I was installing some patches to suckless st and it was no problem till I tried installing the “scrollback-mouse-incremental” patch (installed the prior scrolling patches successfully).
I was trying to locate the code to be patched in vim, but no luck.
I have done that and in the image I posted, I show both the original file and the .rej file. The lines mentioned in the .rej file are not there in the original file, or at least, I can’t seem to find them.
In the following image, I go to the specified lines 163 tp 164. The line mentioned is not there.
(bottom file is the .rej and the top is the original file at line 163, col 8)
No, for all the scroll back ones, I went with the bottom-most one, here it is st-scrollback-mouse-2019024…
Should I try 0.8.2?
I can try that and reply how it went.
So, I am just applying the patches from the beginning, for the scroll back patches, what order do you recommend installing them in, Like, should I install the 0.8.x ones only?
i tried to get to the increment patch but for shift+mousewheel all patches are failing except 2019. you can manually patch 0.8.4 > 0.8.2 > increment. better off with luke’s st build or using alacritty (like me )
(2 highlighted lines correspond to the lines we need to change, here I have alredy applied the change needed)
Again, I have ignored the config.def.h.rej, it mentions Button4 and Button5 to have masks as “ShiftMask”.
and so the only change for this patch must be that of .i = 1 → .i = mousescrollincrement
After making this change and compiling the program successfully, I have not noticed any real change in the scroll speed or anything else. Maybe I have screwed up and someone can correct me, thanks.
