system freeze has occurred so far.
UPDATE: unfortunately system freezes still occur sporadically on kernel 6.1.126-1. Seems to be a deeper issue.
my inxi -zv8 command line info
Kernel: 6.1.126-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1a5f9d3d-6281-4281-bf22-d61ec4d6507d rw quiet apparmor=1
security=apparmor resume=UUID=b8ff2c58-bb8b-4145-9249-7e7194489c95
udev.log_priority=3
Desktop: GNOME v: 47.3 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-I GAMING v: Rev 1.xx
UEFI: American Megatrends v: 2801 date: 09/18/2019
System RAM: total: 16 GiB available: 13.57 GiB used: 3.23 GiB (23.8%)
Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK16GX4M2B3000C15 serial: N/A
Device-2: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1427 min/max: 1600/3500 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1427 2: 1427 3: 1427
4: 1427 bogomips: 27956
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: spec_rstack_overflow mitigation: SMT disabled
Device-1: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series
/ Radeon Mobile Series] vendor: ASUSTeK PRIME driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1
empty: HDMI-A-2,HDMI-A-3,HDMI-A-4 bus-ID: 06:00.0 chip-ID: 1002:15dd
class-ID: 0300 temp: 40.0 C
Device-2: Microsoft LifeCam HD-3000 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2
chip-ID: 045e:0810 class-ID: 0102
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Idek Iiyama PL2209HD
serial: <filter> built: 2010 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 102 gamma: 1.2 chroma: red: x: 0.651 y: 0.333 green: x: 0.286
y: 0.600 blue: x: 0.153 y: 0.075 white: x: 0.314 y: 0.329
size: 478x269mm (18.82x10.59") diag: 548mm (21.6") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
1152x864, 1280x720, 1440x576, 1024x768, 832x624, 800x600, 720x576,
720x480, 640x480, 720x400
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Info: Tools: x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Microsoft LifeCam HD-3000 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.1.126-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
tools: pacat,pactl,pavucontrol
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: c000 bus-ID: 04:00.0 chip-ID: 10ec:b822 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Info: services: mld, NetworkManager, smbd, systemd-timesyncd,
wpa_supplicant
Device-1: ASUSTek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 0b05:185c
Local Storage: total: 2.73 TiB used: 76.24 GiB (2.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: HD153WI size: 1.36 TiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: 0002 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM003-1SB102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BDDVDRW CH10LS20 rev: 1.00
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 59.6 GiB size: 58.37 GiB (97.93%) used: 43.11 GiB (73.9%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 1a5f9d3d-6281-4281-bf22-d61ec4d6507d
ID-2: /boot/efi raw-size: 550 MiB size: 548.9 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: D1D5-8DB4
ID-3: /home raw-size: 46.57 GiB size: 45.53 GiB (97.78%)
used: 33.14 GiB (72.8%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: f11661a0-e0df-42e3-b9d4-15dadc082b82
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: b8ff2c58-bb8b-4145-9249-7e7194489c95
ID-1: /dev/sda5 maj-min: 8:5 size: 37.25 GiB fs: ext4 label: DOCS-SSD
uuid: 9383c79a-c31b-4622-85fd-f5f33c28dd51
ID-2: /dev/sda6 maj-min: 8:6 size: 306.9 GiB fs: ext4 label: FOTO-SSD
uuid: 048a7943-8aba-488a-97a7-6e993865ff79
ID-3: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: ntfs
label: System-reserviert uuid: CC581B8B581B7404
ID-4: /dev/sdb2 maj-min: 8:18 size: 197.96 GiB fs: ntfs label: N/A
uuid: 26DE1FA5DE1F6C75
ID-5: /dev/sdb3 maj-min: 8:19 size: 745.06 GiB fs: ext4 label: FOTO-BACKUP
uuid: 539bfabb-e27d-4596-9065-7e3e66a1247d
ID-6: /dev/sdb4 maj-min: 8:20 size: 149.94 GiB fs: ext4
label: AUDIO-BACKUP uuid: 291bccba-e3ac-438f-9966-50819dff99e6
ID-7: /dev/sdc1 maj-min: 8:33 size: 25 GiB fs: ext4 label: AHNEN-HD
uuid: 8c092969-1a5b-4fe2-a9af-718db1df4cbc
ID-8: /dev/sdc2 maj-min: 8:34 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-9: /dev/sdc5 maj-min: 8:37 size: 400 GiB fs: ext4 label: FOTO-HD
uuid: 8993d4e1-aae9-4436-830d-d6fbf96cf694
ID-10: /dev/sdc6 maj-min: 8:38 size: 150 GiB fs: ext4 label: AUDIO-HD
uuid: bb926589-9a5a-470a-906f-8d7e245a28eb
ID-11: /dev/sdc7 maj-min: 8:39 size: 50 GiB fs: ext4 label: DOCS-HD
uuid: c59d6819-e055-4023-a036-42a8345c5c7d
ID-12: /dev/sdc8 maj-min: 8:40 size: 30 GiB fs: ext4 label: WP-HD
uuid: 6d665bfd-7a70-4e1e-a1cb-4ea3d90eccf2
ID-13: /dev/sdc9 maj-min: 8:41 size: 276.51 GiB fs: ext4 label: BACKUP-HD
uuid: 82b6aa40-d0a2-498e-a29d-c5bea553f6f4
Device-1: 1-2:2 info: Logitech M-U0007 [Corded Mouse M500] type: mouse
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 046d:c069 class-ID: 0301
Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:1872 class-ID: 0300
serial: <filter>
Device-3: 1-8:4 info: ASUSTek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0b05:185c class-ID: e001 serial: <filter>
Device-1: 3-3:2 info: Microsoft LifeCam HD-3000 type: video,audio
Device-2: 3-4:3 info: Logitech Illuminated Keyboard type: keyboard,mouse
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c318 class-ID: 0300
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 40.0 C mobo: 34.0 C gpu: amdgpu temp: 40.0 C
Fan Speeds (rpm): cpu: 754 case-1: 690
Power: 12v: 10.36 5v: N/A 3.3v: N/A vbat: 3.25
Packages: 2738 pm: pacman pkgs: 2725 libs: 564
tools: gnome-software,pamac,yay pm: flatpak pkgs: 13
1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
2: https://manjaro.kurdy.org/stable/$repo/$arch
3: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
5: https://mirror.23m.com/manjaro/stable/$repo/$arch
6: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
CPU top: 5 of 279
1: cpu: 100% command: ps pid: 2930 mem: 3.79 MiB (0.0%)
2: cpu: 17.9% command: surfshark pid: 2093 mem: 169.4 MiB (1.2%)
3: cpu: 2.9% command: surfshark pid: 1975 mem: 80.0 MiB (0.5%)
4: cpu: 2.7% command: brave pid: 2350 mem: 408.3 MiB (2.9%)
5: cpu: 2.5% command: Xorg pid: 987 mem: 128.4 MiB (0.9%)
Memory top: 5 of 279
1: mem: 408.3 MiB (2.9%) command: brave pid: 2350 cpu: 2.7%
2: mem: 364.6 MiB (2.6%) command: gnome-software pid: 1399 cpu: 2.0%
3: mem: 280.6 MiB (2.0%) command: gnome-shell pid: 1171 cpu: 2.1%
4: mem: 279.0 MiB (2.0%) command: brave pid: 2640 cpu: 2.0%
5: mem: 251.2 MiB (1.8%) command: brave pid: 2650 cpu: 2.0%
Processes: 279 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.41 GiB services: gsd-power,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: gnome-terminal inxi: 3.3.37
