Good morning,
I would like to know if standard layout after fresh manjaro install with BTRFS is ok for Snapper.
I want remove timeshift and install btrfs-assistant & co.
Thanks since now
Good morning,
Thanks since now
btrfs-assitannt is an excellent tool - I’d recommend you keep timeshift installed due to the default snapshot done before pacman is run.
yes but btrfs-assistant is more versatile than timeshift
For pacman there’s also snap-pac that make it’s work.
Unfortunately I don’t find nowhere information about subvolume and manjaro, I don’t find any new information on this matter, only tutorial from two years ago made with Manjaro Architect, but also this has gone to good life…
Timeshift is a snapshot application originally created for use with ext4 - btrfs-assistant can do specific filesystem maintenance which was never the intention of Timeshift.
The default btrfs layout created by the installer works fine - what should make snapper choke on it?
nvme0n1 259:0 0 476,9G 0 disk
├─nvme0n1p1 259:1 0 300M 0 part /boot/efi
├─nvme0n1p2 259:2 0 467,8G 0 part /var/log
│ /var/cache
│ /home
└─nvme0n1p3 259:3 0 8,8G 0 part [SWAP]
So should be fine?
I am a novice with btrfs.
I don’t see why one layout should be better than another. Unless you want to fine tune the filesystem a lot - I see the Manjaro default as a reasonable middle ground.
Test it and draw your conclusions from your test.
Everyone has their own way of doing things.
If i remember right. snapper is from suse ![]()
I do use btrfs and snapper with my own layout.
# subvolume to snapshot
SUBVOLUME="/"
SUBVOLUME="/home"
PARTUUID=3ee1dfe1-19af-4102-945d-90d957d3c199 / btrfs rw,noatime,compress=zstd:9,commit=300,subvol=@ 0 0
PARTUUID=3ee1dfe1-19af-4102-945d-90d957d3c199 /.snapshots btrfs rw,noatime,compress=zstd:9,commit=300,subvol=@snapshots 0 0
PARTUUID=3ee1dfe1-19af-4102-945d-90d957d3c199 /home btrfs rw,noatime,compress=zstd:9,commit=300,subvol=@home 0 0
PARTUUID=3ee1dfe1-19af-4102-945d-90d957d3c199 /home/.snapshots btrfs rw,noatime,compress=zstd:9,commit=300,subvol=@home.snapshots 0 0
PARTUUID=3ee1dfe1-19af-4102-945d-90d957d3c199 /var/nosnap btrfs rw,noatime,compress=zstd:9,commit=300,subvol=@nosnap 0 0
## Path: System/Snapper
## Type: string
## Default: ""
# List of snapper configurations.
SNAPPER_CONFIGS="root home"
I do use snapper & snap-pac ![]()
By default snapper will create a nested layout (which i do not like, because it is not as easy to manage manualy as a flat layout)
